Thanks oldhippy, this is my "Jack the Gripper" in the photo - can I use this shape of "fingers" for real glass as well? When tightened too much, it grips so hard that it punches holes into the side of plastic crystals :)
Can I use this tool for domed real glasses?
PS Yes, I have a useless chinese as well, it has lasted for 10 watches, now every crystal slips out of the fingers.
Edited by rappeleur
If it punches holes in the glass I don’t think you should use it. For fitting you need the platform it makes it so easy for the tool to get the correct depth when picking up.
So... There is no way putting my glasses with my tool into place. The mounting device is too high, the glass doesn't stand high enough for gripping.
But even when picked up from a flat surface, the tool always slips from the glass. The glass has a tilted border (see photos).
Wrong tool / wrong glass /wrong technique?
Think there is a misunderstanding of the tool required here. Firstly "Mark has done some great video's on the removal and fitting of various crystals. Suggest you look them up on YouTube.
It's inappropriate to use an arcrylic crystal lifter on mineral or sapphire crystals.
Why have you only flat dyes ? Even inexpensive case and glass press tools come with a selection of dyes, including concave dyes suitable for domed crystals. The problem today will be obtaining jumbo dyes for the modern larger watch but they do come up for sale on various sites.
Sent from my SM-T585 using Tapatalk
Yes, this was just what I was thinking! I only have flat dies because I have not bought a better set yet :) hence my question, which one to buy. Perhaps I misinterpreted the above suggestions for my crystal-tool.
I will have a deeper look into techniques and dies/tools.
Thanks so far!
old hippy is right, but for clarification high dome acrylics = crystal lift, low domes = press, but the method is different from pressing a mineral/sapphire/tension ring, with a low dome acrylic you basically have to use the dies to make the crystal curl in on itself slightly, then slip the case/bezel into position and then release the pressure so that it locks in place to the bezel/case. It's probably been properly demonstrated or explained somewhere around the forum before, but i could just imagine someone trying to puzzle that out from scratch.
I'm a very new beginner hobbyist.  Would this low cost Chinese tool work for removing/installing crystals and pressing on case backs?  Anyone have one?
Thank you
I would say buy the blue one that actually has the shape of a press. This one can work but if you press too much, since it's a cheap one, it'll break and you might just break your watch as well.
Stick to the blue ones that cost 15$ or whatever... They're not as good as the original ones in that you might get one that is slightly misaligned (from what I could read in some comment) but it'll be better than this one.
i do not recommend this type because the force is not between pillars and it will lose plane under medium pressure. If you want a screw type make sure that isn't so.
I purchase a cheap one ...It did work fine the one time I used it ..I'll enclosed a picture at bottom ...Which one would be a recommend unit if not the one I already have.
That is fine because the cast construction is not subject to distortion, and being of the lever type it allows better feeling.
Often what makes the difference is having the correct dies in terms of shape, size and material.
Thanks...there is one thing I don't like..depending on the watch if I screw the dies all the way in the dies do not reach ..I put a nut and washer on to extend reach but haven't tried it yet
Sent from my SM-G955U1 using Tapatalk
  • 2 months later...
This is one type I had. https://www.cousinsuk.com/category/press-dies-robur   expensive used for fitting tension ring glasses
As near as I can find of another type I had for tension ring and flat
This very good glass lift and fitting tool for high dome glasses
Beware of cheap Chinese types. You know they won’t last because of the price. Good tools will last you a lifetime.
We have a lot of people here using hand held and bench Chinese presses. No reports of breakage or other problems, generally these are great for beginners. Isn't always necessary to spend a lot on tools. I have an Anchor copy of MKS screw type, works good and has a sturdy build, link is a previous posting in this thread.
For the ease of finding info I have merged various threads in a pinned topic.
Some generic postings moved to another thread. Please stay on topic: Crystal press advice
  • jdm pinned this topic
  • 4 months later...
Has anyone ever used a case press like this one:
https://www.ebay.com/itm/GF8721-Snap-Back-Watch-Back-Case-Press-Spiral-Type-Closer-Tool/142877470395?hash=item2144292ebb:g:EwkAAOSwczhbU1CG
It looks reals sturdy from the pictures, but i would like to get someone's first hand experience.
  • 8 months later...
My experience with the cheap Chinese crystal presses is very poor. I ended up buying a Bergeon No 5500 and I'm remarkably satisfied with it. I recorded a video of the very first time I used it and you can see it via this post.
36 minutes ago, DavidMasters said:
I have the following one at link, or it's similar—lots of knock-offs from China. It beats spending hundreds if this is a hobby like it is for me.
This is a cheap alternative that works very well.
I don't recommend that one, because the pressing force is not in between the pillars, so it tends to flex. Better to have cast strong body as others that were featured before.
Bergeon or other guality crystal lift do not scratch ths crystal.
