Completed project watch
Hello fellow watch lovers, I have just completed a build from part sourced from various sellers. It turned out to be the best build for me yet and I have 20200515_234824.thumb.jpg.5a1f8974dc75d6bbfaf0883500906b5d.jpg20200516_002855.thumb.jpg.a7dff742bc011aa2ae29e1930a9c722a.jpg20200515_230958.thumb.jpg.5b4a2db673437c4ac5f2257022d8cc7c.jpg20200515_231021.thumb.jpg.cc984a60524ca30223d95ef9ec48c65f.jpg20200516_002734.thumb.jpg.1bfcec482231023448dab44ebd6dc109.jpg20200516_002831.thumb.jpg.43831cb8e5f8fdf769aa46ead7ec9536.jpgreally amazed myself and the skills I had to exercise on this timepiece.  I have impressed myself with this one and it is a stunner with a salmon dial. The NATO strap is very lovely on this timepiece.  I apologize for the lack of details on this beauty, Enjoy
  • Like 7
You done very good a good looking watch for sure, you can be proud.
Is it based on a Landeron 48 or similar?
PS. Just a tip. the chronograph hand should just reach the outer perimeter of the seconds , now its just a tad to long ;)
I fabricated the second hand because they are impossible to find. I cut it down and bent the tip like the vintage hands a little to miss the crystal. No Landeron movement in this one. The dial and movement and hands did not fit so I had to make them fit.
I just searched ebay everyday until the parts were available. This type of dial is very difficult to find. I started with a case then I found the dial that fit that case and then find a movement that will fit the case. If it doesnt fiT then just make it fit. Saw, grind, file, paint, whatever u need to do to make it fit.
What movement did you use? Is it a true chronograph? Is it mechanical or quartz?
  • 3 months later...
  • 2 months later...
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
    • I think attaching a nut to the lid to pull it off is the least destructive, any damage damage on the outside is going to an easier fix than any created when trying to push it out from the inside. Scratching up the inside of the lid , mainspring or arbor bearing will be risk. Just my opinion.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
