Dial (face) cleaning?
On 13/05/2018 at 10:18 AM, Redwood said:
Can the lost lettering/ branding be replaced with water slip transfers printed on a home printer and then apply a thin coat of varnish, or will this look dreadful
If you have a really good camera, a really good printer and you are good at using Ilustrator and/or Photoshop ... then it's doable.
Take a high definition picture of your dial, without crystal and perfectly front picture of course.
Open it with Photoshop and change the image so that the lettering is the real size and the definition is 4000 ppi.
Then you redesign the lost lettering on a specific layer.
Here you have to mimic the "age" of the remaining lettering cause you want to repair an old dial ... not make a brand new one.
When the design seems OK you print your file (only the layer with lost lettering) on clear decal paper, spray 1 or 2 really thin coats of varnish to protect the ink (unless you have a laser printer).
Then you can cut your decal and transfer it on the dial, trying to perfectly adjust the position.
Let the decal dry for about 24 hours then spray all the dial with a thin coat of varnish, matte or bright depending on the finish you want.
Protect the dial with a glass and let the varnish dry for about 48 hours.
Now you can put your dial on the movement, case everything and enjoy your refurbished watch.
If you try that one IMPORTANT thing is you must make you first tests on dials you really dont care about, because at first you could do more damages than improvements.
Tough call on that one... The issue is the clear coat/lacquer turning yellow. You can usually remove it gently with an ammonia based window cleaner and a q-tip (rinse in lots of water and dry thoroughly when done). BUT, you can also see that the black paint used to mark the minutes is sticking to the lacquer, so removing the lacquer may cause all the black paint to come off as well. Same reason why I'd keep it out of the ultrasonic cleaner: the lacquer is already chipping and the vibrations might cause it to chip even more.
If it were mine, I would leave it alone.
If you decide to go ahead, let us know what you end up doing and take pictures!
Good luck!
I would leave it alone. If you think that's bad you should see some of the dials that I've handled...
Too risky to go ahead with this. Quite possibly the paint will start to come off. Not entirely but it'll turn bad and out of place.
  • 4 months later...
Hi All,
I am just getting started in the hobby and wondering what the best approach is to cleaning my dirty watch faces on my military watches (A-11 type), some are really faded and stained and some look like the inside of a coal fired boiler.  I recognize they will never look minty fresh, but a little cleaning will help several of them
Just looking for general suggestions /"tricks of the trade" before I do any real damage ..
There was a discussion recently here on radium do a search and see if you can find it. The problem with radium is it burns out the phosphorus relatively fast it is still radioactive for a very long time and depending upon how much you have it's not good for you. Then military dials and hands tended to be much much more radioactive than the civilian stuff.
  • 2 months later...
I have this vintage Seiko digital LCD watch from around 1985. The "dial" seems to be very dirty and I'm wondering how I can go about cleaning it. It looks like its mostly dirt and grime. What can I use to clean it? I tried looking around for a NOS dial with no luck...
Edited by seikoskx
Hello,
I'm working on my AS 341 movement and am trying to clean up the dial.  So far I've been able to polish the numbers by rubbing the face against some paper with a bit of polish on it.  I've also tried using a bit of soap and water as well as isopropyl alcohol, but I'm not able to bring it back to what I would expect is "clean".  Does anyone have any tips or experience with cleaning old watch dials, or what a watch dial like this "should" look like?
Closeups were done with a DLSR, taking an old manual lens and using it backwards.  Makes a great cheap macro lens!  Just make sure to check the mirror won't hit anything and the aperture is as small as possible
Thanks!
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
    • Hello and welcome to the forum Dan. Used to know Middlesboro quite well, that was twenty years plus ago. Attached a little reading to get you started. TZIllustratedGlossary.pdf
