Showing results for tags 'Pocket watch'.
Hello guys, I'm trying to identify a movement for my friend from an unknown brand of the following pocket watch the movement have the balance broken and me and my friend would love to bring that old guy back to life because this watch belonged to his grand dad and he would love to keep some memories for him here is the movement we would like to identify If you could please help in any way with the identity of this movement, it would be very nice and you would contribute to the repair of one of the many exceptional watches that have a really rich history and it would be a shame to let them gather dust. If by some miracle you could also advise us where to buy a balance or donor movement if the parts for it are no longer available anywhere, that would be lovely bonus for my friend Thanks in advance for reading and sharing your valuable experience and/or advices
On opening the barrel of a Lancashire Watch Co Ltd pocket watch I found that the spring had snapped about 1cm from the arbour. I'd be grateful for advice as to how to go about creating a slot at the start of the remainder of the spring so it can be connected to the arbour - I imagine creating and shaping an appropriate hole in spring steel is not that straightforward. (I bought the watch, which is incomplete & in very poor condition, for a few pounds intending to use it as a 'learning' piece. There is nothing to identify the watch other than the company name on the dial (which is of badly cracked & chipped enamel) and "No. 85590" engraved in script on the barrel bridge.)
I recently acquired an Illinois pocket watch that appears to have a screw on front and back. I was able to unscrew the front with great effort. A lot of dirt and grime dropped out. I need to get the back off. There are no grab points so, I have tried a rubber ball and failed. If it was a bolt, I would use heat, but that’s not an option. I am afraid to use penetrating oil for fear of damaging the porcelain face. I am assuming that the watch is in the 100 year old range but won’t know until I get the serial number off the movement. it is clear, the case has not been opened in a very long time. What is the best way to open it?
- 21 replies
- pocket watch
- case
(and 1 more)
Tagged with:
The crystal on my Gruen Veri Thin Precision 380 cracked at some point. And I never had to search for a double dome mineral glass crystal with this high a dome before. And it is a constant radius; it doesn't flatten on top. It is 38.2 mm diameter, is uniformly 1 mm thick throughout, and is 4 mm deep inside. I have found no other high dome crystal like it, in all my searches. I put a temporary GS XHD crystal on my watch for now, but I would love to find a crystal like what it had. The high-curved dome was part of the look of the watch. Does anyone here know of a source?
This watch came to me with a broken mainspring, and otherwise looked in OK condition. No problem, I thought, new spring and off we go. I did notice the missing star wheel, and told the owner that I wasn't sure how well the regulator would stay in place without it. He was OK with that, just wanted the watch to tick if I could get it going. Weeeel, mainspring in and no tickee. At first I thought I hadn't got the train in properly or something was jammed, so I went through the wheel by wheel troubleshooting procedure, which is a bit of a PITA on a full plate watch. That wasn't it. So, I looked a bit more closely at the escapement. Saw something I missed during disassembly, you can see it in the following picture. This watch has a three piece pallet assembly, arbor, pallets, and fork, with the fork and pallets screwed together with two screws. This assembly was no longer lined up correctly, and the stones were jamming against the escape wheel. I'm guessing it was knocked catawampus when the main spring broke, but I don't really know for sure. Anyway, I lined the fork and pallets up as best I could by eye, trying to get them parallel, and the watch is now ticking away. However, I'm not satisfied that the escapement is correct. So, the question is, is there a procedure that I should be using to line up the pallet and the fork? I know I can adjust the lock with the banking screws, but if the pallet angle isn't correct I don't think faces of the stones will be at the correct angle to the escape wheel. What to do, what to do. TIA for any suggestions. David
This is for my Waltham 1883 pocket watch. I watched videos on jewel replacement and i'm more confused now than when i started. The jewel in question is for the bottom pivot of the pallet fork. The jewel is shattered but still in the setting. Do i just replace the jewel? Do i replace the entire setting including the metal? Thank you all for your help! The pictures below show the jewel from the top of the plate, and then from the bottom of the plate, marked with blue marker.
Hi all, I picked up a lovely Heuer chronograph pocket watch with a Valjoux 61 single button chronograph movement. I didn't notice when I bought it but the pusher which should sit within the crown is missing. The pusher within the crown pushes down two pins which you can see in the pictures, the pins then push a sleeve which sits over the crown, this then actuates the start, stop and reset of the chronograph. Unfortunately I have no idea where to find a replacement... anyone have any ideas? The dimensions seem to be quite different to old pusher pocket watch crowns. The crown is 8.0mm in diameter, the tube diameter is 3.1mm and the cavity for the pusher atop the crown is about 3.9mm Thanks in advance!
