SCOTTY
I was referring to the moonswatch, the plastic quartz collaboration between Swatch and Omega, that’s over £200 and I would rate seiko movements over the Swatch quartz. 😀
Tom
Sorry, didn't see the "s" 😉
Yes, for sure. Unlike the Pagani, the reviews of these moonSwatches aren't very good either .
I roam regularly a German website "Kleinanzeigen" and currently there are no less than 514 "MoonSwatches" for sale; new and second hand, but next to new. It seems that people like to get rid of them. (https://www.kleinanzeigen.de/s-moonswatch/k0)
On the Pagani I may pull the hands and re-lume them with Superluminova. I like to have the legibility in the night as good as these moon watches are during the day. Besides, good lume comes in handy too when reading the newspaper in the dark 🤣
I enjoy the affordability and style of some of the mechaquartz chronographs, but I really don't like it when one of the registers is being used as a 24-hour indicator, especially on a watch without a date function. That doesn't seem to be a very faithful homage or a useful complication. Of course, even worse are the ones where the large second hand is a normal running seconds hand, and you find upon receipt that one of the small sub-dials is used for the chronograph seconds. Or the ones where what looks like a 12-hour chrono register is just a 12-hour mirror of the hour hand...
The extreme hype around this watch was difficult to understand, but it shows that what really matters is looks and brand. Other than that, a plastic quartz watch, not making me too excited.
Hi watchie.  Spot on,   It’s what it looks like on the wrist no matter what’s in side.  Certainly looks the part  but there again so does a dollar watch untill it breaks. One for the fashionistas.  I love Omegas but this doesn’t ring my bell either.
For me, a bit of a "kinky" side step; two partially broken vintage quartz watches no less ! 🙃
They do run and the chronograph functions do work, but, from both, the small chronograph seconds recorder (1/10 sec) doesn't reset and they don't run 😬
I've found some instructions on how to reset the small seconds recorder, but it doesn't say whether the recorder hand should run, or not, after a battery change;
"Resetting the Chronograph to Zero:
If your chronograph and 1/10 seconds subdial hand are not aligned after a battery change, do not worry as this is common and easily fixed. Simply make sure the crown is in normal position (pressed in against the case), the push Button C (bottom left) twice. The second hand will move, press C again. Pull out the crown to time setting mode. Now you can adjust the two misaligned hands: Button A will advance the central second hand forward, Button B will advance the 1/10 second hand forward. Push the crown back in."
So, since both of them do have the same problem, it could be simple and the seller didn't know how to reset, or there could be more to it? Is it a coincidence that both movements do run (cal. 3510 + cal 3530) and do have the same problem ??
They added thrill is that these Citizen / Miyota 3510 movements (12 jewels ! 😲 ) are discontinued and apparently (very) hard to get (??).
Perhaps one of those: "There is a thin line between a Hero and a Zero" 😂
Anyhow, without further ado here some pictures of what should be in the post;
Edited by Endeavor
  • Like 5
On 3/2/2024 at 4:46 AM, rossjackson01 said:
Flaming heck!
Any chance of opening the back please? Would like to see the movement.
Sorry, been busy with the day job. Or rather, the hunt for one. 🙂
I order to boycott the Swiss (not really 🙂) I like to try a Seiko (6139-7100). Bit of an iconic 1970's model, nick named "the Helmet". Below sellers pictures and it seems to kinda run ...... according to the sellers watchmaker; ceased due to dried up oil and the seller didn't wanted it serviced, hence sold as defect. Case, glass & original bracelet should be in "super" condition .........
Curious what's under the hood !? 🙂
Edited by Endeavor
What I consider ebay "Paydirt" - taking the back off a watch and finding years worth of accumulation of crud around the edges, so it is as previously worn rather than someone else's failure or Frankenstein attempt they are getting shut of.
And even better when you also find an immaculate movement with no sign of rust or chewed up screws!
Another couple I think are fantastic old ones, from an ebay job lot (under £2 each).
They both look like they have been worn to death, with little plating left.
The "Claridge" one (upper) has the date 1922 (or 23) scratched in the back, and the Ingersoll has 2/48/FW in the back. (Is that when it was sold, or serviced)?
The movement in the Claridge looks like it was a reasonably high end one at the time, from the finish? It's also got quite a fancy dial. That one tries to run, but is very sticky.
The Ingersoll is only a pin escapement type, but it's still going strong with good amplitude!
Edited by rjenkinsgb
  • Like 5
36 minutes ago, ManSkirtBrew said:
I was searching around for a Lord Matic or King Seiko, so of course I bought a Bulova Sea King. 1972, allegedly running.
Not into the bracelet, but definitely feeling the case and dial.
Nice! I'm a sucker for these. This is one from the "President" line and should have an 11AOACB with a quickset date. Now you have to collect them all 🙂
I already have a President "P" and "A", so I'm on my way 😁
Speaking of Presidents, I happened to be wearing one when this guy arrived in the mail. It looks even better in person.
