Back after illness
Hi Guys i'm back after a quite a bad flare up of rheumatoid arthritis.  Its a bit frustrating really. I started this hobby to give me some thing to look forward to in retirement, and after getting very hooked in a short space of time & spending what I'd say a considerable amount of money on tools etc.. I've now been diagnosed with RA.
However, I feel quite blessed as when it first took hold it was quite aggressive & TBH I was starting to think about giving up work, buying a bungalow & installing a disabled ramp.  But with the help of meds i'm now starting to feel more myself apart from the fact I can't straighten my arms lol.
Anyway I'm back at work & feeling much more positive.  i'm probably going to loose a lot of screws, click springs etc. but want to get back to the hobby i loved.
David
Welcome back im sure you will be back to your old self soon enough. My stroke didn't stop me you just adapt I do still have a dodgy right hand that often has a life of its own when trying to pick up things with tweezers but a sit back and a deep breath sorts it out oh and me swearing at it like a n navvy  helps alot too :D
Thanks guys for your kind warm welcome back.  Now I just have to remember how i disassembled this movado HS360 kingmatic, at least I took pictures. However, can't remember which size screws go where.  Its been soaking in lighter fluid for 3 months lol
Welcome back. Not easy when one has forgot where the screws should sit. But could be done with some trial and error.
 Maybe not as RA ? But i have some bad thumbs. Arthritis in both my thumbs . Little bad back and arthritis in my feet:
But can be without something to put my hands on. Even if i drop thing from time to time:
Edited by rogart63
Welcome David, good to have you back.
Glad you are coming to terms with the RA and still able to enjoy the watch tinkering. I have had a few comical incidents lately after retiring from a job 5 years ago that often had me literally on my knees laying in network cabling and rerouting telecoms. I have frequently got down on my knees to do some diy or gardening and couldn't actually get up again other than by crawling to the steps or a chair, well you have to laugh sometimes. Luckily I can sit in a chair to mess with my watches.
All the best,
Vic
re the Movado.
1. Group the similar screw together, you should be able to identify the bridge screws by design and the number you need, eg 3 for train bridge, 3 for barrel bridge, one for balance cock.
2. Assemble the watch without wheels and look out for any screw which potrudes on the back-side.
3. screws which live deep in the movement have very shallow heads.. eg centre wheel bridge, pallet fork bridge.
4. Screws with a tapered base will fit into a hole with a tapered seat.
A bit fiddly but doable, patience and an organised approach is all thats needed!
Anil
One more thing regarding screws... screws that hold a movable part would have a 'shoulder'. Example the screw holding the 'click', without the shoulder, the screw will keep on tightening against the click rendering it immobile. You will find this on the calender (day/date) wheels as well.
Sorry for multiple posts.
Anil
    • But it also makes it seem less susceptible to gravity. If you place a droplet of oil on an epilame-treated surface the droplet of oil will still stay in place even if you then flip the surface from a horizontal to a vertical position. That is, the oil droplet remains anchored, and that's the purpose of epilame. If it was just a matter of creating an oleophobic surface we could probably use other, less expensive, methods!?
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
