Measuring watch Hands
You can do a quick search of the internet, you should use the following site to find out movement specs,
www.ranfft.de
from this site I see that the hands are hour 1.50, minute 0.90, and seconds hand 0.21
A close match to Hands of the style you need are available from various sites, www.cousinsuk.com stock this style but the centre seconds hand with square luminous tip may be a problem to find.
Thanks, I found the www.ranfft.de site but it listed the 25 jewels and not 17 jewels of the movement so I was not sure if this was the right hands size. Should I buy and take the chance?
Yes IMHO ... Different variations of a same movement often wear the same hands.
BTW what happened to the dial ?
It looks like somebody stripped all the lumed parts off [emoji39]
Envoyé de mon Moto G (5) Plus en utilisant Tapatalk
My friend tried to get the parts and lost the energy, so I took it. I am not watch expert but I thought if I can get some advice from the community I might be able to atleast get hands and see where we go from there.
Do you know if these lumed parts can be fixed? I am sure it will need a service too after the hands are added..
You measure from the centre of the dial outwards to about 2 thirds over the numbers, make sure you leave enough room for the hands to go round, you do not want them catching on the inside of the glass.  Then you pick a style and colour that is suitable to the dial and case. If that is the case you want chrome or silver looking.
Hi, Thanks for the help. The picture, video of the movement outside of the case with new hands installed.
I ordered the hands day before your comment, it seems I ordered a little longer based on your comment. I will check the size again and get shorter ones. Next step is to add back to the case and see if it still works.
IMG_1803.MOV
10 hours ago, measuretwice said:
I saw that too and notice the OP's shown above also has Wimding.  Is this a "thing"?
LE JOUR being a swiss company possibily, it's possible that the guys that designed the dial where french speaking.
I'm French and I COULD write wiMding instead of wiNding ... an error that a native English speaker wouldn't do.
Look at the the "spatiale" and the "grands fonds" ... the dials are "french" and there is no misspelling.
zrc-spatiale-300-m-brevete-sgdg-ref-02059-vers-1968.thumb.jpg.44b4818de3b89f583fbd25e927dd4dc9.jpg
Edited by manodeoro
IMG_1803.MOV
The hour and minute hands are not only too long but :
- they are too thin
- the are not squared at the end
- they lack the "contrepoids" (I'm not 100% certain about the english term but I would write "counterwieght")
Look at that pic
The hour hand and minute hand should be the same width, the couterwieght are about the same length.
The only difference is the length of the part that hold the lume.
I wish you good luck in your research for the right hands, because you'll need some.
Here's a pic of a ZIM watch with hands that are more similar to the hands you need (you still can rework them a little and paint them black).
ZIM 2602 hands are : Hour 1,60 - Minute 0,88
PUW 1463 hands are : Hour 1,50 - Minute 0,90
So if those hands are OK about the length (just ask the seller) you can close a little the Hour hand tube and open a little the Minute hand tube.
The seller is topdom789 and he's a really nice guy (old horologist from Bulgaria).
I bought 2 Raketa movements from him last year ... I paid USD10 only for the 2 movements and he serviced them before shipping.
If those hands are too short or too long you can tell him what you need and he'll search if he can find hands that match your needs.
Hi, Thanks for the help. I am new to this forum, how do I find the seller "topdom789"?
Search topdom789 on eBay.
Petar is a nice guy and always ready to help if he can.
Hope this help and have a nice day
  • 1 year later...
There are hand gauges for measuring the pipe, The Bergeon one is sold by cousinsuk around the £40 mark. or alterativly visit the esslinger site in the USA they have very good tutorials one specificaly for measuring watch hands  and many more instructional files as well.
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group.
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro. I thought the idea was for the epilame to create a barrier, a wall between the lubrication and anything else, so the lube cant spread.
