I would like to try the Brunnel microscope. If it’s anything’s you and others say it is, I would like to get a used one.
Thanks. I’ll let you know how it works out.
After VAT, shipping, and the Pound to USD exchange rate it became cost prohibitive.
I ordered an Amscope SE-400-Z instead. 10X and 20X pairs with X1 objective. I also won’t have to buy a voltage converter.
I hope it works just as well as the Brunel BM-1.
  • 4 weeks later...
Santa left me one of these under the tree :thumbsu:
I like to take this quiet time to clean and redress all my tools and equipment.
The microscope was used to check my tweezers, screwdrivers and holders, the screen gives a great picture of the critical parts and is much better than using an eyeglass.  My tweezers in particular now have complete contacts (no bent up end, flat faces etc) and square ends, so hopefully fewer parts will go flying away.  They certainly seem to pick-up better.  My drivers were manly ok with only the odd burr to remove.  The edges on my holders are now better and seem to hold better.
Can't wait to use on watch movements and maybe go back and sort out some the messed up hairsprings !!!!
I also purchased one of these thanks @canthusand @transporter
I too use it for dressing tweezers, screwdrivers and the like but for watch movements I would not be without my long arm microscope for most of the work....However it is good for recording a dismantle process on a micro sd card for later reference or in laymans terms Where the b..... hell does that piece go.
I use an Carl Zeiss Stemi DV4 Stereo Microscope to inspect the jewels with, before I used it as one is supposed to but nowadays I have become a bit lazy and put a cheap USB camera on the ocular. Took me 22 minutes to make it with a 3D printer.
One can get quite a nice picture on a computer screen with a setup like that and even take one odd picture on for example a cap jewel.
5 hours ago, mlfloyd1 said:
Elevation speaking, when working on watches should the microscope be used on top of the watch bench or on top of a standard desk?
I would guess that depends on how long you work by the microscope. At a labaratory one mostly costum fit the microscope to fit your hight and so on. I use a standard desk but have an adjustable chair instead.
Some of our yonger personel even likes to stand on a ergonomic rubber matt instead of sitting.
Here is some instructions from Leica about the matter.
Reading this thread has me really wanting a stereo microscope.  I'm just a watch hobbyist, but I also do quite a bit of work on smallish firearm assemblies.  I've been looking at scopes like some of the 10-20x ones on Ebay for over a year now.  There is one that gives an 8" working area, which seems like it would be adequate.  Some times, even when using a loop I will bump my screwdriver hand with the loop. A little separation seems like it would be a nice thing.
From this thread, it sounds like the 10x power is the most utilized?
  • 6 months later...
Just to be clear: this is being sold by the Horology Club that I am a member of; I won’t benefit from any sale but the club will (which is a good thing!). Mods please feel free to nuke this post if that crosses any lines.
With that out of the way, I’d just like to point out a large Zeiss microscope that is being ebayed at the moment in Essex, England. Listing is 254317526719
People may not notice it as it is not listed under watch or clock tools.
It’s a medical quality ‘scope on a blooming big stand! From what I’m told the working distance is perfectly suitable for watches and clocks (depending of course on how big your clock tools are!).
So If anyone is in the market for a decent quality ‘scope in that area it could be of interest to you.
6 hours ago, oldhippy said:
I’ve just had a look. Quite an impressive piece.
We don't need to nuke your post. :D
Thanks OH. I'd have the thing myself but I already have a stereo scope, and the first time my wife saw the big stand she would no doubt string me up from it!
Wow, very nice. Can you connect it to your monitor?
I have purchased a 5mp eyepiece camera. Will arrive in a few weeks. Then I get video and pictures. If I bought the microscope with the camera installed, I would not get the X70 optical zoom, only X45
Why a stereo microscope is recommended instead of a single lens one? As opposed to the traditional loupe recommended in lieu of a stereo visor?
Does anyone know of an especially small and lightweight model?
Edited by jdm
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
