Watch of Today
mk3
35 minutes ago, digginstony said:
Hattori Nh35. I suspect Motion Tone are producing these movements for Seiko but couldn't confirm either way
Hattori was a "family name" brand, but isn't used anymore by Seiko-Epson marketing. NH / NE etc are all branded (SII) Seiko Instruments International, and are (mostly) made in Japan in highly automated factories. That is to allow their OEM customers to sport the renowned provenience, while Seiko doesn't need to do the same for their own branded watches.
Hattori was a "family name" brand , but not used anymore by Seiko-Epson marketing. NH / NE etc are all branded (SII) Seiko Instruments International, and are (mostly) made in Japan in highly automated factories. That is to allow their OEM customers to sport the renowned provenience, while Seiko doesn't need to do the same for their own branded watches.
I think the 4r and NH35 parts to be interchangeable. The movements appear identical, though the standard of finish, better on the 4r. Would you know ? Also is there an equivalent to the 6r15
They are identical. The finishing is also the same, but Seiko makes it with a gold plated rotor.
6R15 is NE15 in SII branding, but isn't very popular because it's too expensive for micro brands.
My pic
Oh yeah? I thought all Seikos were auto winding only.
J
4r, Nh, 6 onwards etc have manual wind and hacking. But it's a matter if you believe in hand winding an auto watch and Seiko enjoys a very efficient autowind system.
If the second reduction gear is not disingauged whilst hand winding, this would probably lead to accelerated wear.
.Titoni 'Airmaster' today.
It has 'Bombe' lugs which don't really match the band fitted here. A leather strap would suit it better. The original steel bad has enpieces which fitted better.
Nicely executed caseback with the Titoni flower prominent.
Titoni flower on clasp.
And the makers name on the clasp.
Titoni were really big in Asia in the 50s to the 80s.  Inside is an ETA2408 I think, the case back need a a special tool which I don't have.  If I need to I can open it with some other caseback openers but I do it only if I need to get inside as it could get scratched in the process.  Normal quality but it's running pretty well here.  Been wearing it for the last week and hasn't needed the time adjusted.
Anilv
@anilv
You can easily make your own caseback opener.
I've had great success a few years back.
Sandwich wrap over the back, JBWeld metal repair putty pushed and moulded to cover just the caseback and a nut buried into it for using a spanner on to undo caseback once the JBWeld has set for 24hours.
@anliv
I resorted to this after myself, and my watchmaker, tried everything else.  Superglued the nut on and used nail varnish remover to remove the nut afterwards.  We had tried everything else first
I can't add this to the videos section until I have 30 posts, but if anyone else wants to do that then feel free.
39 minutes ago, ro63rto said:
@anilv
Thanks Ro63rto.. I have jb weld.. Will give it a shot.
25 minutes ago, Scottswatches said:
@anliv
I've tried superglue (cya)  few times but it didn't work for me. Maybe it's the quality of the stuff we get here in Malaysia.
Anilv
4 hours ago, Scottswatches said:
@anliv
I've done the same thing numerous times.
J
5 hours ago, ro63rto said:
@anilv
Hi ro63rto , I have a couple of 6 , 8 , etc. sided casebacks to open but don't have the proper wrenches , so when I saw your comment on the JB weld method my ears perked up with curiosity . I know I need to eventually get the right wrenches for this purpose ,...BUT , would elaborate on your method and possibly show one of your creations ?
Thanks , Louis
4 hours ago, digginstony said:
My Seiko SNK805K2. Just finished service. Still need to polish out some light scratches on the crystal. Favourite travel watch and slightly modded, with sunburst blue dial and hands.45284f9c72b41d0ff9e872bfea2e7219.jpg
Nice watch. I have one Blue-dialed watch, and it's a 1973 Bulova Jet star. Still haven't been able to get my hands on a bead-blasted matte finish watchcase like yours.
J
On 4/1/2018 at 7:52 PM, Tipsy said:
This one makes me want to buy 19mm straps! Sadly I have zero, so this Seiko 5 strap will have to do for now.
ETA 2472 (wish it had proper quickset).
Very nice watch! I believe Ginsbo went on to become Pagol which was a popular brand in Asia. Similar for Felca which became Titoni.
Anilv
Wearing a chunky Citizen this Friday the 13th!. It has a 6501 movement inside.  On this example I believe the hour and minute hands have been changed, they should be gold-plated.
It has a whole bunch of numbers on the back but the serial number is the one starting 409xx which means that this is from Sept '74. Citizen use the 2nd and 3rd digit of the serial number for the month whereas Seiko only uses the 2nd digit with 0, N and D for Oct, Nov, Dec respectively. The case is black anodised aluminium and I usually apply some grease on the threads when I have the caseback off as aluminum and steel can corrode badly.
I like these Citizens as they are uniquely 70s in design and much better than their 'Eagle' models. One downside is the anodising wears off on the back but as its not really visible I can deal with that.
Have a good weekend ahead!
Anilv
Anilv
Ohh , that's Funky . I like it...
Wearing a Fortis 'True-line' this Sunday.
It's an automatic with an ETA 2452 inside. Bought it cheap a few years back as it was not running,  a service and it's running fine. It had a generic crown which I swapped out for a used original I had around.
It has shrouded lugs which is a nice design feature and with the date at 1 o'clock it's quite a unique watch.
Foetus is a brand rich in historynd their recent models are quite ice but is sad that they had to declare bankruptcy last year..  Hope they make it through.
Anilv
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service.
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro. I thought the idea was for the epilame to create a barrier, a wall between the lubrication and anything else, so the lube cant spread.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
    • I think attaching a nut to the lid to pull it off is the least destructive, any damage damage on the outside is going to an easier fix than any created when trying to push it out from the inside. Scratching up the inside of the lid , mainspring or arbor bearing will be risk. Just my opinion.