- heuer
- chronograph
(and 2 more)
Tagged with:
I have a Junghans J36 alarm pocket watch with a gun metal case. I'm in the process of restoring it. I need technical information on its proper disassembly/assembly. Right now all I can find is sales catalog information (from the NAWCC). Ranfft also has a couple of bits. Anybody know how to take these apart safely? I'm a little hesitant to tear into it. I also need some info on dial restoration i.e., who might be able to restore the dial. Thanks!
After having experimented with some very cheap watches I thought it was time to attempt something a little nicer. Bought this silver pocket watch and took it apart. Noticed quite a few of the jewels were shattered so is likely to be beyond my skill set at the moment to restore anyway. Despite that, I decided, probably unwisely, to examine the mainspring and measure it up for a replacement so rendering it useless in the process. The measurement I have taken are: Height: 2.6mm Thickness 0.2mm Length: 520mm ID of barrel: 16.5mm Type TR Then I find out there is no replacement to be found in the TR book which I accessed through the Cousins website. Am I not looking properly or have I made a big mistake in assuming a replacement could be found? Many thanks.
Quite a rare old watch lever set 18s running very well. Location: Philadelphia, Pennsylvania Years of Operation: 1868-1886 Production Jewels: 7-19 Jewels Production Sizes: 18s, 16s, 8-6s Total Production: ~12,000 Factory Building Status: Demolished
Looking for advice. Daughter (7) bought me a pocket watch from a second hand store. The hunter case crown is missing a cap to open the front. It appears to be threaded. Essinger seems to have the right replacement part. I can't figure out how to get the stem and crown out. I think this is an old Belle Suisse 8810. Help? Also I know it is posted to wrong forum but this was the only non grayed out option.
I am new to watch repair, but have successfully repaired, cleaned and oiled several pocket watches. This picture is from an Elgin pocket watch that I am currently working on. The piece indicated by the arrow, obviously assists in toggling between winding and setting via the clutch pinion but, as you can see, there is no screw in the hub to hold it in place. However, in the bridge, above the piece indicated, is a small screw in a threaded through-hole that is not retaining any other pieces and, at first glance, appeared to be doing nothing. I assume it is there to somehow retain the piece shown, and possibly adjust the resistance/tension of that piece. I've haven't seen one like this yet. What exactly is the mystery screw supposed to be doing, and how do I adjust it to do so?
- 5 replies
- Elgin
- pocket watch
(and 2 more)
Tagged with:
Hello, I have a lovely antique cylinder escapement pocket watch that I've serviced and got running beautifully but now I have a problem with the minute hand falling off. I think it's known as a pin hole fitting hand. On measuring the hand it shows approx. 0.40mm, and then on measuring the arbor diameter with the vernier guage, it's also 0.40mm so it's very near but won't even grip when mounted. Photos provided of the job. Does anybody have a technique I can use to get the hand to fit?
I am working on an Elgin pocket watch grade 312. It was an estate sale purchase and was not running when purchased. I assumed that it was not running because it was very dirty and thought cleaning would solve all the problems. I completely disassembled it and ran it through an ultrasound cleaner and rinse. It came out bright and shiny and when I started to reassemble for the first time I saw that there was NO roller jewel! So, what now? Can the roller jewel be replaced by a person with very modest ability? I am including two pictures of the balance and roller plate. I do not see any sign of where it was attached. Thanks in advance for any guidance. Bill H.
I'm as green as they come and need a scrap movement for practice. I scored this on an eBay auction for $0.99 (+ $4.99 shipping, LOL) First inspection shows it not in terrible condition. The balance and escapement move at least, but it doesn't wind (very stiff) and the keyless works are either rusted fast or broken (the stem does not move in or out). I'll be taking this very slowly, since it's educational more than anything else. Please note the high quality cardboard case ring.
