Watch repairer recommendations
I feel I have been a little bit dismissive... For that I am terribly sorry... All my comments were written on haste (I was at work).
Timezone, please accept my apologies! Nonetheless, I encourage you to tackle your 6497-1!
  • 8 months later...
  • 4 months later...
It is not my region. I am in Mid-Devon. You could phone them, just because there listed, as clockmakers does not mean to say they do not undertake watch repairs, at some point I did both. Also they might know someone. What you need to ask is if they undertake repairs on the premises. If you do a google search, as an example there are many in Leeds.
  • 1 year later...
Hi Andy,
There are many people who can adjust a Seiko for you but as you are on here why not learn to do it yourself? As it's only a couple of years old you can get away without a full service I'd guess, but it's quite simple to pop the back off and very slightly move the balance rate adjustment arm to improve the time keeping. :biggrin:
It might not be just pop the back off. The back could be a screw back, in which case a proper screw back removing tool will be required. Anyone who is not familiar with how a watch works should never start to fiddle with the movement and certainly not try to regulate it.
Hi Andy  Old Hippy is right telling you not to fiddle as one slip and its goobye watch hello repair bill. If you are interested in the craft do plenty of reading and watch Mikes videos then practise on some old watches when you understand it a bit better. I have been doing it over 40years as a hobby and still learning all the time.
  • 6 months later...
I've recently acquired a Tag Kirium, probably year 2000, for which I'm buying a contemporary WL1116 electric blue dial, as I'm not particularly keen on the existing greyish one.  There's nothing else wrong with the watch, which has had a fairly recent service and is running very well.
I'm in west Essex, UK.  Can anyone recommend a Tag specialist (preferably close by me) who might do the job and still leave me with a little spare cash to pay my mortgage?
Thanks,
Tom.
Edited by 2131tom
Spelling
There are no "Tag specialists" because beside it being a good watch like any other, the manufactures supplies parts only to authorized repair centers. So either you find one of these on their website, or bring it to a reputable watchmaker. You can use NHI directory for that and ask for an estimate before giving the job. There are various with a web presence, easy to find with a Google search.
  • 3 months later...
Hello to all, I'm new here I discovered Mark channel and realized it might be possible to service a watch by myself :)
I've just finished level 2 and I have a question regarding an AR1010 movement :
I bought a cheap one on ebay and started to stripped it down filming myself under a microscope, the trouble I have is that the microscope is very close to all the parts and now I'm stuck at putting everything back in order.
I'm sure someone here already tried to service that movement and I would greatly appreciate any help I can get to put it back together !
I now have a smaller microscope so will try to be smarter next time (I got an ETA 1258 auto for my next project : Enicar seapearl automatic)
Thanks again for your help and excuse my english as it is not my mother tongue :)
7 hours ago, AndyHull said:
Thank you for this, I've found that before and also a detailed list of parts. Actually I'm looking more for a service manual (dunno if that exist anymore) or the order of reassembly from the beginning. I have the feeling the pallet fork should be placed first (it's secure by a bridge deep inside the mechanism) but it seems strange to me according to Marks video? Thanks again for your help
I have several vintage Enicar, movements are in-house.Based on jules borel, I find that only a few movement parts are nterchange at all and with like omega.
I wonder if more parts are interchangable than what borel says, anyone knows ? Or any other data base?
Hi All
I have a Longines watch with 30L movement. it was running very fast so I tried de-magnetising but made no difference. I have avoided "fixing " it myself for a while but then decided to take out the balance  to see if I  could see any problem with the spring. Now of course it does not run at all. I think the pivots may have broken off the balance staff but that is just my guess.
Can anyone recommend a good watchmaker/ repairer in the Manchester (UK) area?
thanks in anticipation.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