Unfortunately the quickset doesn't work, and it clearly has the wrong crystal glued in, but for the price I paid I'm happy to fix that.
Casio MDV106G-1AV Gold DURO200
I'm going on a long family vacation to Southeast Asia this summer and wanted a cheap but reliable beater in case I lose it, break it, or get robbed. Quartz movements aren't my thing, but I'm not dogmatic and this was a cheap option. A few years ago you could buy it for under $50, but since this particular model with the Marlin fish has been discontinued, you have to pay about double that, but I still thought it was acceptable.
Sure, I could wear one of my cheap and very reliable Vostok Amphibian divers watches, but I have a personal relationship with them (having put a lot of work into them) and don't want to risk losing them.
Strangely, I feel very excited. Maybe because I haven't bought a brand-new watch in over 10 years! 😀
The only downside is that this is the watch Bill Gates has been seen wearing, and I'm not exactly a fanboy of Bill Gates. Anyway, who cares!?
  • Like 7
I just broke my Rule #1 - Do not buy a watch unless you can see a good pic of the movement.
I currently don't have anything to work on (itchy fingers) and as I just got this for £20 from ebay, (sold as "working"), I thought it was worth the gamble.
I liked the look of it, It has 21 jewels, so I'm assuming automatic. The back says "Incabloc" and "waterproof", so it looks to be reasonable quality. The case looks good.
From the little I've found on google, the Credos Lugran company was formed in 1954., and bought by Bucherer in the 60s. This looks 50s-60s to me. There's a reference to using good quality ETA movements. I hope so.
Edited by mikepilk
12 minutes ago, RichardHarris123 said:
Let us know what's inside.
I can't wait to see. I'm hoping for something good. I just hope it's not one of those bleeping FHF 96, as in the Mumbai Specials 🤣
Well it's arrived, and it's a pleasant surprise. A 11.5''' 21 jewel FHF 72. It's running (just) and looks in great condition.  It needs a good service, and new crown and strap.
It's a front loader but doesn't have a split stem. There's a small lever (visible when you remover the bezel), which when moved, frees the stem and the movement from the case (a new one on me).
Edited by mikepilk
The 73 was my setting lever make Mike, same piece fitted to your 72. I enjoyed working on the movement, fair quality.
73 wasn't front loading,but a tight spacer ring that i had to fit onto the movement before casing up. I had to adjust endshake on the third wheel  so apart from the make everthing else was good.
Much like @mikepilk, I took a chance on a movement-unseen Citizen Square Custom. If I did my serial decoding right, it should be vintage 1969.
Some discoloration of the dial, but otherwise looks to be in nice shape with the original bracelet. There's a video that shows it running and the price was right, so fingers crossed.
    • I've bought brands like Citizen, Seiko, Titoni, Tissot, Roamer. Strange thing is many of them were using ST96 movements. I'm not sure if the ST96 is original to that model or whether it was a replacement movement.  All the watches with nice looking dials were obviously refurbished, after-market dials. And all of them had over-polished watchcases. Some of them had non-original hairsprings, rejewelled pallet forks, watch crystals that don't fit and glued in with a generous amount of glue. One of them was totally not working because the pallet jewel was loose to the point that it almost fell off. But the sellers were very nice. The seller of the non-working watch gave me a complete refund. Some of them gave partial refunds. I would say don't by luxury watches on the internet, regardless of the country the seller is from. Don't believe the "serviced by master watchmaker" statement. Have realistic expectations. ( Do expect the occasional complete junk.) Do expect to do a complete overhaul and major repairs. Otherwise, watches from Mumbai are great. For clocks.... I'm not so sure.
    • In 2020,I picked up an Orient Mako II online. It ran at +15 seconds per day and after 3 years of resets more than weekly, it was time to crack the seal and take a shot at regulating it. Not having a timegrapher, I used a spreadsheet to track the time, referenced the Canadian NRC website, wore the watch between adjustments, and used the back end of some tweezers to lightly tap the regulator daily until it ran to within one second per day.   Two months later, it’s still running to within 1 second per day when measured over a week or longer, while daily variations are up to 9 seconds per day. For my purposes, its overall stability is surprisingly good. Is this method of adjustment “better” than adjusting to 5 positions using a timegrapher, since during the adjustment period the watch is already in the environment in which it’ll be used? Rob in Winnipeg
    • Nice file  Just got old pocket watch in and tools,  can I get it back together or should I give up.  we'll see  thanks for the info
    • @HectorLooi Yes, I would say that Mumbai has the highest liquidity in terms used watches. How was your experience with these used watches and what watch brands did you buy used? I have always found the vintage luxury watch segment in India a bit shady. Quite a few are genuine watches with genuine matching parts but just not from the same one.
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
