Watch of Today
mk3
I haven't posted one of these for a while so I thought I had better.
This is my current favourite. 1970's Accurist diver, ETA Cal.2472, all stainless case.
eBay score in a very tatty state but for reasonable money. All it needed was a full clean and service, relume of the hands, and a new crystal, it's now keeping great time. I can't do much about the wear on the bezel as it is not an insert, but printed directly on the aluminium but I actually quite like the "well used but not abused" air that it lends the watch.
It's on a second hand Mont Blanc stainless steel bracelet (also off the bay) which I think looks great and is extreemly comfy.
On October 7, 2015 at 4:16 AM, Gryf said:
Wore the Shturmanskie today - a Poljot chronograph that I've owned since it was new. It's showing some wear now, mainly the missing chrono reset stud and not much chrome left on the crown. If anybody can suggest a source for Poljot parts, I'd be grateful! I think Mark recently posted a teardown of this movement.
Gryf
Wow , You have put your watch to good use .
I have several Russian watches with this Sturmanskie being one of my favorites .
This Vostoc Ships clock is pretty nice. 8 day wind up and nice and heavy duty . Along side my Vostoc diver .
Nice, I recently serviced a "Avenger" Brietling much the same style as the first pic. The only issue was the removal of the hands as they are coated with some sort of ceramic & they were fitted really tight & one was damaged & I had to replace. However a real nice,heavy watch.
3 hours ago, Horologent said:
Saturdays gonna be a GMT day I can feel it........Time to go vintage.....1975 to be exact, man i love this dial
I have owned two of these beauties & wish I still had one . Now I have a boring submariner. As you can guess I love Rolex. IMG_0767.jpg
Yeah but subs are classic, nothing boring about it my friend. Yep, the one above was my second GMT ....the first (below) was a newer Master II of course but oddly enough I like the '75 better for reasons I haven't figured yet.
Edited by Horologent
    • Same goes for me, i like to pull broken things apart to fix them, it forces me to think more about how they work. If i take something new and working apart and then break it then thats just gonna pee me off.
    • VWatchie, I remember you saying you have picked up a few bargains on that site.
    • Understood OH , i just thought i would ask.
    • Your original balance can be poised by adjusting the balance screws. The replacement can't and it is cheaper to make.
    • OK, let me try and expand on why I think this is right (but maybe misleading at the same time). Wikipedia has a good explanation of surface tension, which is where I got most of the ideas below. The cohesion of the liquid molecules binds them together into the most compact form possible. If there are no external forces acting, this is a sphere. Surface tension is the combined effect of the cohesion between molecules on the surface with others on the surface, as well as the cohesion to molecules just under the surface, causing contraction and the formation of a denser "skin". The way a droplet of a liquid forms on a solid surface is determined by the strength of this cohesive force relative to the adhesive force between the liquid molecules and the surface material. If cohesion >> adhesion, you get a droplet. If cohesion is similar to adhesion, the liquid tends to spread out on the surface and creep away from its original location. Oil doesn't have the same high surface tension that water does, so it is not going to form a really rounded droplet on any surface in the way that water will "bead" on wax. This is where my earlier statement is misleading, but it is still exactly the same principles at work. Drops of oil on an epilamed surface are not going to run off in all directions at the lightest provocation. What the epilame does, I think, is reduce the adhesive force to the surface somewhat, making the weak cohesive force of the oil molecules more effective. The result is less tendency of the oil to spread out and creep, and more tendency to stick together as a cohesive mass. I don't think epilame has any effect on surface tension. That is a property of the liquid and is determined solely by the cohesive forces between the liquid molecules. I also don't think the epilame makes the liquid "stick" to where it is applied. The oil adheres ("sticks") more strongly to a non-treated surface than to a surface treated with epilame. This is why the epilame needs to be removed from the contact surfaces by running dry for a short period. The oil then sticks more readily to the local contact surfaces, where the epilame layer is worn away, than to the surrounding area. The oil sticks together, and is thereby anchored in place as a single body. Interestingly, reducing the adhesion of the oil to the solid surfaces will also reduce capillary action, which is what we rely on if we don't use epilame. Another reason to make sure the epilame is worn away from the spot you want the oil to stay put.
