Tools you can't live without?
FLwatchguy73
Good morning folks. If you had to recommend 2 budget conscious (under $300) tools to a hobbyist watchmaker what would they be? I already have the bare minimum hand tools necessary to do the work. There are so many tools I'm sure I could find useful occasionally, but what would be 2 tools you would be lost without, other than screwdrivers, tweezers, movement holders, timegrapher, etc. Thank you.
     save the 300 bucks  and search for used tools.  a book by de Carles at the library might be good.   vin
Above lathes are recommended but the OP clearly stated he's asking for tools under $300. And he mentioned ones excluding a timegrapher, which I suppose he already have. So I can recommend budget good opening tools as discussed below
And then a pressure tester, which is around $150 on AliX.
Its very sad but as you get older your fingers aint the same...I don't think I could do without a selection of those grab claw crown winders which keep my hand wind watches going especially when the crown gets a little worn. Perhaps I should just stick to automatic watches
I have definitely encountered the need for a good opener. I was servicing a vintage Seiko 7002 diver for a friend and I nearly couldn't get the back open. Are there tools that make opening snap back cases easier? Knife blades are terrifying to use but occasionally that's all that will work. Thank you for the suggestion.
    • As Richard said, this is a really old school trick for joinery.  Cut i strip of paper, might need to be watch paper  around 1 " x 1/2" lay it over a staking block then press the stud screw into and through the edge of the paper upto the head of the screw. You probably wont even need to pull the paper away the head will pull itself through.
    • Thanks Jon, my mum is getting there day by day, so strong and determined, they dont make em like this anymore 🙂 Old folk are so amazing,  my mum used to love her golf, she didn't stop playing until she was 70 . Enjoy your trip and your golf.
    • Hello,  i am looking to source a winding stem (winding arbor) for a waltham 6/0 d movement. I have found some that claim to fit 6/0, 6/0s, 6/0b etc and somealso claim they will also fit the d as well. The d does have hacking which is driven by the stem seating completely. Given some of the costs of these, i was hoping someone would know of any interchangeability with a source, or know a source where a confirmed 6/0 d stem can be had. I am in the US so a US dealer is best.    thanks in advance.
    • So great to see and hear- your mum looks great! …my mil had a stroke last summer in the golf course parking lot. I’m flying out tomorrow to visit and play golf. she’s ornery because she can’t get off the tee but I hear she makes up for it on the greens since she’s been putting since a week after her stroke 🧐…
    • Very best wishes to you and your family, as a carer myself I know how difficult things can be.
