I texture the inside of my tweezers with emery paper, 500 grit? i forget exactly, on the finer side but c.o.a.r.s.e enough that you can still feel the grit with your fingers. Just place the paper inbetween, close the tweezers and pull, fold it to do both sides at once.
Edited by Ishima
Carbon steel tweezers can be glass-hard. My stainless Dumonts are softer and still get magnetised slightly anyway. I also have their "Dumostar" versions which are very hard, to be fair.
As already mentioned, dressing them is very important, including giving the insides a slightly co**BLEEP** finish to provide grip.
I suspect your Dumostar may have a higher nickle content to achieve their hardness. As previously mentioned, EN21 steel retains flexibility or to be more precise elasticity but derives strength through its nickle content
Sent from my SM-T585 using Tapatalk
Love my Dumont carbon No.1s but the **BLEEP** things are sooo magnetised. I have half the **BLEEP** watch hanging off of them. I really must get a demagnetizer....:angry: My stainless Supras are nice though...nice and light. Really must get a set of brass ones though. Have a set of Dumont No, 5 in stainless but have not used them yet so can't comment on them.
Why in the heck can't we say c.o.u.r.s.e.??? or b.l.o.o.d.y....
Ron
Edited by 94marconi
spelling
@RyMoeller Since electronics are also in my hobby spectrum, I knew these tweezers are anti-static & anti-magnetic Stainless Steel. They don't come with a watch-brand printed on them, perhaps hence the cheap price?
IMHO, they work great !
http://www.ebay.co.uk/itm/6pcs-ESD-Anti-Static-Stainless-Steel-Pointed-Tweezers-for-Repair-Tool-/272088601890?hash=item3f59be9522
ESD-11 is, together to my brass tweezers, the workhorse.
Edited by Endeavor
  • 10 months later...
Apologies if this has been covered numerous times, but what are your preferred tweezers, manufacturer, sizes (and material, eg: non-magnetic SS or brass) for removing screws, bridges, etc...?
I have a lot to select from. Too many.
I always used Dumont s/s tweezers, 3 for basic watch work and fine clockwork, 5 for fine watch work. For large clockwork old tweezers that would have, the out of shape or broken points filed down. Even older ones for soldering work.
I use Dumont 2 for just about everything.
I have some brass ones (just says '3' on them) for handling steel components I don't want to mark
and a very fine Vetus pair for (usually screwing up) hairsprings.
Three 3c seems to be very popular with a lot of people and I prefer number 2 for watch work. So tweezers I use are made by Fontax and they're called Taxal nonmagnetic. There are actually very interesting how they're made casual observance they look like normal tweezers careful observance you'll notice that the tips are made out of a different material. Normally anti-magnetic is soft these are not whatever the alloy is is almost indestructible. Then unfortunately I've seen the modern version and they changed the shape slightly I don't like them. This represents one of the problems of there's no universal standard for numbers of the tweezers various manufacturers have slightly different interpretations.
Still have not done any real work yet, but have been practicing picking up parts and dressing tweezers, etc.
One thing I did discover early on is that your hand size can make a difference to which tweezers work best.
I have large palms that just swallow up many tweezer sizes, so the longer ones work better for me, at least for general work. AA and SS, for example. For finer work like hairsprings you just have to manage with what is available.
I find that the SS tips can cross a bit easily compared to the more robust AA. Might just need more practice. But I did slim my AA tips down a little finer and that seems a good compromise.
Also slimmed the shoulders of the AA, more like the 3, so I can more easily roll the tweezers in my hand.
My favourites are Dumont dumoxel #2 for most work then #5 for hairsprings.
I bought a set of Vetus tweezers from Cousins to get a range of shapes and sizes, but there is a reason why the Dumont ones are nearly 10x the price and I tend to just use these for odd jobs. Good tweezers feel like an extension of your hands. Cheap ones are an obstacle to learning to use them and you will regret the difference in price the first time you ping a part across the room.
I’ve also picked up some used oddments from eBay: Fontax #4, good for fine work; Fontax F, which have polished tips for handling hands; and Dumont carbon steel #7, useful to use with the #5 for hairsprings. I have also seen a lot of abused tweezers which have gone for high prices on eBay.
