Cleaning and oiling balance and jewels
For those who use One Dip, how do you use it? Do you transfer it to a more practical jar to use it and then back to original container?
I transfer some into a small glass jar with a glass pipette. Easier to work with that way and can be sealed up so it doesn’t flash off as quickly.
On 3/22/2019 at 2:50 PM, tony1212 said:
Is there a risk that the glass fiber brushes leave marks on the metal parts? How to you use them? Liberally or with specific care?
Yes! I use them to remove rust and corrosion from stems, wheel pinions, and wheel pivots (steel). You have to use them with "specific care" as they can produce some pretty ghastly scratches on the wheels themselves (non-steel parts). I hold the wheels as steady as I can with brass tweezers or in a vice, and then I brush the pinion in one direction away from the wheel towards the pivot. Fibreglass scratch brushes are extremely potent, sometimes too potent and that's why I've just ordered a nylon scratch brush which can be used more liberally and on other non-steel parts but still have a very good effect.
Out of materials of your choice, I make several  golves to pull over a flat wooden ice creame cone, to use as brush on pallet jewels, Your one directional strokes of the brush is A okay.
Sorry ice cream sticks not cones
On 3/21/2019 at 1:40 PM, nickelsilver said:
Benzine won't melt the shellac. Alcohol will, but even that needs some time.
I stick pivots into pegwood or cut the tip of a tooth pick with nail clipper to stick the pivot into, rotate the tooth pick " not the pivot"  repeat , best to soak the part in your cleaning solution.  If the shock system lets, remove the jewel ,enter the tooth pick inot the housing, in which case I rotate the wheel. Soak and rinse again.
On 4/2/2019 at 10:22 AM, mikepilk said:
Worried about shellac dissolving, I tried an old pallet in IPA for 5 mins in the ultrasonic without any noticeable change
I forgot about a pallet in IPA for about 20/30 minutes and the pallets stones came loose, that's why I never rinse the pallets and the roller in IPA for more than a few seconds. Five minutes probably wouldn't do much or any harm, but personally, I just don't want to risk it.
I'm afraid I can't picture this in my head, could you please provide a picture? It sounds very interesting!
Do you by chance mean pith wood? I think quite a bit a force would have to be used to penetrate peg wood (a toothpick would be softer) with a pivot and in my mind that could break the pivot. Or, do you make a super tiny hole in the peg wood first? Or, perhaps the pivot is so small that it can actually penetrate peg wood without any problem. When thinking about it some more the answer is probably yes!? Oh well, I guess I could try it but if you have the time to elaborate I'd appreciate it. Thanks!
I actually prefer toothpicks for pegging jewel pivots as they are somewhat softer than peg wood.  You can develop a sharpened tip with sandpaper or a fine file.  I do sometimes use peg wood as well though.
I use naptha as well in the ultrasonic.  I run thru three separate naptha baths and pith the pivots on wheels, the pallet, and the balance into pith wood for cleaning between bath number two and three.
It works for me but use at your own risk.
RMD
Edited by rduckwor
  • 2 months later...
I picked up a movement from Ebay to tinker with, I think it’s Derby 40. I only have experience with incabloc and this one puzzles me. There is a balance jewel and an endstone but no shock spring so why the endstone?
To clean and lubricate the jewel it looks like I’m going to have to remove the hairspring.
Any tips, threads, articles or videos lubricating this?
Open "boot" on index pins. Loosen stud screw. Remove balance. Remove two screws on underside of balance cock to remove cap jewel.
Oil drop should cover around 50% of the cap jewel. Refer to BHI document.
Thank you for your tips and explanations.
I don’t know how you open the boot. My plan was to loosen the stud screw and slide the hair spring through the boot and index pin to remove it but looking at the picture the hairspring doesn’t go as far as the stud. I’ll have to have a good look at it at home, admittedly I never took a balance apart and I’m not sure how it is actually attached and I can’t see it that well from the picture.
Is the BHI document available to view anywhere?
    • It looks like the canon pinion function is part of this great wheel. The pinion nearest the clip runs the minute wheel on the dual side. The pinion nearest the wheel is driven by a small wheel from under the setting lever cover plate that engages in hand setting position.    So when assembled the crown was driving the whole great train. Does this mean the pinions are too tight? Should I attempt to disassemble this great wheel and lubricants?
    • Picking up this side-tracked post again as I just removed a balance staff of a 1920's Omega (35,5L-T1) I was impressed by the way @Delgetti had his setup when he had to change out a balance-staff (https://www.watchrepairtalk.com/topic/28854-new-balance-staff-not-riveting-to-balance/page/2/#comment-244054 Not only that, but also the idea of removing the seat first before punching the staff out from the seat-side, avoiding the whole discussion of the rivet yes/no enlarging the hole. I didn't have the fancy clamps & tools Delgetti has, so I used my screw-head polishing tool. Initially I used #1500 grit diamond paste on the steel wheel, which kinda worked, but very slow. I changed to #800 grit diamond paste, which worked better, but still slow. Then I glued #240 sanding paper to the steel disk; That worked and the disk was hand-driven. Once close to the balance wheel, I took the sanding paper off and continued with #800 diamond paste. One can only do this when the balance wheel sits true on the staff and has no "wobble". I went on grinding until I saw some diamond paste on the rim of the balance wheel. This was as far as I could grind and it seemed that there wasn't much left of the seat. Carefully, with my staking set, I knocked the staff from the seat-side out. Turns out that the thickness of the seat left, now a small ring, was only 0.1mm. The balance wheel hole is in perfect shape and no damage done to the wheel at all. Of course, if the wheel has a "wobble" or isn't seated true on the balance staff, you can't get as close and there will be more left of the seat. In my case, it worked perfect 🙂 I'm very happy how this method worked out ! 😊
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
