Watch of Today
mk3
7 hours ago, ro63rto said:
Are the markers and hands luminous?
Where did you get the parts from?
Thanks.
The dial is the 'Fuller 6 O'clock Special' from Jake (Dagazwatch.com) . It's awesome quality with polished lume filled markers. all round.
Hands are from Dagaz also except the electric blue seconds from harold (yobokies)
And AR sapphire crystal from yobokies also
Edited by Tunokies
Desk diving today with Seiko 6309-7040 from Dec 1984. Has been reworked with new hands, dial, bezel insert and case base been lightly polished. This is one of the easiest wearing divers watch I've had the pleasure to slap on my wrist and fits ok under the sleeve of a dress shirt. This case style originally came with a black bezel but the guy I bought it from fitted a 'Pepsi' bezel. Looks good and it'll probably stay this way.
I have to say the quality of aftermarket parts is really goods these days..the only problem with the ones here is the poor lume.
Close up of the dial..alignment of the '150m' could be better!P_20160810_083311_1_p.jpg
Anil
I was looking at Jeffc83 posting showing the Helbros, in my travels I picked up a Gruen for spares/ repair that bears a remarkable similarity, I was attracted by the date at 6 and it does tick for a while so I live in hope.
Makes me wonder if there was a relationship between Helbros and Gruen but apart from the American connection there does not seem to be one
Cheers,
Vic
Breaking away from Seiko's for a change, i saw this and had to give it a work over :)
Swiss Made but assembled in England, the case design is awesome, smooth curved lines contrasted with straight and angular hands/indices, and that seconds hand just tipped me over the edge :D
ETA 2783 - Summit 25 Jewel Automatic
  • Like 6
Ok so it's seikotime.  This is another "bitser"  that I've made up.  I went through a phase of these things.  It's an early 1960's seiko 8306 Sealion that I made up from my parts bin.  The movement is a low /hi beat (pending on how you look at it at 18000) 30 jewel unit.  Probably it's most interesting feature is the winding mechanism.  You can hand wind it or it self winds using a fairly complex, but very smooth and compact inversion roller type mechanism.  A nice change from the "magic arm"  so common in seikos. I just couldn't find any more original dials so it got a Seiko 5 pilot type one and  grafted it onto it.  It doesn't really reflect what's under the hood  (but I know and that's what counts),  but it's produced a nice daily wearer.
    • Thanks, ManSkirtBrew.  I started looking for a setup like yours and ran across this.  It was about half the price of the JKA Feintaster (depending on what auction you were in), and it's a Bergeon.  I bought it because I thought the price was fair (eBay - Buy it now), and I'm a sucker for vintage tools. It also has a table, so it should be easy to use for measuring jewels. I wonder if the the contact points can be changed out. Bergeon seems to manufacture new tables and accessories for the contemporary dial version. What do you guys think of it? I'm sorry this post seems to have taken a detour. I'm new here so let me know if I should start a new topic.
    • This is a flying cutter, usual one. The cutter itself is shown in the pictures in the first message, it is made of broken tungsten carbide drill bit. I asure that all the angles of the cutter are as they should be. I have video - little older one - that I made when onse making the same kind of winding pinion for a Poljot 2200, which is even smaller than this one. It is not easy to see in the video, but the tool rest moves about 1mm towards the object in Y direction and then returns back untill cutter is rotating. Then the spindle is rotated one tooth ahead and everything repeated untill all teeth are cut.
    • After a bit further research could it possibly be an AS 970?
    • Latest project was a non-running ebay purchase with an FHF70 movement. I stripped and cleaned it, reassembled it, and got it running. So far so good, nothing damaged AFAIK.  I was oiling the top jewel on the balance (the one in the cock) which was a slightly unusual shock setting. I removed the spring (3 leaves) which was part of a chaton holding the cap jewel. This left the hole jewel behind which I retrieved with rodico and then lost it. I was taking it off the rodico, very gently as I thought, with tweezers, and then it just disappeared.  Fast forward a week, I got a donor movement, non-running, with the plan to just take the shock jewel that I’d lost. It was the same movement but had standard incabloc settings, and was steel rather than copper/brass.  I changed the cock and balance complete and it ran, not very well. I switched the lower jewel setting, cleaned and oiled both jewels and the replacement balance. Without the pallet fork the balance swings very nicely with a puff of air. With the fork in place, balance out, it flicks side to side nicely with power in the mainspring.  Put them together and it doesn’t run. The impulse jewel sits in the fork and it stops.      Any suggestions how I proceed? In case you didn’t follow that I have 2 FHF70 movements, nothing broken as far as I can tell, but mixing up the balance wheels and jewel settings results in a non runner.
    • Oh and this almost perfect third wheel pivot and slightly set mainspring  Ah ok yes i see what you mean, good idea. I'll try that if i fluff this one up. The image isn't great quality but i like the idea though.
