Good morning folks. If you had to recommend 2 budget conscious (under $300) tools to a hobbyist watchmaker what would they be? I already have the bare minimum hand tools necessary to do the work. There are so many tools I'm sure I could find useful occasionally, but what would be 2 tools you would be lost without, other than screwdrivers, tweezers, movement holders, timegrapher, etc. Thank you.
     save the 300 bucks  and search for used tools.  a book by de Carles at the library might be good.   vin
Above lathes are recommended but the OP clearly stated he's asking for tools under $300. And he mentioned ones excluding a timegrapher, which I suppose he already have. So I can recommend budget good opening tools as discussed below
And then a pressure tester, which is around $150 on AliX.
Its very sad but as you get older your fingers aint the same...I don't think I could do without a selection of those grab claw crown winders which keep my hand wind watches going especially when the crown gets a little worn. Perhaps I should just stick to automatic watches
Mine would be my Dumont 3C tweezers. I have tried pliers with very limited success. And as oldhippy points out, a good eye glass to see what I am ruining with my Dumonts...:(
Ron
I have definitely encountered the need for a good opener. I was servicing a vintage Seiko 7002 diver for a friend and I nearly couldn't get the back open. Are there tools that make opening snap back cases easier? Knife blades are terrifying to use but occasionally that's all that will work. Thank you for the suggestion.
Yes and you will find these in the topic linked above.
