Back after illness
Hi Guys i'm back after a quite a bad flare up of rheumatoid arthritis.  Its a bit frustrating really. I started this hobby to give me some thing to look forward to in retirement, and after getting very hooked in a short space of time & spending what I'd say a considerable amount of money on tools etc.. I've now been diagnosed with RA.
However, I feel quite blessed as when it first took hold it was quite aggressive & TBH I was starting to think about giving up work, buying a bungalow & installing a disabled ramp.  But with the help of meds i'm now starting to feel more myself apart from the fact I can't straighten my arms lol.
Anyway I'm back at work & feeling much more positive.  i'm probably going to loose a lot of screws, click springs etc. but want to get back to the hobby i loved.
David
Welcome back im sure you will be back to your old self soon enough. My stroke didn't stop me you just adapt I do still have a dodgy right hand that often has a life of its own when trying to pick up things with tweezers but a sit back and a deep breath sorts it out oh and me swearing at it like a n navvy  helps alot too :D
Thanks guys for your kind warm welcome back.  Now I just have to remember how i disassembled this movado HS360 kingmatic, at least I took pictures. However, can't remember which size screws go where.  Its been soaking in lighter fluid for 3 months lol
Welcome back. Not easy when one has forgot where the screws should sit. But could be done with some trial and error.
 Maybe not as RA ? But i have some bad thumbs. Arthritis in both my thumbs . Little bad back and arthritis in my feet:
But can be without something to put my hands on. Even if i drop thing from time to time:
Edited by rogart63
Welcome David, good to have you back.
Glad you are coming to terms with the RA and still able to enjoy the watch tinkering. I have had a few comical incidents lately after retiring from a job 5 years ago that often had me literally on my knees laying in network cabling and rerouting telecoms. I have frequently got down on my knees to do some diy or gardening and couldn't actually get up again other than by crawling to the steps or a chair, well you have to laugh sometimes. Luckily I can sit in a chair to mess with my watches.
All the best,
Vic
re the Movado.
1. Group the similar screw together, you should be able to identify the bridge screws by design and the number you need, eg 3 for train bridge, 3 for barrel bridge, one for balance cock.
2. Assemble the watch without wheels and look out for any screw which potrudes on the back-side.
3. screws which live deep in the movement have very shallow heads.. eg centre wheel bridge, pallet fork bridge.
4. Screws with a tapered base will fit into a hole with a tapered seat.
A bit fiddly but doable, patience and an organised approach is all thats needed!
Anil
One more thing regarding screws... screws that hold a movable part would have a 'shoulder'. Example the screw holding the 'click', without the shoulder, the screw will keep on tightening against the click rendering it immobile. You will find this on the calender (day/date) wheels as well.
Sorry for multiple posts.
Anil
    • Yea a have given it a full service this movement is chinese 2813 whats the left angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com   Anyway, I wouldn't be surprised if it would be more correct to think of epilame as a binder rather than a repellant. Until convinced otherwise that's how I will think of epilame.
    • I read that same article last night  H.  I think epilame is too much headache for me, sources aren't always accurate, some conflicting. Such is the GRAVITY of this situation, Is it ok if i just STICK  to a thixotropic oil 🤣
    • Not sure I follow along. As I stated in one of my previous posts, the epilame will remain intact between rubbing parts as long as the surface is lubricated by oil or grease. Maybe it's just a coincidence, but note how the epilame-treated surface is illustrated in @Waggy's post. It looks like the oil is exposed to a binder (epilame!) so that it can't move sideways.
    • The epilame under the oil will also be removed  Unless the oil makes a barrier between the epilame and the escape teeth 😅 I think i need two strong coffees now 🤣
