Elma Watch Cleaning Machine
2 hours ago, Mark said:
That one doesn't have the transducer - but very true what you said.
I had two varimatics with the ultrasonic units but I prefer my elma super elite - it's manual but never have a problem with it, plus I get to keep the watch in the jars for much longer should I want to.
Sorry, I thought all the "vari matic" ones had ultrasonic and the none ultrasonic ones were called "watch matic" or something else.
I looked at buying one a couple of weeks ago and rang this company below about getting the ultrasonics repaired, he has a fully updated refurbished one for sale at £2200, he quoted me the £1600 to refurb one.
http://www.delphelectronics.co.uk/pre-owned-machines.htm
That's Graham Baxter - he's a very good chap. His workshop is just down the road from me.
The L&R shown in the OP definitely does not have a transducer (Big metal cylinder where the basket will be attached). But it can be converted to ultrasonic with the addition of a unit which sits under the main machine, and the transducer which is fitted to the head.
That's right Mark.
Yeah, that's him Grayham Baxter, he really knows his stuff, I was talking to him for ages on the phone. He was really helpful.
  • 8 months later...
That was my point the R90 is now obsolete and was been replaced by the "Elmasolve RM" which retails at £3k +.
You have got to do lots and lots of repairs to get any sort of return for that sort of outlay.  If you can find a pre-owned one and source replacement parts then it might be a viable option. However if my info is correct they are also not as efficient as the the old L & R machines.
On 28/1/2017 at 10:04 PM, Peterburke340 said:
I know they don't come up very often but am looking to buy an Elma RM90 watch cleaning machine if anyone has one or knows of one for sale. I am uk based.
Thanks
Elma RM90 is on my wish list as well. Some of these machines have problems with the wire to the motor. You may be lucky and find one and maybe you can fix it ... It's such a machine with this mistake im looking for!
RM 90 19$ repair >>>
More about this problem >>>
I've occasionally seen this elma at online auctions, I have seen them there at very fair price
An old auction >>>
Another old auction >>>
I hope you get one some day... good luck
20 minutes ago, teegee said:
Interesting machine!
L&R vari-matics seem impossible to obtain these days, unless you don't mind paying USD 2k..
Expensive yes but one hell of a cleaning machine and all automatic, you can set the timing for each jar for how long you want it to be in the cleaning jar and for both rinse jars and heater and spin off. There is even a part which enables you to clean many watches at the same time. I used a few machines in my days and this one is certainly the tops.
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
    • I overhauled a ladies Rolex and noticed erratic performance so I stripped in down again and did fault finding. This is what I saw. The lower jewel (the one in the plate) is cracked and the hole is too big. Before discovering this, I stripped down and re-cleaned the main-plate (and parts) by hand with a fine natural fiber brush. I somehow missed the fault the first time and cannot understand how it was still running. Perhaps re-cleaning it dislodged some pieces of the jewel widening the hole? I don't know. Now I need to replace the jewel but don't have a Seitz tool. The Rolex part is 2130-0913 and the top and bottom are the same. The part comes complete in brass setting with KIF elastor spring and cap jewel. Note: I have never replaced a jewel. I do have a good vintage stacking set that I've used quite a bit.  Can I replace using a stacking set? Any suggestions would be greatly appreciated.
