Mainspring winders
I bought mine off ebay, originally i used them just held in my hand, until i got the proxon drill that solved the excess runout that basic dremmel tools have. It was Nev that told me about dentist slotting disks... tbh it's pushing the limits of what a 1mm Swiss screwhead slot should be ( 1mm screwhead not screw thread) , which is more like 0.1mm . -
Can You share what happened? May be there is a solution, it is true for almost all situations. -
Out of curiosity does it have a smell when it's not Deluded?
Thanks to everyone for their guidance. Just a quick update. I was able to pull the pipe off with a standard set of handset leavers; the pipe was to small for the presto lever. I then installed the whole Hour Wheel Counter assembly including the bridge. Went together in no time (bad pun).
