Watch of Today
mk3
Today its a comfy Seiko Sportsmatic that someone in the far distant past had scrubbed the dial clean. I gave it a polish and a varnish after servicing it but I would really like to find a new dial . I look on the net almost everyday for one but alas have yet to spot one so if any of you kind people spot one let me know thanks.IMG_0362[1].JPGIMG_0422[1].JPG
I always think about who owned it, where it traveled, how long it was used before it was discarded, etc.  Would be awesome to be able to find out the past life of some watches!  Thanks for the compliment. I will also keep my eye out for Seiko Sportsmatic dials during my searches.
Edited by jeffc83
@12toneman Like your radio room. There are a lot of memories for me regards Radio-rooms. When I saw the first Amphibian, it had a RR-dial and I had to have one....... the start of the Amphibius-virus :)  Your dial however is much nicer than my modern RR-dial and you have a date window! Wish I had that one !!
@bobm12 Finally arrived !! Congratulations :thumbsu: Now the fun really starts !! Tip No#1: Get a bigger back-door or build a special post-extension to the "you know whom" house :D
Thanks, Endeavor. I definitely share your affinity for the Radio Room. It took me a while to find that one, with the off center anchor and date--from a vendor with a website only in Russian and prices in rubles. I changed the hands the other day because the original ones were hard to read against the white background and red second hand got lost in the red sections of the dial.
In keeping with the whole Russian theme my old beaten up vostok Paratrooper looks like it went to syberia and back but keeps excellent time about 3 seconds a day in all positions you cant argue with that .20160611_153054.jpg
My late uncle was wearing this watch when his army patrol was attacked in Ireland in the early 70s.
The strap broke and it rolled around in the bottom of the personnel carrier, it was recovered eventually but didn't work any longer.
I was given it to look at, and after a little tlc it is running again...next step glass and then a strap...then it goes to my cousin.
video-1456875143.mp4
Wearing a Tissot hand-wind today...powered by a cal 27-2. Most of the Tissots from the 50s were in base metal cases, this one is in stainless steel. Dial is in pretty good shape as well, hand could be better.. :(
Today I'm wearing this recent bay purchase a bit of a mess when bought and now in running order a 1912 size 0 class 320 7 jewel ELGIN. Serial No 16397025 for those interested.
I will be doing a service walkthrough on this in the near future so look out for it.IMG_0444[1].JPG
Yeah! I love to hear stuff like this....and the watch is super nice (sub-seconds) too!
JC
Thanks. Seems to be keeping decent time so far.
8 hours on my wrist yesterday and again today plus dial up overnight and it looks like it has only lost around 30secs.
Bought a "matching" accessory today [emoji4]
Nice!
JC
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
    • one of the problems we have is visible versus invisible. For instance millennium disulfide another high pressure lubricant black in color. I was told by somebody worked for the Boeing company that they had a piston like device somewhere that has eight call it around it to grab it so it has to slide and in the collet has to grab. But if somebody puts that type of dry grease on where grease with that in it it embeds itself basically in the metal and they have to throw the whole part away they get use it all. So I suspect on all the dry powdery lubricants that they will go into all the basically microscopic cracks and crannies of the metaland that's where it is visually at least until you scrub it off your visually going to see it which is good because you want your lubrication the stay word is. But I'm sure it doesn't last forever on the metal it's just a really nice lubrication
    • Thanks for the info. I can't seem to find tech sheets for those either.  I'll muddle my way though 🙂
