Ariste Racine started his watch production in 1913 in the Jura mountains north of Geneva. The name "Racine" had already been copyrighted, so Ariste reversed his surname and registered the trademark as "Enicar". The firm produced watches up until 1988. There were massive sales to the Middle and Far East, and you have to watch out for repaints, fakes, etc. This is a nice clean one from the 1960s, with an AR 1010 movement in it.
Edited by WillFly
Another fine watch in remarkable condition with a high quality movement,  well worth keeping and preserving,  I notice it has got Incabloc shock protection.  Incabloc in it's self is fascinating in the way it works and how they ever manufacture such tiny, tiny jewels and settings is a mystery to me.
RogerC
Horrible feeling not being able to sign your own work with your own name, still a great idea doing it in reverse another beautifully preserved example Will.
How may watches do you have in your collection?
At the moment I have:
15 American mechanical hand-wound pocket watches, of which 11 are Railroad Grade and the rest 3 are US military with a 4th UK military with an American (Elgin) movement.
15 mechanical hand-wound wristwatches: 4 Roamer, 3 Hamiltons (1 with a Swiss ETA 6497 movement), 3 Wittnauer, 1 Enicar, 1 Elgin, 1 Paul Jobin, 1 Longines, 1 Smiths. All pre-1970 with the exception of the Swiss Hamilton.
2 modern quartz watches: 1 Certina DS Podium chronograph and a Seiko Solar.
Edited by WillFly
  • 2 years later...
Hello, everyone,
I have a 'Swiss Emperor' chronograph (Valjoux 72 movement) which needs to be serviced.
I have emailed Mark twice about this, but have had no replies.
Can anyone recommend a reliable place to get the necessary work carried out?
I'm in the Harlow, Essex, area; but posting wouldn't be a problem.
Thanks.
Len.
You could get in touch with the B H I tell them what you have and where you live, they will then be able to tell you of a suitable watch-repairer/maker who can undertake such a repair. Just go to their web site.
Hi Len
I'd be more than happy to carry out the service for you. I have serviced this movement numerous times. Please PM me if you want further information.
Best wishes Peter
Hi Folks:
Can anyone recommend a watch repair shop which can reassemble a balance with stud, balance wheel, regulator, stud support and lower and upper indexes for an ETA 6497-1?  The local jewlers I've asked in my area don't want to touch it.  Phone number would be welcomed.
Thanks,
Timezone (Central NJ)
Hi:  Thanks for the encouragement but I don't have the level of expertise required for such a delicate repair.  The hairspring has to be reattached and I assume the balance has to be calibrated which would involve test equipment which I don't have. It was my inexperience that broke it in the first place.  Thanks for your reply.
Timezone
As far as I know ETA does not make a complete balance.  I asked Frei and Esslinger and both said the same.  I've attached a pic of the parts and new balance wheel still in it's sealed package. The bridge is a little blurry. I purchased the balance wheel from Esslinger.
Timezone
I asked for a professional watch repair person/ company in my post.  If a local professional watch repair man said he couldn't do it I sure as heck am not going to try it.
Timezone
This forum is for watch tinkering, like I said. If anyone had known any professional around your place, he would have helped you by now.
JDM:
Thanks for your response. I am a learner NOT a watchmaker. I will try the AWCI and find someone there.  Again, thanks for your advice.
Timezone
    • Thanks for this post MikePilk, I just came across a similar problem with an Omega 1022.  The problem I had was the seconds pinion spring was bent out of shape and did not even engage with the wheel properly, so the seconds hand was not moving at all. (no power loss though :) I removed the automatic module so I could access the spring and work on it. Once I bent it back close to the right shape, I experienced the same problem you reported about power loss.  Many tweaks later, and the seconds hand is moving properly again, with amplitude back to good numbers again. Cheers
    • After cleaning up the pivots, I made bushes on the lathe. At this point I've pressed in 6 bushes (3 sets) and the wheels turn smooth. What I can also tell you, is that I'm not looking forward to final assembly. Getting the pivots aligned seems to get exponentially more difficult with each wheel that is added.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
