My engagement watch was a Briel, which turns out to have a 0S60 Miyota movement.
I paid goldsmiths to replace the battery, boy what a mistake. When I collected it the crown came off in my hand. Goldsmith said they can't repair!!! They paid me £250.
So this is when I did some research and took the back off the watch. I believe the stem is still in the watch. But I think I can repair by replacing the stem and crown. I still have the crown.
Could some one advise what stem I need and how can I attach the crown, doesn't appear to have a thread but I think it should have. I can get more photos if needed.
Many thanks
Strange. Can you provide a picture of the crown. It would be helpful to know if the stem simply came un screwed or snapped off leaving some of the stem left in the crown.
I realise you had a bad experience with one business but I wouldn't completely disregard seeking out the help of another, at least if there's any watch specialists around your area, The watch mainetence/repair work of jewellers, particularly large chain jewellers (like goldsmith's) often leaves a lot to be desired and what's 'impossible' for them is childs-play for someone who is a watch repairman first and foremost.
From the first photo I can see part of the stem, I would say its broken off. The button screws on.
Stem from here. https://www.ebay.co.uk/i/253007986837?chn=ps&dispItem=1&adgroupid=13585920426&rlsatarget=aud-133395220866%3Apla-142405555266&abcId=&adtype=pla&merchantid=9391734&poi=&googleloc=9041119&device=c&campaignid=207297426&crdt=0
Photo of how to take the stem out.
Excersise extreme delicacy when pressing the stem release. It is very common for people without the proper experience to basically damage that mechanism. You'll need to press on it while gently pulling the remaining piece of stem from inside the case with a pair of tweezers. And the stem may need to be pushed, clicked in to the proper position (fully in) otherwise the stem release leaver wont be there where you're pressing.
Edited by Ishima
My thanks to both Oldhippy and Ishima. All responses are excellent.
I think old hippy is correct in that the crown was stressed at some point and does appear to have snapped of. I intend to get some better photos later as per Ishima.
I also take your points Ishima. My experience with Goldsmiths was very emotional as to have a very important watch (emotionally not in terms of £'s value) returned broken was a true shock , the lady on the counter at my local store was near tears and I hadn't said anything. My true concern with Goldsmiths is that if I can research that stem replacement is relatively simple, Goldsmiths should have been able to replace, but I suspect as with most large scale businesses of this type they went for the easy option and gave me money to which I now have a very nice Hamilton Crosswind and the potential to repair my original watch.
Also, looking at the watch removing the remained stem may be a step too far for me as it may not come out easily as there is little if any to grip so I may have to find a repair support locally (not that many around here Tamworth, England) that according to google. I have sourced a stem on ebay for £5 from USA so, if will see where I go.
But again to both Oldhippy and Ishima my thanks for your time. I will post photos later.
thanks
Hi all,
Just been emailed the stems info below:-
065.453 - 1800 Length
065.533 - 2400 Length
065.557 - 2400 Length
How do I measure length of stem required?
You will need to cut the stem to the right length when you fit it. For this it is better to fit - measure - adjust until it is right rather than to cut to a "spec" length and fit blind. See here for an excellent walk through by Geo.
As for the crown, if it is stainless steel or plated brass your best bet is to use alum to disolve out the remaining stem leaving you with clean threads to fit it to the new stem.
great responses, my thanks. Looks like I have a little work to do.
Here's some more images. Notice in the crown it looks like it snapped off leaving the stem head in the crown, but I could be well wrong.
The stem end is like any other stem.
That bit I think is part of the crown.
PS - Sorry about the DNA under the crown [emoji33]
PPS - Got the stem from Leosics in the UK.
Sent from my Honor 5c
Does not look good, Check if you can find a suitable replacement on Cousins UK or other source.
If you can't get a new crown you can drill and retap the original one. You'll need to find a watch maker or model engineer with a lathe to drill the centre of the crown. The stem will be a Tap 9 which is a 1.1mm thread. You'll need a bottom tap as well as the usual taper tap to cut the thread.
Not difficult in engineering terms but booldy annoying after a trip to a usually reputable retailer.
Cheers Neil
You will not get a crown other than the original. It is custom made for this case only.
A generic in a different, but acceptable style is possible, no?
Edited by Ishima
  • Similar Content
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
