Bent mainplate
Hello all. I am new to the talk. I’ve been watching the videos for about a year now and look forward to new projects. With that I recently began restoring my first watch. I purchased an Omega 563 movement. I failed to realize the mainplate had a slight bend that caused it to contact the balance wheel. Is it possible to straighten the plate after disassembly?
Are you sure the balance wheel or staff is not bent? I just cant see any circumstance which would bend a main plate, not saying it cant happen but i would think it would have to be deliberate. Maybe previous owner tried to repair and had fit of rage and slam dunked it on the floor.
While anything is possible , I also think it unlikely. I would be much more likely to suspect wear in the hairspring assembly. I think that "debending " a main plate could be very tricky, because it would have to be done in a very precise manner.you would have to locate the exact spot and the exact amount of bend.unless you had some type of die made for this purpose you could make it worse,have you checked to see if the watch will run in different positions? does gravity have an effect?
Can you post a few pics? I agree a bent mainplate would be a new one on me and I have a couple of decades at the bench. That's a really fine movement and while robust in use rather delicate to work on, not one I'd recommend as a first watch.
Edited by nickelsilver
Hi I would agree wit all the comments so far, to bend the main plate would take quite a bit of force and to straighten it out would weaken the plate, But like has already been mentioned what else has been distorted/broken/bent.  As requested by Nicklesilver post some pics and one of the bent plate with a steel rule to acertain the distortion.
If you place the plate on a perfectly straight edge, and see if you can see light through the gap between the edge and the plate, you should be able to figure out if it is bent. Check across various different directions. A bent plate would almost certainly result in damage to other components. A bent gear on the other hand might give the impression of being straight, but the illusion that the adjacent plate was bent.
I think we need some good close up pictures to see what is going on.
Edited by AndyHull
3 minutes ago, rodabod said:
More likely to be a bent cock if anything. Ooh err.
Could be, sounds painful... or maybe  misalignment of screws or pegs, leading to one side being pushed up and the opposite side down.
Pictures.. we need pictures...
Anything is possible. Be sure it is bent and not being kept out of true by a piece of odd debris or possibly some other cause.
Be careful and prepared for it to break, as a worst case scenario. Take before and after pics to share, please.
Good luck.
12 hours ago, Omegajeff said:
I can see the bend. It is very slight but  enough that it is contacting the balance wheel and causing the rotor to not fully spin without binding. I will try and post some pics later tonight. Thanks for the feedback
The balance has a decent about of clearance from the plate and if it is making contact then the bend has to be right at the edge of the movement. Which still blows my mind how it can occur, not to mention if there was something forceful enough to do that then i cant imagine how nothing else is damaged. I would really love to see a pic of this movement. It should be in some kind of medical journal for watches.
Ouch.. I'm not sure if you will be able to straighten that without risking snapping it. Small gentle tapppity tap taps.
If it were something less fragile, I would suggest heating it before bending, but in this case.. probably not..
Any suggestions anybody?
Put it in a vice between two soft jaws maybe?
I guess just enough unbending to stop the balance rubbing, then test, if still not satisfactory, then just a little more.
Edited by AndyHull
Ok...here is my blasphemy....the plate is buggered.. it  may or may not snap back. It may snap  off! It might  cause  more damage  and make the  watch inoperable  all together.  Option  one replace  the main plate ,this would be preferred..option  two..attempt  to straighten  bend..option three relive the plate of the damaged  area..take a file to it.very judiciously  file away the distorted  area. The balance  wheel  will turn and the watch  should  work. This of course  should  be your last ditch  option. The absolute  last resort.. but  in my opinion  if you really  want  to put that  watch back into service  ,it is something  you may want to consider.
Edited by yankeedog
I was able to put it in a vice and straighten a good portion of it. The balance moves freely now and the rotor spins. To my dismay the wheels were not turning. I found the fourth wheel seized in the bridge. When I tried to remove it, snapped clean off.
I checked the wheels before straightening and they did not move. At that point I figured, just do it and inspect later. All other wheels move freely. I ordered a new 4th wheel and am working on getting the pin out of the bridge. I am also stumped with the dial on this watch. Seems to have an old steam crane logo on the bottom. Haven’t been able to find any information. Looking through the loop it doesn’t appear to be added later on. Smooth on the dial.
    • Post some pictures , some good close ones of the parts you've described.
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. If its a potential problem for amateurs to use then i would prefer not to take the risk .
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
