@GeorgeClarkson A while ago I opened a thread "Genuine "Leather" watch straps". I plan to continue as soon as I get to it. I did build already a stitching pony, which I will explain in the thread. I ordered already needles, pricking irons, awls, various colors of waxed stitching thread and other small stuff required. You don't need a lot to get started. The Nato strap turned out reasonable good, being my first object, but I like to improve on the saddle-stitch. I also made a few key-pouches like the ones on the picture and they turned out fine..... for a beginner that is. It's a skill and it takes time to perfect.... like with everything else B)
If you are interested to learn about leather craft, I can highly recommend you to visit the YouTube channels of these two "top-notch" craftsmen:
Armitage Leather : https://www.youtube.com/c/nigelarmitage/videos
Ian Atkinson: https://www.youtube.com/user/satansbarber/videos
I can only say that it is a very fulfilling hobby :thumbsu:
Edited by Endeavor
And a very nice friend she is too :D Crisp Clear and Colourful
Past few days been wearing this 70's throw back >
I rarely endevour to repair quartz watches but this was presumed dead and sold off very cheap. Luckily i checked the basics, removed and cleaned contacts, checked battery, fitted new battery, and.....tada. Photos don't really show it but the watch is immaculate :)
I can scratch this one off of my wish list .  A beautiful Hamilton Ventura in excellent condition...I'm stoked...
I removed half of the reference #...
Ooooh me likey a LOT!![emoji7] [emoji7] [emoji7]
Very Nice , I really like this one .
A converted Hamilton for me today.... This is the "Registered Edition" Piping Rock that had a Hamilton Quartz Movement in it until yesterday when I exchanged it for a Hamilton automatic movement .
  The new movement did not come with an hour wheel so after not being able to find the proper hour wheel for this movement , [yet] , I went rummaging through some old movement watch lots I have had for about 4 years . These junk movements were sitting in the back of a drawer , and there were bits and pieces from different watches with names I had never heard of . There were several hour wheels so I figured I had nothing to lose by trying to fit them to the Piping Rock movement .
Would you believe one of them fit the cannon pinion and mated with the minute wheel . I was looking at it and I couldn't believe it .
 The hour wheel was .06 mm too tall , and the O.D. was a skosch larger than the hole in my hour hand . I carefully filed the hour wheel down .06 mm and finished out the rough edge with a sanding stick . Then I very carefully broached out the hole on my hour hand and fitted it . By another stroke of luck the winding stem with the crown from my quartz movement fit the automatic movement to wind it and set the hands , but the stem from the auto movement is a tiny bit too big to slide into the quartz movement ,....I'll use the quartz stem with the crown attached as the length is correct .
The watch has been running for about 8 hours so far with no problem , but I'll wear it for the next couple of days and see if it makes it through the trials .
I've attached some links at the end in case anyone is interested in a little history of the Piping Rock .
http://www.hamiltonchronicles.com/2012/09/1928-piping-rock.html
http://www.hamilton-museum.com/museum
http://www.vintage-hamilton-wristwatches.com/2015/03/hamilton-piping-rock-registered-edition.html
11 hours ago, clockboy said:
Found this at ranfft & I have circled the interesting part of info. IE perhaps it was made for either quartz or mechanical. The link I found it from is below. A good result Richard.
 http://www.ranfft.de/cgi-bin/bidfun-db.cgi?00&ranfft&a&2uswk&Hamilton_53
Aloha Clockboy , If this is in reference to my Hamilton Piping Rock , you've circled the mainspring which of course would not be used in a quartz watch ,
My new Hamilton automatic movement is stamped # 889 on the bridge and stamped # 138.001 [FHF I think ] , under the escape wheel .
I am searching for the hour wheel . Boley listed it as part FHF # 250 , which I ordered , but it is too small and does not mate with the minute wheel . Jules Borel lists 2 hour wheels for this movement , 250/1592  and  250/1593 ,...the difference being the height of the hour wheel tube .  I am reluctant to order this part as it is also a #250 which had proved to be to small . I will call jules Borel and inquire if their # is also a FHF # .
Mahalo , Louis
Thanks for the help and Info Clockboy .
The parts list shows Hour wheel P/N 250 for the 138.001 which I ordered but does not mate with the minute wheel . The other hour wheel is for the sister movement  138.011 that shows a double toothed hour wheel . On other hour wheels I have seen listed for the 138.011 they were not double toothed but a bit higher tube but still had the P/N 250 assigned to them .
I wii try to ger more info on the dimensions of the double tooth wheel although I don't know what the top gear would be used for ......On second thought , I think the second gear is for a date wheel on the 138.011 .
Thanks , Louis
Edited by ricardopalamino
I am actually wearing it, but that is not a picture of my arm! Stainless Steel 1970's Bucherer Automatic - ETA 2824.
28,800 BPH
Quickset date
Second Hack Feature!
I have a real soft spot for Bucherer. I've got a broken 1980s quartz on my work top I keep meaning to do something with
Sent from my SM-G920F using Tapatalk
This one is looking for a new home on eBay now :-)
What's the movement inside?
It is Breitling's version of the Valjoux 7750.
I have had it for over a decade and still runs to a couple seconds a day. I need to get better at this watchmaking habit because I am sure it needs a service though.
Of course it is a 7750! What I was thinking about! Yes, good movement and good watch! Why did I ever thought Venus? Who knows, maybe old age! :)
Cheers,
Bob
    • Why do you think this is Fontainemelon ?
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
