Lubricants
11 minutes ago, Alastair said:
OK--In the spirit of education--What are the opposing properties of (Thin Grade, 9010/20) watch-oil and motor-oil?
Some just off my mind:
watch oil: restricted temperature range. Motor oil - the opposite
watch oil: to forms lubrication between hars stones and metal film - watch oil - meta to metal only
motor oil: resist pressure via oil pump:- watch oil: no pumping pressure
motor oil: contain all kinds of additive like anti-foam, cleaning, detergent for combustion residue. watch oil, nothing of that is needed.
I'm sure anyone can come up with with some 30 more and then the most important: the product is designed and tested by the maker and moto (or watch) maker. Or do we want to have a laugh all together at the next watch fair, see you at the Mobil booth.
Edited by jdm
I'm going to do a full service for ETA 2896 movement and the service documentation says that the oils needed are:
  • D5 (OK - I will use HP1300)
  • 9501?
  • 9010 (OK - I will use 9010)
  • 941/9415 (OK - I will use 9415)
  • Treated (ETA)?
Other oils I have available at the moment are 9020 and 8200. What does "Treated (ETA)" mean, can I use 9020 or 8200 as a substitute for 9501 and/or "Treated (ETA)"?
I use 8300 instead of 9501. 9501 is synthetic and way expensive. I think 8200 is a little to oily. 8300 is more like grease?
Have some 9501 but tend to use 8300 most of the time.
Edited by rogart63
2 hours ago, beastomaniac said:
I was just thinking that could I use 8200 instead of 9501...
There is only one place where you should use 9501 on a 2892. That is the underside of cannon pinion . I think you can use HP1300 or 8200 there. Or a breaking grease like 8217 . It very little you need?
Or what does the other guys say?
Don't forget to check the reversing wheels before you clean them. Very often outworn.
Just my own observation here.  About 3 years ago when repairing some vintage long clocks I did a very small scale test of Mobil 1 vs a clock oil I have used for years because I am cheap and was looking for a alternative.  The Mobil 1 was 0w20 which our Prius's use.  Two very similar clocks cleaned and lubed, one with clock oil and the other Mobil 1.  Both are still running fine today but...and it's a big but.  In performing this test I had put a small amount of Mobil 1 in a clean bottle cap which I was using for a oil cup during the servicing.  Couple of months ago while cleaning my computer desk I found this bottle cap with what remained of the Mobil 1.  It was a noticeably thicker and sticky.  Wish I had saved it now to post a pic but I didn't.  I wouldn't have thought a fully synthetic oil like Mobil 1 would evaporate like that but it sure did. The bottle cap had remained covered with a tinfoil cap so it wasn't dust and it is possible it could have reacted with the thin plastic coating on the inside of the bottle cap but that appeared unaffected when I poked around it with a toothpick.  Like I said at the start, just an observation.  And thankful that clock oils aren't as costly as watch oils.
I suspect that on a watch Mobil 1 would be a disaster
Sent from my GT-N5110 using Tapatalk
One of our members has a chart of his experiments with motor oil and posted it so I suppose you guys can check it out...I tried to find it (pdf) but didn't have much time. I'm sure it will give some information about the subject. Also, oils and lubrication is an argument waiting to happen as Clockboy said, so no matter what the result as per experimentation and/or chart consultation, I'm sure we will always be reluctant to change our ways, specially when they gives us good result and peace of mind. Therefore, Moebious will always have the upper hand and Mobil will never make it to the watch industry...unless they are willing to spend lots of money to win the - for them -- "meager" new market (no comparison in volume sales cars vs watches).
Just my two cents. Also, I will try and use always the recommended oils until I know better but that's simply affirming the above.
Cheers,
Bob
Dr Tillwich Oils.
An alternative source from Germany for specialised (watch) lubes which are cheaper than M etc.   They have some really decent oils and greases. Home site data sheets and source on e**y links below.  I spent many years in lube industry so can help interpret tech data if needed.
http://www.dr-tillwich.com/index.php/en/produkte-3/schmierstoffe/datenblaetter
http://stores.ebay.co.uk/uhrmacherwerkzeuge/Uhrenole-Dr-Tillwich-/_i.html?_fsub=9879334017&_sid=111822197&_trksid=p4634.c0.m322
7 hours ago, canthus said:
I came across that research findings last year, but ever since, its not shown up anywhere to of been developed for the marketplace which is a shame.  Its something that I would love to try on some Chinese movements that have been modified with extra gear train for moving the native seconds @9 to either sec@6/12/3.
10 hours ago, canthus said:
Very interesting article & yes maybe it is the future of lubricants. My only issue is not the non friction properties of the crystalline oils but can they stay where put. This is the dilemma with watches & clocks. They need lubrication but the oil/greases must stay where applied.
1 hour ago, berniethebolt said:
what about pegasus/anchor/porpoise jaw oils?
Murdering poor defenseless porpoises to steal their oil is generally frowned upon and that would include whales in the same category.
Anchor oil has really interesting properties especially when you Google it. Then usually in horological discussion groups the subject is undesirable lubrication. So you have to wonder if the few horror stories you hear are just a few or whether all of the oil is bad?
Then Pegasus oil I have no idea what that is?
there has been a lot of research done on oils since 1945.  probably not for watches, but for military use, like 50 cal. air craft machine guns ( see p-38s are not oiled).  detergent and  multi viscosity oils were available after ww2i use.  the mineral non detergent motor oils DEFINATLY  have a shelf life.  standard oil of californa has a research lab where oil engineers have been working for many years.  i use motor oil on clocks and  watch oil on watches.  if the experts change watch oil every 5 years,  so be it.  vinn
This topic is now closed to further replies.
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro. I thought the idea was for the epilame to create a barrier, a wall between the lubrication and anything else, so the lube cant spread.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
