Need help with used Bergeon Platax tool No. 2677
VWatchie
These are the two punches (0.1 and 0.15 mm) used to put force onto the balance staff to remove the roller and to drive out the balance staff. For anyone not familiar with the Platax tool here’s an excellent video of its use.
As you can see, the two holes/grooves in the punches are clogged, and I wonder if anyone knows if this is by design or because they have been clogged by broken off balance staff pivots?
Unlike the Platax punches, these roller remover punches from Bergeon’s dedicated roller remover tool No. 30070 have extraction holes so that any broken off pivots can be removed.
What suggests that the Platax punches are clogged by design is that they lack these pivot extraction holes. What speaks against this theory is that the clogged Platax punches will inevitably bend or break the pivots instead of putting the force onto the cone of the staff. One could argue that it really doesn’t matter much but putting force on the cones gives a better and more controlled distribution of the force. Also, why have two punches (0.10 and 0.15) when both will have the same effect, that is, bend or break the pivot?
My guess is that the Platax punches have been clogged by broken off pivots, but that clearing them would be extremely difficult and not worthwhile as the tool can still be used.
BTW, in the video I linked too @Markmentions that if enough people would show interest in a Platax tool video tutorial he could make one. I believe several comments expressed such an interest, including me, so when and if you have the time for it Mark, it would be much appreciated!
Edited by VWatchie
This might be a daft suggestion, but...
Maybe try heating the punch to expand the metal then dip the end in water to try and free the remainder of the staff?
If the remainder of the staff cools quicker than the punch, it might just free it. At least that's my guess, I've never tried it.
Thanks for your suggestions, but I think I'll try to snap off or file down the pivot (unless it's already broken) before I punch out the staff. It should give a larger area for the punch. To bad the punches for the dedicated roller remover tool doesn't fit the Platax tool. Anyway I'll be using the dedicated roller remover tool to remove the roller rather than the Platax. Let me know what you think!
Hi, I was pointing to the next-to-last post with the microscope view.
It shows why punching from the rivet side - with or without removed rivet - will widen = damage the hole. The staff was already distorted to taper shape by rivetting. This widened part will be forced through the hole then.
All pros that I know and appreciate will remove the hub by those reasons.
Frank
I own a Platax tool and when used I only apply the lightest taps to remove, if it shows no sign of removing then I cut the majority of the balance rim away with my lathe before finally tapping out with the platax. Some Staffs seem to be made of real strong metal and I type with experience these vintage staffs if punched out it widens or distorts the hole. The key is what ever method is used the balance must not be distorted in any way.
I have very limited experience and have only used the Platax tool to remove staffs from modern (< 70 years old) wrist watches. It has worked well and the staffs have come out with very little force. The biggest risk is if you don't know how to use the Platax tool properly. You must, of course, make sure punch never reaches the hole in the balance. BTW, doesn't the hole in balance wheel also become wider and wider as we punch in new staffs? Perhaps modern balance metal can both expand and retract? Yes, that seems to be an insane idea, but nothing surprises me and I'm certainly not a metallurgist.
Come to think of it, jewels are wider than the jewel holes, but still we can replace a jewel several times, perhaps even indefinitely(?) without widening the jewel hole? Or maybe not...
Good points indeed. All I know I changed a vintage balance a few years ago using the Platax and when fitting the new balance it was too loose to rivet.
There was a very good article a few years ago in the BHI mag with regard to punching out staffs and an example was given changing a vintage Rolex staff. The guy who summited the article informed that these staffs used metal that in his experience had to be annealed before cutting the rivet and showed how to anneal without damaging the balance.
There's always a risk of opening the hole in the balance when punching out a staff. On a hard steel balance (bimetallic) or a Glucydur there's a smaller risk of enlarging it too much, with softer nickel balances it's pretty sure the new staff will be quite loose. Supposing you manage to get the new staff riveted, there's no assurance that the staff is centered in the enlarged hole, so you'll have to spend more time poising- which on many balances means removing metal with no means of adding.
The K&D staff removing accessory for staking tools and the Platax do ensure that the balance isn't distorted when punching out a staff. The Platax is particularly useful for dismantling assemblies where you need support between two parts. But I'm with Frank on removing the hub. Or, if the balance is Glucydur or nickel you can soak it in alum for a few hours.
That sounds like a super safe method, thanks! Is there any easy method to determine what type of alloy a balance is made of? What other alloys are balances (usually) made of?
They are pretty much bimetallic (brass and steel), Glucydur (which is hardened beryllium copper), or nickel alloy. If you aren't sure, check with a magnet, as long as the balance isn't ferric it's OK. There can be some discoloration of the balance at times but it seems to clean up with normal watch cleaning solutions.
  • 4 months later...
I have made Platax punches from silver steel. The only trick worth passing on is that to drill the hole the best method is to start with a centre tool and then use an end mill of the appropriate size. Curiously they drill much faster than a twist drill and are available from https://drillbitsunlimited.com/Default.aspx
Incidentally, Matk Lovick had a video of the use of a Platax to replace the balance staff of a vintage Cyma watch. The title was 'Fitting a new balance staff to a vintage Cyma www mitary watch' It can be found with a google search.
  • 1 year later...
So I have a Platax tool with the exact same problem, clogged punches.  I bought some drill bits but the smallest set I found was still too large to drill out the broken pivot.  Has anyone been able to unclog these?  I have some Vissin that I could try, but I'd be worried about damage to the punch.  I may consider heating as well.  Perhaps this is why the tool is no longer made.
The problem with that theory is in other words this is a defective tool where is the replacement tool?
Reality is it's no longer made because it's no longer needed.
Has been replaced with what, or balance staffs are no longer being replaced by professionals but instead the entire balance complete is replaced?
    • Thank you!   Yes I did. I did not notice a difference. Although 9415 is advertised as a thixotropic grease (and I did had high hopes for it), the only advantage at this point I see is that its “easier” to apply than an oil (if one does not use epilame). But this is subjective, I guess. What I did notice though, if you apply a bit too much grease, that definitely slows down the movement. Oil in this case is a bit more forgiving, as its super thin, and it would usually just spread out.  Again, imho.
    • Mark keeps a close eye on his forum. I'm sure if you asked him he will reply, he might not do it right away but you will receive his answer.
    • I kind of think the same, the surface under the oil is the same as the surface around the oil. Can epilame both repel and attract , that doesn't quite make sense in simple terms, but is it more complicated than that. When cohesive forces within a liquid are stronger than the adhesive forces of a surface then surface tension is high causing the liquid to bead up. So  an applied epilame coating reduces the adhesive force of a surface inhibiting a fluid to wet the surface. So i guess no epilame cannot both repel and attract . If something is keeping the oil in place on top of an epilamed surface then there must be another reason for that.
    • I agree with @JohnR725. Oil on an epilamed surface is essentially the same as water on a waxed surface. The same physical properties are at work (surface tension vs. adhesion).
