Elma Watch Cleaning Machine
2 hours ago, Mark said:
That one doesn't have the transducer - but very true what you said.
I had two varimatics with the ultrasonic units but I prefer my elma super elite - it's manual but never have a problem with it, plus I get to keep the watch in the jars for much longer should I want to.
Sorry, I thought all the "vari matic" ones had ultrasonic and the none ultrasonic ones were called "watch matic" or something else.
I looked at buying one a couple of weeks ago and rang this company below about getting the ultrasonics repaired, he has a fully updated refurbished one for sale at £2200, he quoted me the £1600 to refurb one.
http://www.delphelectronics.co.uk/pre-owned-machines.htm
That's Graham Baxter - he's a very good chap. His workshop is just down the road from me.
The L&R shown in the OP definitely does not have a transducer (Big metal cylinder where the basket will be attached). But it can be converted to ultrasonic with the addition of a unit which sits under the main machine, and the transducer which is fitted to the head.
That's right Mark.
Yeah, that's him Grayham Baxter, he really knows his stuff, I was talking to him for ages on the phone. He was really helpful.
  • 8 months later...
That was my point the R90 is now obsolete and was been replaced by the "Elmasolve RM" which retails at £3k +.
You have got to do lots and lots of repairs to get any sort of return for that sort of outlay.  If you can find a pre-owned one and source replacement parts then it might be a viable option. However if my info is correct they are also not as efficient as the the old L & R machines.
On 28/1/2017 at 10:04 PM, Peterburke340 said:
I know they don't come up very often but am looking to buy an Elma RM90 watch cleaning machine if anyone has one or knows of one for sale. I am uk based.
Thanks
Elma RM90 is on my wish list as well. Some of these machines have problems with the wire to the motor. You may be lucky and find one and maybe you can fix it ... It's such a machine with this mistake im looking for!
RM 90 19$ repair >>>
More about this problem >>>
I've occasionally seen this elma at online auctions, I have seen them there at very fair price
An old auction >>>
Another old auction >>>
I hope you get one some day... good luck
20 minutes ago, teegee said:
Interesting machine!
L&R vari-matics seem impossible to obtain these days, unless you don't mind paying USD 2k..
Expensive yes but one hell of a cleaning machine and all automatic, you can set the timing for each jar for how long you want it to be in the cleaning jar and for both rinse jars and heater and spin off. There is even a part which enables you to clean many watches at the same time. I used a few machines in my days and this one is certainly the tops.
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 at 20° C) than 9504 (305 at 20°). The viscosity of Molykote DX is 285-315 at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease.
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro. I thought the idea was for the epilame to create a barrier, a wall between the lubrication and anything else, so the lube cant spread.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
