Removing extremely stuck screws
Movement is Omega 1012. I bought this from Cousins:
By Embezelled · Posted
To get the full diameter, I'd have to take it out of the case, which I won't be able to do until the screwdrivers arrive. I doubt that it's much use to you, but the raised rim on the case, encircling what you see of the movement, has an outer diamter of 28 mm and an inner diameter of 24.8 mm. The case outer diameter is 32 mm. -
Yes! The terminal curve shape is key. I struggle not only with shape but also the angle it leaves the stud and the the height it leaves the stud. Since on the NH movements the spring is attached to the stud by friction fit and set by machine it can be off and hard to get right. I find moving the stud angle really affects the coil spacing. I understand how to shape a terminal curve but when you install the spring and cock into the movement if gte spring is tilted up or down how do I get the spring flat? The sling on the left is after shaping and I thought was good but it is way off and required more work. The one on the right is new.
Welcome to the forum. We need to see photos but you're best searching eBay for prices.
