Loupe / eyeglass / eyepiece
By TattooSamuel · Posted
Thank you everyone, I have located and bought a part, I appreciate all the replies and have really enjoyed the process…… I’ll let you know which parts I break during re-assembly and we can do it all again 😂😂😂 -
BOUGHT! SOLD! PURCHASED! Un-real, with everyone’s help and information not only did I get a chance to see how powerful a forum could be but I’ve learnt ALOT about movements share/swap uses/information which has resulted in finding and buying the part! Thank you very much mate -
I also use autosol rich, cases definitely, as with all polishes it does abrade surfaces. At x10 🤔 fairly noticable Polinum and Polinoxx are the finest finish I've come across up to now, brilliant stuff -
By rjenkinsgb · Posted
Some parts listing cross reference to a Zodiac 68 (and others); from photos that part is apparently the "minute train bridge". Cousins have them in stock! https://www.cousinsuk.com/sku/details/zodiac-movement-parts/zod70462 Cross referencing again, this is a Zodiac 70 462 on ebay (at twice the price) & the photo appears to match your part: https://www.ebay.co.uk/itm/234176330083 -
By Terrinecold · Posted
@caseback indeed. I'll check the exact dimension tonight. I did find this https://www.amazon.com/Moody-58-0161-8-Piece-Metric-Wrench/dp/B003HGHU9I/ref=sr_1_1?crid=12RW2VFWH854D&dib=eyJ2IjoiMSJ9.vzl7Co7oEUunyeCWTks5tyYb0yJ9mH2s3hQAtN7UMQXGjHj071QN20LucGBJIEps.FaOnyG9Gm2rjwd8I5Z1D-vb03j00YbWhzSHV4hgDHUI&dib_tag=se&keywords=Moody+58-0161&qid=1717445510&sprefix=moody+58-0161%2Caps%2C106&sr=8-1 It is fairly cheap but only about 25% cheaper than a new 6T15 movement so worth it only if I will use it more than this once. Has there been other cases where you had to use a wrench inside a watch movement?
