Watch of Today
mk3
43 minutes ago, noirrac1j said:
 Oh one more thing... you cannot take the circuit board off until you remove the hairspring and vice versa( first replace board on, then hairspring).
P.S. Also, use a new battery!
J
JC
Sorry, remove the board first THEN  the hair spring. Afterward, replace the hairspring then the board.
6 minutes ago, noirrac1j said:
So sorry! everything OK?
J
I'm sorry myself, was a poorly timed joke there;)
On the plus side, you're right; this watch is keeping time within chronometer specifications! +4 sec in 24hours!
Edited by jeffc83
I wore this today:
a9505d87c3a5782526a45c90ff9908bb14204398
It's my "f@rting around watch".  It was so cheap to buy that if it gets clobbered...no matter...just buy a new one.   The remarkable thing is that it keeps good time, both analogue and digital.  (You can see I like Chinese junk...sigh!)
I'm stuck inside for another week with doggy who is recovering from her ACL surgery.  She plays me like a fiddle.  A whimper gets immediate attention.  A raised front paw gets an immediate pat and a scratch of the ears and a shrill bark means, "Take me out for a piddle, dad!"
You can see that I love my dog!  She will be inside until the stitches come out and even then her walks will be much shorter for about two or three weeks.  Big operation...big cost...$AU3,500.  But she's worth every penny.
@stroppy Hope the surgery goes well!  I can see she has a great owner that cares very much for her so either way, she'll remain happy!  I love beater watches...yours is no exception!
@tomprobkins Amazing, I love it!  Well done sir:)
Today, I had a meeting so it had to be a good one: Eberhard & Co Postillon 8 Jours (love this watch, the lume is nothing short of amazing)
Edited by jeffc83
Could not decide which one to wear, feeling a bit nostalgic, this is or was the 'digital' age. I stuck with the Casio, (I hear you laughing, water resistant to 100m!). Citizen multi-alarm way to complicated for knocking around.DSCF0147.JPG
I have a almost pristine example of one the watches you show (to the right) here.  The only blemish is a slight scuff across the glass lens which, I assume would be easy to polish out with some cerium oxide.  Now don't go throwing that watch away because, apparently, early Citizen LCD watches are now getting a pretty packet on the bay.
    • That's the right technique Mal đź‘Ť If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
    • Hope you mum keeps on mending. I was adamant that I was going to get myself going after my stroke. I was only 52. I still have a lot of life left to live. Some people give up. Some people don't let it beat them. Your mum sounds like one of the winners. 👍