It's been a while since I've worked on a movement as old as this. A friend asked me to look at whether I could get his great-grandmother's watch working again. When I first saw it, I thought it was an old 1920's ladies wristwatch, though thought it odd that the winding stem is at 12. However, on closer examination, it resembles more of an old pocket watch movement. Now amazingly, the watch is ticking when wound but I cannot pull the stem to set the hands. On removing the dial, I can see the yoke and yoke spring on the opposite side. But would I be right in thinking that it is missing the setting lever? There is a space that looks suspiciously like there could have been a setting lever there once but I could be wrong. I'd also be interested to hear your opinions on the age of the movement. I'm thinking around 1900. What's more surprising is that when the case is closed, you don't see the chipped porcelain around the edges, so thick is the bevel. It looks so nice and ornate and when the case is closed. Would love to be able repair but have my doubts. Any ideas about the keyless works? Thanks in advance.
- 9 replies
- pocket watch
- antique watch
(and 1 more)
Tagged with:
I'd like to try my hand at converting a vintage pocket into a wristwatch. For anyone who knows, what size pocket watch should I aim for and what's the best source for an appropriate sized case? Is a 'Hunter' best for this? What's the best solution for a winding stem and if I have to go with a case that's not drilled for the stem, what's the best solution? In other words, what best practice for this mod?? Any help would be appreciated. thanks
Hi Everyone I hope you are all well. It has been 12 months or so since I last logged in, and shamefully about the same since I pulled out my box of old watches. I was browsing the 'Bay' as always and really liked the look of this Waltham Traveler. I picked it up for less than £10 and would like to use it as my first restoration project. I have undertaken minor repairs in the past but nothing like this, I hope I haven't bitten off more than I can chew. I need to find a key to see if it winds & runs, repair/service it and source the hands and a case, which is uncharted territory for me and I'm not sure how easily they are sized / sourced. Any help, advice or pointers that you guys may be useful to me will be greatly received Many thanks in advance Dave
- 4 replies
- pocket watch
- waltham traveler
(and 4 more)
Tagged with:
Hello, I have recently bought and serviced this lovely 100 year old 'Spikins from Dent' pocket watch. The movement seems higher quality than some watches of this era that I've serviced, having 15 jewels, and being warranted English. It is housed in a solid silver Dennison Watch Case Co. case and has a 1918 Birmingham hallmark. Given the above info and the attached photos, would anybody be able to identify and tell me whether this is any particular brand of movement? I notice an S in a five-pointed star on the train bridge - is this a trade mark on a movement?
- 3 replies
- pocket watch
- vintage
(and 1 more)
Tagged with:
Hi, I am very new to the hobby of watch repair/refurbishment and self taught thus far so please forgive any stupid questions! I recently stripped down, cleaned, oiled and reassembled a Waltham pocket watch (pictured) but the balance has poor oscillation, stops when tilted at a certain angle and the movement makes a noise in addition to the usual tick which sounds like something is hitting off something it shouldn't. I've stripped the movement down again and checked every part for signs of damage (finding none) and also replaced the mainspring which has improved things but there's still something off. Any ideas on what it might be would be much appreciated.
- 21 replies
- pocket watch
- waltham
(and 1 more)
Tagged with:
Hi all, Strangely, I'm was able to find out any information for the above and have not been able to get on NAWCC message board for whole of this week. Need the information to look at possible options for hands. TIA!
- 2 replies
- hamilton
- pocket watch
(and 2 more)
Tagged with:
Hi all, I made a great fleamarket finding but as usual there is at least one issue. The subject is an old renova pocket watch with a built-in alarm. According to my searches on the internet, it was re-branded on the dial for various companies. Mine was branded with RENOVA (which matches the watch movement engravings) and a Brand of a local Jewelries dealer (Ed. Barth, Zurich). So far so good, as the alarm and everything was working, I could not set the time, so I had to disassemble it to find out how it is supposed to work and how to fix it. I found out that the usual technique for setting the time would have been just pulling the crown out. But there is one part broken, which prevent the mechanism to stay in place. See the following fotos: Next a picutre how it is supposed to look inside. For a better view I removed the piece and made a photo how it should look like. So my question is now, can you either help me to source this part for a swiss renova movement or do you know which caliber /replacement is identical? Or do you got ideas on how to make one by myself? I got very limited ability in making metal work by myself. If someone feels like in the mood on doing one for me, please let me know what would be the costs. I could spend some bugs but not a massive investment, as the watch itself is not worth so much money. I am happy to make a better photo with meassurements or provide a scan of the part with scaleing etc. And jup, that beast had grease allover the place and needs a cleaning. Greetings Max
- 2 replies
- replacement
- sourcing
(and 1 more)
Tagged with:
