Chinese Timegraphers
1 minute ago, Kanie said:
And would that be true on all timegrapher results on all movements read?
Yes, on this timegrapher. In the main menu change the accuracy from 999 sec/day to 99 sec/day and you'll understand better. Only set it to 999 sec/day if the movement is wildly out in respect of the rate; so, gaining or losing more than 100 sec/day otherwise the timegrapher won't be able to give you a reading
As I said, if you set the display in the main menu to display the reading every 2 seconds then your main display will display the accurate reading every 2 seconds than every 40 seconds and really, not displaying an accurate figure, because the rate has changed before the 40 seconds has elapsed, so the timegrapher reads an average
On 8/22/2021 at 12:47 AM, Jon said:
Although your main readout says zero seconds a day, probably because in the main menu you have it set to 999 sec/day instead of a more accurate 99 sec/day, those small numbers are telling you that the movement is losing one second per day. In the main menu you can change how often those smaller numbers are displayed, such as every 2 seconds, 4 sec, 10, 20, and so on. I like to set mine to have a readout every 2 seconds, but that is just my preference.
Once you set the main menu to 99 sec/day, the main display that currently say zero sec/day will then become more accurate and reflect those numbers that say -1 sec/day, because at present it is not giving a reading other than a whole number and you want to see 0.1 sec/day (as an example) rather than rounding it to the nearest whole number which would be zero.
I have the same as model as pictured (Weishi 1000), my menu doesn't have this option discussed to change the display refresh rate as these instructions are inferring. Am confused lol.
the problem with this suggestion is it only works for the 1900. It is not a feature of the 1000.
On 8/21/2021 at 7:34 AM, Kanie said:
Hey,guys…Recently bought a Weishi timegrapher and would like to know what the smaller numbers mean that are under the main readout numbers..have searched the net but no luck…thanks in advance.
just so everyone understands what were talking about I snipped out an image from your question and circle the numbers I assume these are the numbers are asking about?
I have a theory about the numbers we can try an experiment. Go into the menu screen go down to the menu item which says test period which usually by default is four seconds change it to eight seconds and see if the numbers change their spacing on the screen.
Thanks John, I never realised the 1000 model was that limiting with the timing display. Another feature the 1000 doesn't have is different coloured traces for the tic and toc. I always advise people to spend a few quid more on the 1900
I think I could add this feature to tg.  What would be the most useful way to generate the average?
I was thinking a simple moving average of the last X seconds of data points.  For example a 10 Hz movement and 5 seconds period, one would take how many s/d off each of the last 50 beats was and average it.  Or, another way to think of that, is you find the actual time between two beats 50 beats apart and divide that by 5 seconds.  Mathematically, both of those will find the same value.
But one could also use an exponential moving average, which would have the effect of weighting the most recent part of the averaging interval move than the least recent part.
18 minutes ago, LittleWatchShop said:
C8051F360
I'm pretty sure if you look somewhere in the discussion group we have a picture of the inside of the machine. Then thanks for pointing out that this isn't an ordinary 8051 I just thought it was ordinary nothing special. Roffealizing that I didn't grasp the 8051 could be enhanced looking at the 1000 machine it's the same chip. then the reason I know that the pictures exist on the group somewhere I photographed both machines.
What makes both machines interesting is a incredible degree of similarity to the point where they were both made by the same company. Very likely designed by the exact same person with the programming being very very similar.
Then isn't it amazing what you can find out there if you look? Somewhere somebody even did a schematic for the microphone minus all the values for the capacitors because of course are surfacemount.
then for those that don't know what enhanced 8051 is snipped out an image. But don't get too excited is no longer in stock in the US for sale as it's obsolete.
  • 5 months later...
17 hours ago, jdm said:
What they were thinking?
Before I file it down, i'm wondering why the plastic jaw is shaped to project into space or floor a mov.t placed on its top. Maybe there is a reason just can't fathom.
Yes. Please file it down. And make the offset even deeper. I had an accident while using using my unmodified timegrapher. The jaws slipped while I was regulating the movement and it knocked off 2 dial indices and mangled the logo.
While i still wonder if there's a debug serial port exposed somewhere that might dump cooked data, I'm strongly considering tapping the audio signal that comes in from the mic and connecting it to a 3.5mm jack hacked into the back of the nr. 1000. So i can use a program on my computer to monitor performance over an extended period.
  • Mark unpinned this topic
  • Mark pinned, unpinned and featured this topic
  • 4 months later...
30 minutes ago, mikepilk said:
Just what I've been waiting for. Can you report back when you have some more experience with it, and the software ?
I use one of those microphones and Watch-o-Scope software, and have been very impressed with both.
The microphone does exactly what it's supposed to. You can put it on its sides to get all 6 positions. I use my casing cushion to isolate it from the wood desk, but if you're less lazy you can put rubber feetsies on it.
Watch-o-Scope is super versatile, and the free version is completely functional. The paid version is just nice-to-haves, IMO.
You can calibrate it to your specific setup using a quartz watch (mine needed a 1.5 second/day adjustment), and every parameter is completely variable, which came in handy when I had a watch that ran at 21,306 BPH.
I also really like the fact that you can see the raw waveform of what the microphone is hearing in real time.
36 minutes ago, Kalanag said:
My version is not a 3D printed „prototype“ anymore but industrially injection moulded.
The software Tg is well known and works perfectly: download page
There are cell phone apps as well!
Interesting.  It digitizes the signal and sends it over USB.  This is in contrast to the other solutions talked about around here where the signal goes into the audio port.  Cute
  • Similar Content
    • Post some pictures , some good close ones of the parts you've described.
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. If its a potential problem for amateurs to use then i would prefer not to take the risk .
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
