New member from Sweden
CMW
I have always been interested in watches, but it is only the last year that I have tried to learn about the technical parts of the watches, how to service and repair.
Regards
C-MW
Welcome to the forum.
The hairspring you show، needs a bit  of sorting out, coils should be evenly spaced out, concentric, flat and level. Bring the collet to center so the jewel hole is in its center, end curve should be concentric with the rest of the coils and such that moving the regulator arm dose not push the coil to a side. Mark Lovic teaches the entire task in one of his videos.
Good luck
  • 7 months later...
On 5/14/2020 at 6:15 PM, rogart63 said:
Check Per Torphammar page out for translating from English to Swedish . If you haven't seen it already?
@rogart63 I've got his book (my brother gave it to me). I've Googled his name, "English" and "Swedish" but nothing came up. Not sure what you're referring to but perhaps translating the names of watch parts? In that case I'm especially interested. Can you please provide some additional info and/or link? Thanks!
Perhaps this page?
https://www.facebook.com/AmateurWatchmaking/posts/hi-watchfriendsfinaly-i-have-totally-remade-my-hompage-you-are-most-welcome-with/2083826425001416/
http://watchmaking.se/BOOK/Shop/shop.htm
This page. http://watchmaking.se/
You have a good page there which translate from English to Swedish . Maybe wasn't that easy to find. As Per Torphammar name isn't on that page. Only the mailaddress.
Found it, thanks!
Entertaining (and useful) to read the Swedish names of the parts more or less for the first time even though @HSL has taught me a lot of them (Thanks!). The names seem to have more in common with German than with English, but that doesn't come as a surprise, I suppose.
I think reading technical sheets is a good way to learn the parts names in Swedish, I still enjoy reading for example the Omega tech sheets from the past since they are so well illustrated and have nice explanations of the functionality and the complications.
I attach one here for the Swedish audience, well the pictures are universal.
At the same time I wish you all a Happy New Year!
Omega 711.pdf
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
    • I overhauled a ladies Rolex and noticed erratic performance so I stripped in down again and did fault finding. This is what I saw. The lower jewel (the one in the plate) is cracked and the hole is too big. Before discovering this, I stripped down and re-cleaned the main-plate (and parts) by hand with a fine natural fiber brush. I somehow missed the fault the first time and cannot understand how it was still running. Perhaps re-cleaning it dislodged some pieces of the jewel widening the hole? I don't know. Now I need to replace the jewel but don't have a Seitz tool. The Rolex part is 2130-0913 and the top and bottom are the same. The part comes complete in brass setting with KIF elastor spring and cap jewel. Note: I have never replaced a jewel. I do have a good vintage stacking set that I've used quite a bit.  Can I replace using a stacking set? Any suggestions would be greatly appreciated.
