Dial (face) cleaning?
A dial from a Bulle clock (model XC) looks dirty. Varnish remover does not help. Sanding and  resilvering is not possible because the letters are not engraved.
Please help, thanks, Kraai
Edited by Kraai
Without messing it up you will only be able to clean it up by about 25% or so... Even that can be a tad risky, especially with the indexes, writing, numerals, etc.
It looks good as it is if you ask me. It has personality and patina. Not gonna be able to make it look brand new.
I would say that your only bet is to lightly tap the dial with some cleaning substance and some cotton and that's about it. If it'll remove some of the dirt then that'd be good enough.
Y'all,
Just purchased a 90 year old watch. It still runs. The only issue the dial face has some patina (read dirt), oxidation and minor paint loss. Can you provide me recommendations for:
1. Removing the dirt.
2. Dealing with the oxidation.
3. Replacing the lost paint.
The dial face appears to be paint on metal.
Thank you,
MikeCJ
Hi all,
I’ve recently got my hands on a Seiko divers watch which needs a little work. When I first got the watch I noticed what I thought was a fingerprint in the underside of the glass, however on removing the movement I noticed the mark was actually a shiny part of the dial rather than the matt finish.0dcebd3bf356e16fb8c90f3e51e85c9b.jpg
I’ve tried cleaning/lifting with Rodico and some solvent cleaner without any joy.
Does anyone know if there is any way to restore the Matt finish? I don’t really want to buy another dial as I prefer it to be original to the watch.
Thanks in advance
Carl
You know if you wanted to experiment? You could try some degreaser or light soap and then gently touch it with your finger, then rinse/dry.
Yes there is a risk the dial will be destroyed, but there is a chance it will remove the oil stain if that is indeed what it is.
I did ruin a dial that had battery acid damage by washing it - but it was still usable its just that the awesome patina from the acid was washed away with water.
You could try to take a picture of it and edit (removing the dirt and to make it 1 to 1) it in GIMP for example then you could use the same technique what Mark used in his video:
 I am not sure how difficult it would be to find a spare dial to use that for the experiment and not the original one. I also like the original as it is.
GIMP is an image transformation tool with very poor technical drawing features. One needs Illustrator, or Inkscape to work on dial blueprints.
I've used Gimp quite a lot for flat dials, just scan the original and edit out the defects, the beauty of this you can lay the new dial over the top of the old, so if in the future you decide you want a dial restorer to work on it you have preserved it for future restoration.
You can print on off white paper or card to make the dial look aged.IMG_20190613_0002.thumb.jpg.5c53cdbaba9a4b407a94892b6dde0966.jpg1300016454_clockdial.thumb.jpg.11226ab0a0458e9e042a24b15be8e406.jpg
Hi  K  If its not a full on restoration I should give it a wipe over with mild soap and water then leave as is It got like that through the life it lead and is therefore the character of the clock.  I personally like to leave things alone as long as its not detremental to the operation of the clock, we all pick up a few cuts and bruises through life.
Also got me thinking, you may recall I wanted to get an Epee dial restored, but to expensive, I love what Mark did in his video, I was wondering if I could do the same, does it have to be printed with laser printer? or would normal printing be OK on the special paper??
Thanks Len
I've used all sorts of paper a high gloss photo paper printed on a inkjet does a good job of looking like an enamel dial. I use a canon inkjet there is a setting on it that puts more ink onto the paper for the blacks, Epson heavy weight matte paper is fantastic for  non glossy printed dials it has a very fine surface finish to the paper.
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
    • one of the problems we have is visible versus invisible. For instance millennium disulfide another high pressure lubricant black in color. I was told by somebody worked for the Boeing company that they had a piston like device somewhere that has eight call it around it to grab it so it has to slide and in the collet has to grab. But if somebody puts that type of dry grease on where grease with that in it it embeds itself basically in the metal and they have to throw the whole part away they get use it all. So I suspect on all the dry powdery lubricants that they will go into all the basically microscopic cracks and crannies of the metaland that's where it is visually at least until you scrub it off your visually going to see it which is good because you want your lubrication the stay word is. But I'm sure it doesn't last forever on the metal it's just a really nice lubrication
    • Thanks for the info. I can't seem to find tech sheets for those either.  I'll muddle my way though 🙂
