Watch of Today
mk3
Wearing my favorite Seiko 5, the SNKE63K1. Several weeks ago I opened it up to regulate it, messed it up a bit and then set it aside. Last week I put it back on the timer and got it nearly spot on - it's averaging about +2 seconds a day for the last week! I also ran the case and bracelet through the ultrasonic.
"Chronometre" arrived. It has a Glasshütte-style NACHTIGALL movement (see that little bird in the middle of the forst picture). Balance broken. It has a swiss lever escapement but no pallets :blink: Swan neck spring missing. The case had gold plating, now it will get nickel layer.
Edited by szbalogh
Where are you going to find those crucial parts? It would seem to me to be difficult...or no?
J
Well, thats a mystery :)
Moreover, once disassembled it turned out that one pinion on the 3rd wheel is broken, the center wheel has some ~ 6-7 teeth broken and the wheel itself bent from the plane. Not to mention some minor issues like glued on dial and one broken screw of the 3/4 plate.
My first post !
I liked the look of this (50s?) watch I spotted on ebay. Just finished cleaning it - runs nicely.
The movement is a Venus 180. A new make for me, but nice quality.
The watch is an 'Audax' - can't find anything about them, anyone ?
Aww man. That's too bad about the broken parts...its a shame, but don't lose hope. There may be one out there that you can harvest for parts and make one functional  watch.
In keeping with my philosophy that all watches need to be worn and given a little love I present my 50p charity shop TIMEX. Note the bent panel pins to affix the strap I've left them I think they add character and are part of the watches life.IMG_0370[1].JPG
Edited by Cad101
@Cad101 Thanks ;) Looking at your Timex, what kind of spring-bars are those? I may recognize the shape, but I'm not sure :D
Oops; I re-read your post.......yes, they add to the character......nice detail and belongs to the history of the watch ! :thumbsu:
Edited by Endeavor
Wow. Really nice. Sounds like you're an Omega man.
JC
I'm starting to lean that way, but I have a couple of other pieces I wear more often. I have an Elgin I previously posted that's my everyday watch 80% of the time.
Came in with a job lot off the bay but too nice to sell on 17 jewel 100th anniversary Flora runs very well after a service for a 68 year old watch it just needed a new mainspring. I haven't been able to find anything about the make so if anyone has any info pass it on I usually like to find out something about watches I have in my collection.IMG_0384[1].JPG
6 minutes ago, WileyDave said:
Drug out the old 27j Bell-Matic,  have not had a chance to peek inside, day wheel is skewed, on the upside alarm works and is keeping decent time.DSCF0177.JPG
This is funny. Although I'm not wearing a bellmatic today, my date is skewed as well on this cheap  pin lever diver watch. Amazing, lol.
Well said, thanks:)  I was devastated when I went to service it.  The original owner decided to pull the hairspring and balance "partially out" and wrapped it around the click spring. (was a mess)  I had a replacement movement so I swapped out the calendar works and voila, el' cheapo watch that I enjoy!  (heavy too)  Only downfall is my date wheel, which I'll repair along with the second hand. (was missing, will find a good one for it)
Love that bellmatic!  I'd imagine that alarm is noticeable;)
Edited by jeffc83
I love those Belmatics,  I've resurrected three of them now.  There's a guy in the UK,  Stefan who sells some parts for them and stuff pops up on eBay too. I've got another on the go now.
The height of mechanical genius (and sheer coolness too)  just before the electronic age assured their extinction.
This is my outdoors watch.  I'm off on a hunting trip today in NZ. This  thing,  yeah I know it's got a battery,  has an altimeter and compass and has a rugged yet light titanium case. It's getting pretty scratched now.
Between me,  it  and a topo map,  I can successfully pinpoint my position.  In the event of a GPS failure of course!
    • It looks like the canon pinion function is part of this great wheel. The pinion nearest the clip runs the minute wheel on the dual side. The pinion nearest the wheel is driven by a small wheel from under the setting lever cover plate that engages in hand setting position.    So when assembled the crown was driving the whole great train. Does this mean the pinions are too tight? Should I attempt to disassemble this great wheel and lubricants?
    • Picking up this side-tracked post again as I just removed a balance staff of a 1920's Omega (35,5L-T1) I was impressed by the way @Delgetti had his setup when he had to change out a balance-staff (https://www.watchrepairtalk.com/topic/28854-new-balance-staff-not-riveting-to-balance/page/2/#comment-244054 Not only that, but also the idea of removing the seat first before punching the staff out from the seat-side, avoiding the whole discussion of the rivet yes/no enlarging the hole. I didn't have the fancy clamps & tools Delgetti has, so I used my screw-head polishing tool. Initially I used #1500 grit diamond paste on the steel wheel, which kinda worked, but very slow. I changed to #800 grit diamond paste, which worked better, but still slow. Then I glued #240 sanding paper to the steel disk; That worked and the disk was hand-driven. Once close to the balance wheel, I took the sanding paper off and continued with #800 diamond paste. One can only do this when the balance wheel sits true on the staff and has no "wobble". I went on grinding until I saw some diamond paste on the rim of the balance wheel. This was as far as I could grind and it seemed that there wasn't much left of the seat. Carefully, with my staking set, I knocked the staff from the seat-side out. Turns out that the thickness of the seat left, now a small ring, was only 0.1mm. The balance wheel hole is in perfect shape and no damage done to the wheel at all. Of course, if the wheel has a "wobble" or isn't seated true on the balance staff, you can't get as close and there will be more left of the seat. In my case, it worked perfect 🙂 I'm very happy how this method worked out ! 😊
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
