On 5/7/2019 at 2:36 PM, oldhippy said:
Why is it so expensive? I have never used it. I didn’t see the need to have it.
Couple of members reported good results used on reversers. What do you recommend instead?
3 hours ago, vinn3 said:
why is anything "over priced" ?  greed
Only in today's corporate speak, it's referred to as maximizing a return on investment. I prefer to keep it simple. It's just plain greed and pretty ugly at that!
I think it's priced the way it is because it's scientific glass, with the basket mod, with a small market. If you don't drop it you'll use it 2-3 times/day for 20 years, so not so expensive. As for Fixodrop itself, again, small market, high tech chemical, price goes up. Same with Moebius oil, it seems expensive till you realize how much work one can do with a given quantity.
I find synthetic motor oils expensive given the size of the market. But they are better so I'll buy them.
10% Economies of scale, 10% high quality control, 80% Fancy Swiss brand with huge consumer loyalty taking the mickey with their prices.
I'm sure if the oils were the same quality and half the price there are people who wouldn't buy it if because it doesn't seem expensive enough.
   right you are Tex.  vin
On 5/7/2019 at 12:21 PM, clockboy said:
I have been dealing with a PM re-using Fixodrop (Epiline)and I was also going to recommend purchasing the dedicated bottle until........... "Cousins" the price quoted £134.95  absolute madness.
When you first recommended it, amazon showed 50cc bottle for €50 but unavilable.
I think we all be happy with 10cc bottles for €19.99 .I don,t see why such a high volume is offered to the customer.
1 minute ago, m1ks said:
I've never used it, (I wouldn't be able as the price makes my eyes water so I wouldn't be able to see where I placed it).
But I'd imagine there's only placing with an oiler or dipping?
Thank you.
I managed to obtain a bottle rather cheaply so am curious as to the best way to apply, my thinking was to use an oiler but really not sure.
Out of curiosity which brand and type did you get? The reason for the question is if you have the new environmentally friendly version where it's applied is different then how it was done in the past. The link below talks about the hazards of the past solutions.  .
The  purpose of this solution is to keep oil from spreading. As the link below talks about like all horological lubrication discussions where it's applied how it's applied can vary by quite a bit. For instance Omega in the 50s did not recommend applying it to the pallet fork at all. Versus today Universally everyone applies it to the pallet stones but nothing else on the pallet fork. With the newer environmentally friendly version it comes in really big bottles like 1L 5L  according to the most recent Omega document it should be in the last rinse of your cleaning machine and almost everything is covered with this versus the past where it was only applied to a couple of parts.
http://watchmakingblog.com/2011/07/29/one-hazard-of-epilame/
Hi,
Thanks for the information, most interesting and useful information.
I purchased through a Watchmaker moebius 8981.
  • 4 weeks later...
What would be a good method for applying Fixodrop without using a special epilame bottle?
Servicing my first ETA cal. 2824-2 I’m going to follow ETA’s tech sheet the best I can. Probably not necessary but that’s what I’ve made up my mind to do. This means I will have to treat certain parts with Fixodrop (8981, Fixodrop ES/BS-10).
No big deal, right? Wrong! Big deal! The Fixodrop 100 ml is £107 (incl. tax) and the epilame bottle is £162 (incl. tax). In total with shipping (to Sweden) that comes to £278 (€312/$352). These prices are from CousinsUK.com and those prices are competitive, trust me! So, for my money, I get a solution and a glass bottle, although a bit special. There are some less expensive epilame bottles, but the prices for these bottles are still "criminal".
Am I going to place an order? NO! The Fixodrop can be bought on eBay for approximately three times as much as offered by CousinsUK.com, but it can be bought in smaller quantities. So, that’s what I’ve done. I’ve ordered 10 ml (still very painful, $54 with shipping :pulling-hair-out:)
So, what would be a good method for applying the Fixodrop to the parts without using a special epilame bottle? As I understand it, Fixodrop is very volatile so I guess that can pose a challenge!?
I use a little bottle like the pic, 30ml, got it at the drugstore. I fill it about 1/3 of the way. Escape wheel get plunged in with tweezers, cap jewels the same, for the pallets I dip closed #5 tweezers in which suck up a little, and deposit a bit on the stones.
My colleague uses a 10ml plastic lab bottle with a really fine spout, and squirts some on a fine artist's paintbrush (like really tiny) and applies where he wants.
I know they say to soak for a while but that's tricky to do keeping contact with just the pallet stones, and the quick dip really works fine.2413c0c2a0f66b0c6fab9a0f32edbce2.jpg
4 minutes ago, Nucejoe said:
Hi nickelsilver, How about reversers ( winder module),  plunge in?
Thanks in advance.
I plunge whatever I want to treat, except for the pallet fork, since it's been demonstrated that it's detrimental to epilame the fork slot and pivots.
Edited by nickelsilver
Thanks in advance.
This is what ETA has to say about the reversers in the tech sheet:
"Do not wash. If the part is very dirty or rusty,
it should be exchanged for an original part
which is lubricated and delivered by
ETA SA."
Now, I saw Mark Lovick soak them in Lubeta V105, and that's what I'm going to do as well. Don't think you're supposed to treat them with Fixodrop.
ETA SA."
Now, I
That's right- except for Rolex where it's mandatory (they won't work right without it).
I too bought a small 10ml bottle some time ago.  I do not use epilame a lot so like others I needed to conserve as best as possible.  I eventually came to using an old package case from a balance complete purchase, a small round item with lid.  This is big enough for the few items I have had to do.  I fill it from the bottle, immerse the item for 5 mins, then allow the item to dry under a warm light bulb.  The remaining epilame is then poured back in the bottle for next time.  It says its very volatile but not so that it just vanishes as soon as you use it!  I gather that for surfaces that need to retain oil then they should be run dry for a few minutes to remove the epilame from the working surface (which needs to retain lube) but leaves it on the non working surfaces which need to be lube free.
  • Similar Content
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
