Took a Picture of all My Lathes
jdrichard
6 hours ago, jdrichard said:
I took a few pictures of all my lathes. 13 in all, need to lighten the load eventually. Love the ones with the Countershafts: plenty of control.6e2e700f6d44d4fb297dd779e30f9cba.jpg
Wow!
If you want to donate one to a good home.........
I'll even pay shipping.. :biggrin:
3 hours ago, Jon said:
 I've only got three, which now reinforces I don't really have a problem!
You're definitely 'normal' .  sad to say, well more semi embarrassed to say, I'm at I think 16 now - from a 5000 lb DSG to a 6mm watchmakers and all points in between.  The plan is to pare it down to 11.  I rationalize its not hoarding as there is little duplication, different sizes, different tooling and so on...well ok, there is some duplication, but they're all near and dear :wacko:
Edited by measuretwice
Sent from my SM-G950F using Tapatalk
Very funny Mark. I have a number of large wall units that I used for music recording back in the day and converted 2 for watchmaking.2f6aa57a21ccd87f920e5f9bee3d3ec5.jpgf2012f6555c2cb8de416addc9b95b0e1.jpg
Very funny Mark. I have a number of large wall units that I used for music recording back in the day and converted 2 for watchmaking.2f6aa57a21ccd87f920e5f9bee3d3ec5.jpg&key=5e528c98c99e0dc5c7697f61f355bec1a020f7c49b39565c3e416e62d64cc254f2012f6555c2cb8de416addc9b95b0e1.jpg&key=d42230f460311ac80f4d337b245678a38014595b7dec57c0ee0b4ad584040bbc
Aha. Explains the music vids on your channel [emoji106]
    • Picking up this side-tracked post again as I just removed a balance staff of a 1920's Omega (35,5L-T1) I was impressed by the way @Delgetti had his setup when he had to change out a balance-staff (https://www.watchrepairtalk.com/topic/28854-new-balance-staff-not-riveting-to-balance/page/2/#comment-244054 Not only that, but also the idea of removing the seat first before punching the staff out from the seat-side, avoiding the whole discussion of the rivet yes/no enlarging the hole. I didn't have the fancy clamps & tools Delgetti has, so I used my screw-head polishing tool. Initially I used #1500 grit diamond paste on the steel wheel, which kinda worked, but very slow. I changed to #800 grit diamond paste, which worked better, but still slow. Then I glued #240 sanding paper to the steel disk; That worked and the disk was hand-driven. Once close to the balance wheel, I took the sanding paper off and continued with #800 diamond paste. One can only do this when the balance wheel sits true on the staff and has no "wobble". I went on grinding until I saw some diamond paste on the rim of the balance wheel. This was as far as I could grind and it seemed that there wasn't much left of the seat. Carefully, with my staking set, I knocked the staff out. Turns out that the thickness of the seat left, now a small ring, was only 0.1mm. The balance wheel hole is in perfect shape and no damage done to the wheel at all. Of course, if the wheel has a "wobble" or isn't seated true on the balance staff, you can't get as close and there will be more left of the seat. In my case, it all worked perfect 🙂 I'm very happy how this worked for me 😊
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
    • one of the problems we have is visible versus invisible. For instance millennium disulfide another high pressure lubricant black in color. I was told by somebody worked for the Boeing company that they had a piston like device somewhere that has eight call it around it to grab it so it has to slide and in the collet has to grab. But if somebody puts that type of dry grease on where grease with that in it it embeds itself basically in the metal and they have to throw the whole part away they get use it all. So I suspect on all the dry powdery lubricants that they will go into all the basically microscopic cracks and crannies of the metaland that's where it is visually at least until you scrub it off your visually going to see it which is good because you want your lubrication the stay word is. But I'm sure it doesn't last forever on the metal it's just a really nice lubrication
