I just got one of those Accutron astronauts as well and I love it. It runs a little fast, but I understand that it just means it needs to be adjusted for the higher voltage off modern batteries. Maybe I'll find someone to do that this spring. This is my current daily though:c9b3b9b3529462487ff62df511c1d3d2.jpg
Sent from my ONEPLUS A5000 using Tapatalk
Hi , ..Nice Hamilton . Looks like my X-Wind .
As far as the Accutron running  fast , you are talking about phasing the watch to run on higher voltage batteries . At 1.5 instead of 1.3 volts .
You may want to try an accu-cell made for this . You can try one ,...as they are more expensive , to see the outcome .
Wearing a Seiko 7546-605A.. It 40 years old but doesn't show it's age.  I'm quite familiar with Seiko watches but I figured it was from 1988 until I checked on the web.
Pretty accurate like all 75** movements. The dial appears light silver from some angles and a darker shade from another.  Water resistance isnt mentioned anywhere but I figure it's 100m like other non screw-down crown watches from Seiko.
IMG20181115085128.thumb.jpg.a11f94323d6db31275be0a4eb25ac470.jpgIMG20181115085132.thumb.jpg.7924819c8532e8a183d6b2112910eb0a.jpgOK
interesting you say that because it was the one that took the most work to restore.
I had to swap out the balance as the final step to the movement.  When I had it all ready to get back together I cracked the crystal :(
Nice and Very Clean looking .   I'm not a big quartz fan , but Seiko did it right with selections of this era . I'll take a Silverwave anytime .
2 hours ago, noirrac1j said:
Ooh nice @ricardopalamino. I was wearing my Bulova 666 the other day. Today I am wearing Basis Sapphire beach 17 jewel watch with tachymeter markings  on bezel but a plongeur sweep hand --It has a bit of an identity problem!
J
Nice ,...back at'cha .
Who cares if you  have an Identity problem , as long as you look good .  Especially with a sexy bracelet .
I've been trying to get a Speedmaster since last year, but finances haven't been cooperative! I like the Mark II a lot. I am guessing yours has the manual winding cal. 861?  I want one!, but just have to figure out a way to get it!
J
J
You are correct on the movement .
I installed a new crystal when I first got it . The crystal has a groove on the side where a rubber gasket is fitted .
When I installed it , I didn't know that there is a special compression tool that Omega has to install this crystal ,     so I was sweating bullets until I got it installed ,...since the genuine Omega crystal cost me  $100 .
Just off the bench - 1963 Timex Electric -
Needed some TLC.  Missing battery insulator, crown screw washer, sticky set lever , scratched crystal.
Serviced, lubed, buffed and added red nail polish to replaced the cracked and aged lume.
A very 80s Citizen 21 automatic (August 1982), keeping good company (and so far good time) with my white Seiko 5.
The Citizen is much cleaner and more hygienic than it was this morning, and running quite nicely too after a little TLC and a good polish.
I resisted the temptation to try to hide the marks on the dial as I am pretty certain I would "fix it worse". I did remove about a metric ton of grime from the thing though. Both are members of the 404 club (see elsewhere for an explanation).
EDIT: I've just noticed I've set the Citizen 5 minutes slow, due to the rather confusing dial markers. :huh:
Edited by AndyHull
Battery arrived, so today is a Citizen day. I'm not sure if this 3801 calibre is from November 1985 or 1995, my gut feeling is 1985, but I'm sure someone with a little more knowledge will put me right.
(Ignore the arm hair shadows on the glass)
The rather obvious  "double ding" in the glass shows up rather well either side of the second hand in this picture. There are one or two other battle scars consistent with age. It may be no great looker, but considering it only cost £0.99p plus postage (the battery cost more than the watch), I think its not too bad.
I guess that is more of an indictment of our throwaway society than any failing of the watch.
It is a nice classic  , clean looking watch .  I agree with your thoughts on becoming a throw away society .
I feel that so many quartz watches that end up in dresser draws are an example and victim of that attitude .
I vote that you find a new crystal for that puppy .
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
