Thanks oldhippy, this is my "Jack the Gripper" in the photo - can I use this shape of "fingers" for real glass as well? When tightened too much, it grips so hard that it punches holes into the side of plastic crystals :)
Can I use this tool for domed real glasses?
PS Yes, I have a useless chinese as well, it has lasted for 10 watches, now every crystal slips out of the fingers.
Edited by rappeleur
If it punches holes in the glass I don’t think you should use it. For fitting you need the platform it makes it so easy for the tool to get the correct depth when picking up.
So... There is no way putting my glasses with my tool into place. The mounting device is too high, the glass doesn't stand high enough for gripping.
But even when picked up from a flat surface, the tool always slips from the glass. The glass has a tilted border (see photos).
Wrong tool / wrong glass /wrong technique?
Think there is a misunderstanding of the tool required here. Firstly "Mark has done some great video's on the removal and fitting of various crystals. Suggest you look them up on YouTube.
It's inappropriate to use an arcrylic crystal lifter on mineral or sapphire crystals.
Why have you only flat dyes ? Even inexpensive case and glass press tools come with a selection of dyes, including concave dyes suitable for domed crystals. The problem today will be obtaining jumbo dyes for the modern larger watch but they do come up for sale on various sites.
Sent from my SM-T585 using Tapatalk
Yes, this was just what I was thinking! I only have flat dies because I have not bought a better set yet :) hence my question, which one to buy. Perhaps I misinterpreted the above suggestions for my crystal-tool.
I will have a deeper look into techniques and dies/tools.
Thanks so far!
old hippy is right, but for clarification high dome acrylics = crystal lift, low domes = press, but the method is different from pressing a mineral/sapphire/tension ring, with a low dome acrylic you basically have to use the dies to make the crystal curl in on itself slightly, then slip the case/bezel into position and then release the pressure so that it locks in place to the bezel/case. It's probably been properly demonstrated or explained somewhere around the forum before, but i could just imagine someone trying to puzzle that out from scratch.
I'm a very new beginner hobbyist.  Would this low cost Chinese tool work for removing/installing crystals and pressing on case backs?  Anyone have one?
Thank you
I would say buy the blue one that actually has the shape of a press. This one can work but if you press too much, since it's a cheap one, it'll break and you might just break your watch as well.
Stick to the blue ones that cost 15$ or whatever... They're not as good as the original ones in that you might get one that is slightly misaligned (from what I could read in some comment) but it'll be better than this one.
i do not recommend this type because the force is not between pillars and it will lose plane under medium pressure. If you want a screw type make sure that isn't so.
I purchase a cheap one ...It did work fine the one time I used it ..I'll enclosed a picture at bottom ...Which one would be a recommend unit if not the one I already have.
That is fine because the cast construction is not subject to distortion, and being of the lever type it allows better feeling.
Often what makes the difference is having the correct dies in terms of shape, size and material.
Thanks...there is one thing I don't like..depending on the watch if I screw the dies all the way in the dies do not reach ..I put a nut and washer on to extend reach but haven't tried it yet
Sent from my SM-G955U1 using Tapatalk
  • 2 months later...
This is one type I had. https://www.cousinsuk.com/category/press-dies-robur   expensive used for fitting tension ring glasses
As near as I can find of another type I had for tension ring and flat
This very good glass lift and fitting tool for high dome glasses
Beware of cheap Chinese types. You know they won’t last because of the price. Good tools will last you a lifetime.
We have a lot of people here using hand held and bench Chinese presses. No reports of breakage or other problems, generally these are great for beginners. Isn't always necessary to spend a lot on tools. I have an Anchor copy of MKS screw type, works good and has a sturdy build, link is a previous posting in this thread.
For the ease of finding info I have merged various threads in a pinned topic.
Some generic postings moved to another thread. Please stay on topic: Crystal press advice
  • jdm pinned this topic
  • 4 months later...
Has anyone ever used a case press like this one:
https://www.ebay.com/itm/GF8721-Snap-Back-Watch-Back-Case-Press-Spiral-Type-Closer-Tool/142877470395?hash=item2144292ebb:g:EwkAAOSwczhbU1CG
It looks reals sturdy from the pictures, but i would like to get someone's first hand experience.
  • 8 months later...
My experience with the cheap Chinese crystal presses is very poor. I ended up buying a Bergeon No 5500 and I'm remarkably satisfied with it. I recorded a video of the very first time I used it and you can see it via this post.
36 minutes ago, DavidMasters said:
I have the following one at link, or it's similar—lots of knock-offs from China. It beats spending hundreds if this is a hobby like it is for me.
This is a cheap alternative that works very well.
I don't recommend that one, because the pressing force is not in between the pillars, so it tends to flex. Better to have cast strong body as others that were featured before.
Bergeon or other guality crystal lift do not scratch ths crystal.
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
