Best movements for practice?
By transporter · Posted
its used to lengthen or shorten the suspension spring from the front f the clock dial, this in turn will give regulation to the clock. Try inserting a pocket watch key or even better the double ended key for the clock into the small aperture on the dial at the top and turning it, you will see the suspension block either raise or lower. If it raises the clock will run faster if it lowers the clock will run slower -
Grateful for info regarding the nature & function of the horizontal cog and the unit it's on top of in the picture. It meshes with a vertical cog (enclosed in the unit) on the arbour which is supported at its other end by the back plate of the dial unit to which it is not quite perpendicular...
Hello good watch folk ,I just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are we thinking its reaching a peak volume ? Younger generations clearing out passed parents and grandparents possessions. The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ? i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ? -
Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs, the ticktock is phenomenal, i can hear it across my living room . You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk. I expect some did well when they embraced the use of synthetic, probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
