Watch of Today
mk3
Wearing a simple Sandoz today, basic day only powered by an ETA2824. I got this cheap off the bay for less than the price of a new balance wheel and figured I'd use it for parts but its been running well and it seems a shame to break it down. It has its original crown and bracelet which tapers to a tiny 12MMS at the clasp.
I haven't done anything to it and it's been keeping time accurately for the last 3-4 years. Only issue is the movement is a bit loose in the case but I have a cunning dodge to fix this.
It's interesting in the sense that you can see a lot of Rolex in the basic design, even the tapering bracelet is kind of a Rolex thing. I believe this was cased in Hong Kong or made for the HK market where Rolex are popular...a wannabe so to speak.
Original crown
Signed bracelet..
Have a nice day!
Anilv
Got my Huntana on today
It's been getting quite a lot of wrist time lately. At 34mm diameter and just 8mm thick it is just such a comfortable watch. The thin bezel makes it wear bigger than it is and the design and layout is so easy to read.
It has a Unitas 6325 inside which is a lovely movement. A nice easy size to work on, simple, bullet proof, consistent, and reliable.
This particular one is also the loudest ticker I have.
@Cad101 that's a very nice Helvetia indeed. I love that huge sub-dial and as you say, the movement is very obviously UT 63xx based, albeit with a slightly different jewel configuration to my 6325.
Edited by Marc
capitalisation
10 hours ago, ricardopalamino said:
Today I'm going with a vintage Seiko Sportsman Seahorse I haven't worn for a while ..
louis - you don't see too many of them (seiko) in that combo - stainless case and gold finished dial. i love that look.
i am totally unfamiliar with a huntana, but i love it!! very sweet looking. that is a perfect dress watch.
if you ever felt the need to part with it, look here first. it's a beauty.
6 hours ago, Cad101 said:
Well @Marc I've had something similar on for the past week. The movements are very similar I know the H65 and H66 were the Unitas 6310 but the H64 is very similar indeed.20170215_194937.thumb.jpg.e762461c27016b0cdd4392badc0be393.jpg20170215_195633.thumb.jpg.0bad32a658dba5ec6c4b6cbc4bdb5396.jpg
every helvetia i've seen has been a great looking watch. this is no exception. that is very nice.
Been wearing this for the last 18 hours since I finally adjusted the donor hairspring into some kind of shape its lost about a minute in those 18 hours. I will get it back on the timergraph I may be able to tweak it a bit more.20170219_154543.thumb.jpg.1acdcea47a6641abe40a66ed991e9fdc.jpg
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
