Elma Watch Cleaning Machine
Thanks for the information Rafal, I have sent an e-mail to Elma and await their response. I have been running it off and on today and it's the motor that moves the big gear wheel that is smoking, ( if it's faulty and burns out so be it) When you find the time can you run through the sequence of your machine please, do you operate it all manually by pressing the start button to each phase. I have been taking notes on mine.1 main switch ON press start it goes down to the  first jar and spins for 2 minutes clockwise the 2 minutes anticlockwise it then raises and spins excess off.2 moves to next stage and repeats the operation on the second jar,after this it raises and stops.So my machine is only doing 2 stages instead of 4. Does your timer reset itself? mine times out and that's it but i looked at one on You Tube and noticed that the guy sets the time and after each stage it automatically goes back to what he set it at.Your thoughts would be appreciated. Regards atkinson.
Machine goes on all 4 steps automaticaly, there  is no need for manual overide (perfect condition :) ). Regarding timer - its only for first step - washing in watch cleaning solutions, next 2 steps are just for flushing cleaning solution and repeling water (as elma solution is water based). Timer only extends time for washing, in fact it stops another small engine which is timing whole process - when you remove cover and use timer you will notice when this thing stop moving. Timer is simple device which is wired in a way that it brakes circut when time is set, when it reach zero, circut is connected back.
Before you burn motor which turns big wheel - please check lubrication as it require maintenance every 3 months according to elmas manual (I suppuse if you are professional watchamker and clean many watches...), thats include wheels, pilar and clutch (not sure if that is proper name for this knee like connection) - to big wheel is mounted rod for lifting bucket. step 2 and 3 take same time to finish, so when it stops on 3rd something mighte be also broken or blocking - all intervals when bucket spins are mechanically switched on and off by bronze disks with tooths. Also lower table where jars sit could have some issue with turning, when it start smoking it seems it has not enough power to move.
If you have picture of inside it would help to spot any difference from my machine. I dont know if my description will help you or get it worst :).
Rafal .Thanks again for the information most informative, i am posting some pictures for you to study, when i removed the cover the red wire on the right of the terminal block on top of the transformer ( 1st picture) was not connected, i have put it into the last connection on the right is this the same as yours? Regards atkinson.
Rafal, I have been observing the machine again this afternoon and i believe i now know what the problem may be, it would seem that although the small motor next to the transformer is spinning forwards and backwards the gears do not move at all, consequently the cams do not move.When you have time can you let me know at what stage the gears/cams move and is the red wire in the terminal block in the correct position? Thanks atkinson.
Im sorry for late response, but I just got back home. At first glance your machine looks like re-wired or upgraded version, connector to transformer doesnt match mine setup. Also yours have 2 starting resistors where mine has only one (big green resistors which sliding part - it gives a kind of soft start for motors).
Small motor next to transformer is a sync motor, it rotates with certain speed to measure time (when you use timer it will stop, to spin bucket for longer time), on same axis you have those disks with tooth's which move end switches on and off  -  one is connected to relay switch which is responsible for changing direction on which bucket spins, second end switch moves procedure forward -  next stage/jar.
Thank you Rafal for your reply, i managed to realign the gears on the sync motor last night and the cams go backwards and forwards now, i still however find that the machine does not start on the first jar and end on the heater stage, can you Rafal when you find time to post a photo please of the position of the cams on the first stage before starting the machine, Thank you,Atkinson
Hi Atkinson,
I finally manage to take pictures for you:
2 end switches on left hand side are in ON position, ones form right hand side - first is in ON position and 2nd is in OFF state. Machine just stopped and red light is on, so it possible to lift bucket a bit without starting new cycle (easier to remove bucket). And close up picture:
second set close up:
Edited by Rafal
Thanks once again Rafal for your message, i am posting some pictures taken this morning of the machine after the heater stage, i have now got the machine to complete a full cycle up to this stage but unfortunately i now find that the heater is not switching on, just wondering if perhaps the cams are out of sync or the worst possible outcome that the heater is kaput.The total cycle time from switch on to the end of the heater stage is approximately 18minutes.
Well i have finally got everything working, the heater you are probably aware is connected by two sets of fixed contacts so the stage before the main  heater stage brings the heater on to gently warm up before the main heater stage, when i was testing the machine one of the knucle joints came off and the top of the machine came down heavily onto the heater tube causing the roller cams to be out of alignment, once realigned contact is now made on both stages of the heater. I have run the machine for eight cycles and it seems fine so my next trial after i have replaced one of the knucles will be with fluids.Thanks Again for your help. Atkinson.
I have been following this post with great interest as I have (until this post) never come across this style of cleaner. What intrigues me is why it has a heater. I have a L&R which has three pots & also ultrasonic cleans as well as cleaning. Just wondering what cleaning solution will work with heat.
Hi clockboy.Most if not all european watch cleaning machines ( i have four different ones) and they all  have a final stage of heating the contents of the basket to dry them. You have the following stages, 1st clean, 2nd rinse,3rd final rinse, 4th drying.To my knowledge all watch cleaning chemicals will work with these machine, i personally use L&R and Horoclene. Regards atkinson. P.S if you want pictures of any of them just let me know.
  • 4 weeks later...
Hello Alvis, I recently did exactly the same as you and I finished up with a great machine fully refurbished.
Sadly I didn't take any photos but did follow SSTEEL's posts for guidance.
I did find the manual for the cleaner. I think it is the same one but there may be some differences. If you would like a copy I can send it in pdf. format to you. Also if you need any help then just contact me and I will try to do so.
Best wishes, Mike
Thank you Mike, I appreciate it. I will ask if I have any questions.
I have found a manual for this as well. Would be interesting to see if it is the same.
Most of the parts are cleaned now, so the next step is trying to get the motor to run. I really hope the bearings are okay, and that a clean and new grease will sort everything out.
This looks like asbestos, could be dangerous by inhaling invisibly small fibers.
You can replace it with a silicone plate, or make it yourself from heat-resistant liquid silicone gasket for cars.
Oh cr@p..
I have been handling this without any precautions at all.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
    • one of the problems we have is visible versus invisible. For instance millennium disulfide another high pressure lubricant black in color. I was told by somebody worked for the Boeing company that they had a piston like device somewhere that has eight call it around it to grab it so it has to slide and in the collet has to grab. But if somebody puts that type of dry grease on where grease with that in it it embeds itself basically in the metal and they have to throw the whole part away they get use it all. So I suspect on all the dry powdery lubricants that they will go into all the basically microscopic cracks and crannies of the metaland that's where it is visually at least until you scrub it off your visually going to see it which is good because you want your lubrication the stay word is. But I'm sure it doesn't last forever on the metal it's just a really nice lubrication
    • Thanks for the info. I can't seem to find tech sheets for those either.  I'll muddle my way though 🙂
    • Ohh spooky I have just aquired the same one mike, but mine has a drill bit inside it.