I use Vetus tweezers and have absolutely no problem with them. It's the person and his/her dexterity that does the job, not the tool.
Well yes - this is sadly true, but lacking the experience, I find the Dumonts much easier to work with. :)
I’m assuming you are talking about the Vetus ones that cost about £4 a set? Be interested to know what yours were like straight out of the packet?  Mine needed a lot of work to get the tips to anywhere near the finish of the Dumont ones.
Some Vetus are fake, especially the eBay ones. I have a fine of fine ones. They are ok, but have more twist at the tips than Dumont and are a lot softer. Basically, they are not as good, but they seem like good value.
Yes, I think so. I did nothing to them, I just try to grab parts as logic and physics dictates. I don't expect the tool to make any miracle and in return for a good service I do not abuse it.
I have bought some more tweezers from a now defunct domestic maker, but haven't even tried them.
  • 2 months later...
I have a ladies, very small, (No model number on it) Sekonda wind up watch that needs some work attending to on the hairspring.
This obviously represents quite a challenge and, without really good, fine tweezers, I think there's no hope of (Hopefully) getting this watch back in use.
I use a stereo microscope and when I view the tweezers that I have, they look like a garden shovel; compared to the hairspring!
Can anyone recommend any reasonably priced tweezers and where to buy?
I know there are plenty available, but they are way too cost prohibitive.
Vetus make a fine tipped set of tweezers, but buy them from Cousins, otherwise you will probably end up with a fake pair like I did.
Ideally you would get something like Dumont 5.
  • 2 months later...
I also have a "fake" pair of Vetus tweezers, and after putting them through the "ringer" of completely refining the tips, they work nearly as well as my trusty "ZEE brand medical tweezers that I currently use for EVERYTHING, including installing crown tubes!
Since I don't like to rely on only one of any critical tool, I'm currently mid-search to see if other brands (Such as Stella) are good, or if I should just bite the bullet and get Dumont tweezers. Honestly, it's second (maybe) only to screwdrivers with regards to how often they are used so I guess I'm answering my own question regarding: "Should I just get Dumonts..."
    • Funny I should come across this particular thread because I have a hairspring that I’ve just knocked the collet off!! It was too loose on the balance wheel and I was trying to tighten it (of course I failed!).  So I’m looking for a new balance myself. The hairspring is in quite good shape but obviously doesn’t have a collet now, so I don’t know if you’ll be able to use it. I wouldn’t dream of trying to refit the collet myself because I know exactly what would happen!! If I wanted to refit the collet to the hairspring (assuming I can find the original as it’s on the floor somewhere!!) where would I find a taper pin small enough? As some of you may know, this whole thing is tiny!!
    • Thank you. No value to me, and I guess not much value to anyone else either - just practice fodder as far as I see them. Ingersoll might make a nice watch to wear if I manage to service it. Benrus, I suspect, is too far gone in terms of case and dial - no cheap ways of getting them to decent looking condition? I wonder how these old movements compare to modern Chinese ones? Probably not favourably, even if there's nothing broken in them? Progress moves on? I've got an old Slava that I'm quite attached to, so I won't be learning on that one.
    • Welcome to the forum. You're best starting with something that you know runs well and keeps good time. That way when you've stripped and service it, any problems are due to something you've done.
    • Welcome to the WRT-Forum! Sorry to say it, but you’re very likely to break or lose something when servicing a wristwatch for the first time — I’ve been there! So, if these watches have any value to you, don’t attempt to service them as a beginner.
    • In writing "shimming the staff" I was alluding to the idea trailed in the above referenced thread of inserting a hair along the staff which, as the discussion there covered,  could result in some eccentricity. By making a (more or less) complete cylinder I was hoping to avoid that problem. Don't tell anyone, but needing a very ductile metal to do this by manipulation at such a small scale, I used a piece of an empty Tomato pureé tube! It occurred to me that the material's ductility(?) would also put less stress on the RT in forming a sufficiently tight seal. Anyway, that's how I avoided the temptation to use glue. No doubt your punctuational response to this confession will be "!!!" !
