Removing Balance
N00b question but I've seen two recommended methods to remove the balance assembly from the movement, and now I'm confused which is the best / more correct ?
1. is to lift the balance cock and very gently remove it by just holding the cock and making sure as to not snag the balance wheel. so that the wheel hangs on the hair spring, as per Mark's videos. Also when using this method how does one go about flipping it over to lay it in the parts tray, other than very carefully ..
2. is to pick it up by holding the balance cock and wheel together in your tweezers, as per the picture attached (sorry for the blurry mobile phone pic).
So which is the most correct way and more importantly why? Which way should a n00b like myself be using.
I use the second method. As i am elderly i tend to shake a little making the first method difficult.  But that can be risky and i think u can bend the pivot if you hold to tight? On balances that has a jewel that you can remove . I do that and put it back after i have put the balance back on the movement?
I use both methods. I've once tangled a hairspring using method one (balance suddenly sprung upwards due to sticky lower jewel). I've once bent a lower balance pivot using method 2 since the lower pivot was stuck again, and the balance always lifts at an angle when you use this method.
I usually go for method 1, and use method 2 if the balance is sticky. If it is too sticky, then I pick up an oiler in my other hand and use it to persuade the balance wheel to lift.
2 minutes ago, madchops67 said:
I use the first method to avoid damage to the hairspring, just in case it's gets nicked by being compressed against the balance wheel and balance cock.
That can't happen, because the shape of the upper pivot into the balance cock hole the makes so that there is always a certain space between the wheel and balance body.
On the other hand, when you keep the wheel dangling by the hairspring, the latter can get distorted by catching int something, or by the wheel weight itself.
It happened to me once before, maybe because I gripped to hard with the tweezers and the outer part of the spring end up distorted. It may have been pinched or rubbed against the balance cock. That is jus my experience, so that's why I use the first method.
I prefer option 1 but use option 2 if the whim takes me.
I like to lift the cocktail and rotate so it sits on the movement leaving the upper staff pivot loose. Then lift the lower pivot out its jewel. Then lift the assembly. That way you'll not end up with a jumbled mess if sticking pivots in the jewel hole.
On old pocket watches there is a third option.
3. Loosen the stud retaining screw. Push the stud down away from the balance cock. Remove the balance cock. Then remove balance wheel and staff. It can then be reassembled on the worktop.
I'd have to say it depends a bit on the movement.  In some movements the center wheel is very large and will cover a good portion of the balance making option 2 difficult.  Other times, if the movement hasn't been serviced in quite a while or you know the balance pivots may stick, option 1 goes out the door.
I generally use the first option but with a caveat; Once the balance cock is loosed I'll lift it and shift it slightly to release the top pivot from the jewel, then lift the balance wheel up out of the bottom pivot before removing the entire assembly.
If you use method one you don't need to leave the hairspring dangling. I use a balance stand and a bit of rodico and it could sit on its standard for years if necessary. Have attached some pictures for demo. Just remember when taking the balance assembly of the stand to hold the wheel gently incase lower pivot sticks in the rodico. Then release from the rodico.
I think people prefer method 2 to avoid having to flip the wheel over when working on the balance.e1e993a4a39694fe7cc590f463b3bcd3.jpg3082f14a7ea479edbf4eec8d2c605dac.jpgc13f1cabc442e023536908a694af60d7.jpg
Great question ... and answers!
I've always gone for option 2 as it has served me well but I might start using option 1 for some of the reasons given.
And digginstony I am so getting (or making) myself a balance stand! :)
Edited by WatchMaker
I use this method so I can sneak up on it, save for the third method there that I haven't thought of, pretty slick!
BTW I just got one of those balance stands/tacks and it's extremely useful.
What has that to do with this? [emoji4] Better to let it swing?
Yep it's more of a swing than a vertical lift, to move the balance bridge from its fixing stud or studs Then ease the lower pivot from its jewel but it still necessitates a slight lifting motion ??
    • My latest. Timex 2465. Replaced the crystal, caseback gasket and spring bars. All in less than $5US. Added a gray NATO strap I already had in stock.
    • I have some Gruen 510's in my donor pile if you need parts.
    • I've been intrigued by everyone's input here...so I decided to give this a shot. I bought the"typical" Pearl watch-machine basket and trays, for about $65. The trays are good,..the housing is a nightmare ! Thought it would take the mixer off my bench at anything above about 200rpm. The housing is cast of course,..and it's not "true" at all...so the harmonic vibration was insane. So,..I bit the bullet and bought the Elma housing and top. Not the baskets though, as the Pearl one's fit the Elma. Saved a bunch there. The basket and lid came to about $80 with shipping. The opening in the Elma top is 8mm, and the shaft that came with my stirrer is 6mm. I bought a piece of steel tube, 8mm O.D., and 6mm I.D. Cut off about an inch of the tube, and drove the rod into it. Gives a really snug fit.... Lightly champfered the leading edge of the 8mm section, then lightly tapped it into the top of the Elma lid. Spins like a dream now So... I have about $240 total into this including jars and steel mesh for the wave breakers   I'm pretty happy Best to you all   Randy
    • Still haven't gotten around to getting stems or screws, but I did make my first attempt at polishing a case. I just used a soft mop and rouge to reduce my odds of ruining them, and I think they came up pretty nice. Also gave the crystals a polish on the same wheel while I was at it. They were both very badly scratched up. The one on the left is fairly beat up, but it'll still make for a decent presentation.
    • You can try a rubber on that the sort for rubbing out a pencil.
