Watch of Today
mk3
@GeorgeClarkson A while ago I opened a thread "Genuine "Leather" watch straps". I plan to continue as soon as I get to it. I did build already a stitching pony, which I will explain in the thread. I ordered already needles, pricking irons, awls, various colors of waxed stitching thread and other small stuff required. You don't need a lot to get started. The Nato strap turned out reasonable good, being my first object, but I like to improve on the saddle-stitch. I also made a few key-pouches like the ones on the picture and they turned out fine..... for a beginner that is. It's a skill and it takes time to perfect.... like with everything else B)
If you are interested to learn about leather craft, I can highly recommend you to visit the YouTube channels of these two "top-notch" craftsmen:
Armitage Leather : https://www.youtube.com/c/nigelarmitage/videos
Ian Atkinson: https://www.youtube.com/user/satansbarber/videos
I can only say that it is a very fulfilling hobby :thumbsu:
Edited by Endeavor
And a very nice friend she is too :D Crisp Clear and Colourful
Past few days been wearing this 70's throw back >
I rarely endevour to repair quartz watches but this was presumed dead and sold off very cheap. Luckily i checked the basics, removed and cleaned contacts, checked battery, fitted new battery, and.....tada. Photos don't really show it but the watch is immaculate :)
Very Nice , I really like this one .
A converted Hamilton for me today.... This is the "Registered Edition" Piping Rock that had a Hamilton Quartz Movement in it until yesterday when I exchanged it for a Hamilton automatic movement .
  The new movement did not come with an hour wheel so after not being able to find the proper hour wheel for this movement , [yet] , I went rummaging through some old movement watch lots I have had for about 4 years . These junk movements were sitting in the back of a drawer , and there were bits and pieces from different watches with names I had never heard of . There were several hour wheels so I figured I had nothing to lose by trying to fit them to the Piping Rock movement .
Would you believe one of them fit the cannon pinion and mated with the minute wheel . I was looking at it and I couldn't believe it .
 The hour wheel was .06 mm too tall , and the O.D. was a skosch larger than the hole in my hour hand . I carefully filed the hour wheel down .06 mm and finished out the rough edge with a sanding stick . Then I very carefully broached out the hole on my hour hand and fitted it . By another stroke of luck the winding stem with the crown from my quartz movement fit the automatic movement to wind it and set the hands , but the stem from the auto movement is a tiny bit too big to slide into the quartz movement ,....I'll use the quartz stem with the crown attached as the length is correct .
The watch has been running for about 8 hours so far with no problem , but I'll wear it for the next couple of days and see if it makes it through the trials .
I've attached some links at the end in case anyone is interested in a little history of the Piping Rock .
http://www.hamiltonchronicles.com/2012/09/1928-piping-rock.html
http://www.hamilton-museum.com/museum
http://www.vintage-hamilton-wristwatches.com/2015/03/hamilton-piping-rock-registered-edition.html
11 hours ago, clockboy said:
Found this at ranfft & I have circled the interesting part of info. IE perhaps it was made for either quartz or mechanical. The link I found it from is below. A good result Richard.
 http://www.ranfft.de/cgi-bin/bidfun-db.cgi?00&ranfft&a&2uswk&Hamilton_53
Aloha Clockboy , If this is in reference to my Hamilton Piping Rock , you've circled the mainspring which of course would not be used in a quartz watch ,
My new Hamilton automatic movement is stamped # 889 on the bridge and stamped # 138.001 [FHF I think ] , under the escape wheel .
I am searching for the hour wheel . Boley listed it as part FHF # 250 , which I ordered , but it is too small and does not mate with the minute wheel . Jules Borel lists 2 hour wheels for this movement , 250/1592  and  250/1593 ,...the difference being the height of the hour wheel tube .  I am reluctant to order this part as it is also a #250 which had proved to be to small . I will call jules Borel and inquire if their # is also a FHF # .
Mahalo , Louis
Thanks for the help and Info Clockboy .
The parts list shows Hour wheel P/N 250 for the 138.001 which I ordered but does not mate with the minute wheel . The other hour wheel is for the sister movement  138.011 that shows a double toothed hour wheel . On other hour wheels I have seen listed for the 138.011 they were not double toothed but a bit higher tube but still had the P/N 250 assigned to them .
I wii try to ger more info on the dimensions of the double tooth wheel although I don't know what the top gear would be used for ......On second thought , I think the second gear is for a date wheel on the 138.011 .
Thanks , Louis
Edited by ricardopalamino
I am actually wearing it, but that is not a picture of my arm! Stainless Steel 1970's Bucherer Automatic - ETA 2824.
28,800 BPH
Quickset date
Second Hack Feature!
I have a real soft spot for Bucherer. I've got a broken 1980s quartz on my work top I keep meaning to do something with
    • I was wondering whether anyone could assist with some questions I have about my latest acquisition, which is a two train ‘Bravingtons Renown’ mantel clock - Pics attached I have done some reading about Bravingtons and believe they sourced movements from various suppliers, so I wondered whether anyone recognises this one. I have stripped and cleaned the movement and the clock is now running well, but there are a couple of dodgy brass springs that I would like to replace. I haven’t found anything suitable searching the internet so I wondered does anyone know of a supplier that might help. Last question is about the veneer on the case, it is generally in reasonable condition but there are a couple of patches on the top where the veneer has lifted. So far, I have tried to reactivate the existing adhesive by heating from below and above with a hair drier, then clamping for a day or two. It has improved slightly but the bulge is still visible. I’d be grateful for any advice if anyone has dealt with this sort of repair before.
    • Hi some pictures o& the movement and case would be appreciated so we can ascertain what the problem is you are having in fitting the movement.   Thank you.
    • Thank you very much,T. I'll try turning the arbour from the clock face end very carefully in case I haven't reassembled the suspension block correctly (I had to make up a suspension spring using remnants of a broken one as I haven't been able to find an exact replacement online).
    • Hi murks a picture of the front as well would help,   By the size of the plate it was stuck to I would suggest a coin cell,  2030,  2015 all depends on the height of the cell. And the space when the back is fitted.         3 volt.
    • We seem to have gone a bit quiet on this ?  Do we all agree to ask Mark for some input on this matter, or is no-one really bothered.
