Sticky hairspring; how to demag and what does the hs alloy do?
If you use your brass tweezers to hold the escape wheel by the pinion, can you turn the wheel with your fingers? -
Of a pivot is broken and they are not engaging. -
That means that the escape wheel's abor is loose. The wheel remains stationary while the pinion is spinning. -
I decided to give it a go. With the hope I can replace the missing pieces. Fingers crossed 🤞
