New member from Sweden
CMW
I have always been interested in watches, but it is only the last year that I have tried to learn about the technical parts of the watches, how to service and repair.
Regards
C-MW
Welcome to the forum.
The hairspring you show، needs a bit  of sorting out, coils should be evenly spaced out, concentric, flat and level. Bring the collet to center so the jewel hole is in its center, end curve should be concentric with the rest of the coils and such that moving the regulator arm dose not push the coil to a side. Mark Lovic teaches the entire task in one of his videos.
Good luck
  • 7 months later...
On 5/14/2020 at 6:15 PM, rogart63 said:
Check Per Torphammar page out for translating from English to Swedish . If you haven't seen it already?
@rogart63 I've got his book (my brother gave it to me). I've Googled his name, "English" and "Swedish" but nothing came up. Not sure what you're referring to but perhaps translating the names of watch parts? In that case I'm especially interested. Can you please provide some additional info and/or link? Thanks!
Perhaps this page?
https://www.facebook.com/AmateurWatchmaking/posts/hi-watchfriendsfinaly-i-have-totally-remade-my-hompage-you-are-most-welcome-with/2083826425001416/
http://watchmaking.se/BOOK/Shop/shop.htm
This page. http://watchmaking.se/
You have a good page there which translate from English to Swedish . Maybe wasn't that easy to find. As Per Torphammar name isn't on that page. Only the mailaddress.
Found it, thanks!
Entertaining (and useful) to read the Swedish names of the parts more or less for the first time even though @HSL has taught me a lot of them (Thanks!). The names seem to have more in common with German than with English, but that doesn't come as a surprise, I suppose.
I think reading technical sheets is a good way to learn the parts names in Swedish, I still enjoy reading for example the Omega tech sheets from the past since they are so well illustrated and have nice explanations of the functionality and the complications.
I attach one here for the Swedish audience, well the pictures are universal.
At the same time I wish you all a Happy New Year!
Omega 711.pdf
    • Post some pictures , some good close ones of the parts you've described.
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. If its a potential problem for amateurs to use then i would prefer not to take the risk .
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
