I know this is a simple question but I'm new so I don't know much.
I am about to use for the first time an old style L&Road variomatic cleaner. I have been trying to read up on what type cleaning solution and what rinse to use. It seems most of them are advertised as used with ultrasonic cleaners, I don't know if that will also work properly in an older style machine.
Could someone advise me on what is the proper solution and rinse to use for my machine please ?
Thank you, Tom
Hi all
I use an ultrasonic cleaner with greiner cleaning solution, followed by a 2 stage rinse with Isopropanol
it does a great job at cleaning, but once the parts have dried my method leaves very light marks / blemishes. For info, after rinsing I just let the parts dry under a cover of some sort (glass or jar).
See my pics below, although it is not that obvious on the pics
Should I be getting better result (cosmetically?)
I am not sure what causes these marks, would I avoid them by heating / drying the parts quickly? (E.g. Using a hair dryer or similar). Photo%2021-09-2016,%2022%2029%2052.jpg?dPhoto%2021-09-2016,%2022%2029%2030.jpg?d
thank you very much in advance
Hi Oli, I don't have a lot of experience on cleaning parts using your method but I certainly would not allow my parts to "drip dry" the way you currently are, I for sure would hit them with hot air from the dryer and see what happens, can only see it being an improvement.
Would be interested to know how you get on, please keep me informed!
Brian
Thank you very much gents. I will try using a blower first, it sounds like that could well resolve my issue!
i will let uou know how I get on next week, I am planning to strip a 7S26 I just got from ebay.
thank you very much
Edited by oli
Hi guys,
Another question from a newbie: I have a rotating cleaning machine with three jars. In the first jar I have Sambol Platina 1:20, in the second jar Elma reinigungskonzentrat 1:9 for rinsing and in the third jar sterilized water. Thereafter the basket goes in the heater chamber.
My issue for now is that the first jar completely foams up. The jar is 3/5 full with the solvent but becomes completely foamed up. Is this a problem with the solvent or is it not actually a problem? I got this solvent from watch-tool.de
Stian
Hi all
i have tried heating the parts withba hairdryer after my 2nd rinse, and I am pleased to report that the results were great, no residue! The wife will be looking for her hairdryer now!
thank you all for your responses and advice
Edited by oli
I have recently acquired some vintage Vostoks, and my dads old Seiko. All have stainless steel cases.
I want to clean the cases (disassembled of course) in my ultrasonic cleaner. I am not able to get my hands on any of those professional cleaning soutions like L&R because of restrictions. Is there any good alternatives I can use? Is isopropanol a good option as a final rinse?
Thank you.
Washing up liquid is usually fine. A warm temperature (say 40c) can help. Don't run your ultrasonic for extended periods like over 10 mins without giving it a break to cool down as they can fail for this reason.
For cases, I usually find that hot tap water works fine as a rinse.
Thanks. I want the cases to be really clean. Isopropanol can't hurt, can it?
My ultrasonic cleaner has a cooling fan and heat protection that shuts it down if its gets too hot. It can be set to a 30 min cleaning cycle and has a heating element. Is it not reasonable to believe it can handle more than 10 minutes?
As mentioned before I've found that warm water and dish soap is the most effective for the type of dirt found on case and bracelets. But I that guess one can use anything else too.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
