I've just bought a small amount of the Horotec Episurf-Neo, which is advertised as a 'next gen' epilame treatment.
Directions for use say 30 second dip, 60 second dry at air temperature. So no heat required.
I too am looking for a cheap DIY alternative to the special dip bottle. I've been experimenting with the little filter baskets from the water inlets on washing machines! Haven't found the perfect solution yet, but I'm working on it!
  • 1 year later...
I was thinking about using Fixodrop but  have a hard time figuring out what parts to use it on. The fewer the better considering the abhorrent price for it. What I got so far.
* Pallet jewels
* Escape wheel
* Reversing wheel on automatic
* Balance End stones
What is your opinion on this ? Should the end stones be treated, and if so, does that include the chaton ?
https://www.cousinsuk.com/category/moebius-fixodrop-fk    This link will give you ther page on Cousins site regarding fixodrop/Epilame  not only is it expensive, there are also hazzards in using it as explained in the following link  http://watchmakingblog.com/2011/07/29/one-hazard-of-epilame/.  I would suggest reading both and makining an informed descision         cheers
  • Thanks 3
17 minutes ago, oldhippy said:
I myself never used such stuff, not sure if it was around in my days, besides I had a very steady hand.
Yes it was, 1957 Omega literature explains it, in the 60s Greiner made a machine to apply it from bags of stearic acide, after ultrasonic cleaning.
I've neither used it so far, I think that today's quality of lubricatints helps doing without it, at the same time I don't have enough experience to recommend one way or the other.
15 minutes ago, praezis said:
Don't forget to run the movement dry for some minutes, before oiling.
Frank
You should never run a movement dry. It needs lube no matter for how long. More then likely you will need to add oil as you re assemble the movement as the more you add parts the more difficult to oil certain parts become.
In csse of runing movements, I take dial and disk plates off, wind full and drop the whole movement in avgas( absolutely friendly to shelac) , if it ran whilst submerged, I lets it run overnight to clean itself, then disassemble it for clean& service.
 My late repairman frowned on this practice of mine but never explained the reason.
This is a chance to put my question to vote, your thoughts please.
By avgas you mean kerosene I guess? Why not, I don't think it will hurt anything, but getting all of that cleaned off would eat a lot of solvent or cleaning solution.
  • Haha 2
Aviation gas = avgas ,  I am not sure if this grade of avgas runs piston airplane or turbine engines( diferent I hear), but has no effect on shelac and no visible effect on base metals either.
Some calibers wont run while submerged.
Thanks for your response.
15 minutes ago, oldhippy said:
It’s one way of causing extra wear on a movement, pivots could shear off, all sorts of damage could happen.
Oh I mean submerged and running with oscilator, so runs at low speed, if thats your concern, amplitude also drops.
I’ve done something similar to what Nucejoe describes when doing a “pre clean” on an utterly filthy movement with L&R cleaning solution. Personally, I don’t see any great risk of harm. The aviation fuel probably provides a reasonable amount of lubrication for the short amount of time that it is running.
Avgas has lead in it. Is it enough? No idea. It’s 100 (min) octane gasoline.  Turbines (jets) run on Jet-A which is essentially kerosene.
I had also considered such action at times (with Ronsinol) but never did. Cleaning is always better when you have access to both sides of plates.
Edited by Tudor
On 8/29/2020 at 3:44 PM, nickelsilver said:
Run the movement with the pallet jewels dry for some minutes, this allows the escape teeth to scrape off the epilame from them and that non-epilamed "track" holds the oil.
Thanks, nickelsilver!
I was referring to the epilame treated parts only, acording the topic.
Frank
One of the problems with watch repair is the age of the technical information. A problem with the age of the material is it's possible that things have changed like even fixodrop? Like for instance at the link below there is variations lots of them? Plus they've changed the solvent to something more environmentally supposedly friendly. Changing the solvent has had other interesting changes.
For instance 7061 This one's interesting wash resistant if you download the technical sheet it tells how to apply it. Then since I really enjoyed the answer "NO" up above I'm going to quote something "Fixodrop-treated anchor pallets should be lubricated only after running dry for 1 to 2 minutes" Unlike the answer "NO" up above it's okay because it's only the pallet stones. You need to remove the surface treatment so the oil will stick otherwise you're going to have issues.
Then they explain the drying procedure. This is interesting because the previous solvent they were using would evaporate so fast that if you weren't very very careful the cooling effect would cause moisture to condense out of the air eaving a microscopic coloring of moisture on your nice clean steel parts which leads to rust. This is why shops using this a lot of times I have a hot hairdryer radius and is a part came out that immediately put hot air on to hopefully avoid this. Now it's supposed to be better and not have that happen.
Only the end stone should be treated not the setting.
http://www.moebius-lubricants.ch/en/products/epilames
  • Similar Content
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
    • I overhauled a ladies Rolex and noticed erratic performance so I stripped in down again and did fault finding. This is what I saw. The lower jewel (the one in the plate) is cracked and the hole is too big. Before discovering this, I stripped down and re-cleaned the main-plate (and parts) by hand with a fine natural fiber brush. I somehow missed the fault the first time and cannot understand how it was still running. Perhaps re-cleaning it dislodged some pieces of the jewel widening the hole? I don't know. Now I need to replace the jewel but don't have a Seitz tool. The Rolex part is 2130-0913 and the top and bottom are the same. The part comes complete in brass setting with KIF elastor spring and cap jewel. Note: I have never replaced a jewel. I do have a good vintage stacking set that I've used quite a bit.  Can I replace using a stacking set? Any suggestions would be greatly appreciated.
