Watch of Today
mk3
Very wet weather here in Kuala Lumpur over the last week.  Since my transport to work a motorcycle I've been using my newer water resistant watches.
Today it's my Seiko 7s36-01E0, or more commonly referred to by the cognoscenti as the 'Atlas'.
Too chunky for other days but fine for Friday's.
Have a good weekend guys
Anilv
17 hours ago, ricardopalamino said:
Not sure what you mean by your statement of , "  I ruined for myself by hyping it up to much."
Clean looking watch though .
I should have explained that better. Essentially before I got it, given the history (Scandinavian, aviation, design and horological) I built it up in my mind and it got worse as I serviced it, everything in the movement just seem to be designed so well. But when I put it on my wrist it just cant live up to that impossible image. :)
Onward to a watch that did the opposite. My first impressions of the Alpinist was small and dull. But it really grew on me and the dial/handset combination plays with the light just beautifully.
Picture reflects the Swedish weather quite well, grey and cold.
12 minutes ago, digginstony said:
I've fallen for this mid-size Spinnaker. Fitted with the Seiko NH35 movement. Seeing as it's a "Keeper" I've corrected the beat errorbed7a6434d310909faaebcf335b12572.jpg2165bdc7b4874507d57c5bba376844c3.jpg4d8545fdba8a81c2af5f635007438a67.jpg
Great numbers--You've done a good job of regulating it. What does it look like Crown down as in the pic with you wearing?
J
Joe
1 minute ago, digginstony said:
Not sure. Watch taken off wrist and given the Seiko shuffle for a minute or so and then left for about 10 minutes
Right...Seiko's are fully automatic for winding. Looks good then. Amplitude would probably go up with a day or two on an automatic winder.
J
    • Hi to Blackminou29–am a collector/ caretaker—good luck to you following your repair course—with hindsight I wish I’d pursued a career in both watchmaker/ jeweler fields—good luck with whatever career passion you engage.   Thank you Watchweasol for posting the amazing TZIllustratedGlossary! Best wishes, Mike
    • yes I noticed the new site and I miss the old site. It's the unfortunate problem of the Internet here today gone tomorrow sometimes some of the stuff gets backed up and sometimes well it does not then the problem with the early Seiko's were there were not necessarily designed for distribution across the planet and as such there is no customer support for them. So trying to find early stuff like technical information or sometimes even parts list for older Seiko is is problematic. But I did find you a you tube video. A quick look he seems to take a heck of a lot of time to actually get to the service single I did not watch all that but it does look like he did disassemble or started to say there's a tiny bit here
    • RichardHarris123: Hello and welcome from Leeds, England.  I have family all over Australia, went as £10 poms Thanks Richard. Hope you’re able to visit your family here and that they’ve all done well 🙂 My relatives arrived from England in the 1790s transported on the ‘Second & Third Fleets’—a story of timber sailing ships, of convicts and doing well in this huge Country of Australia. When I visited the UK in the 1980s, I was too young to comprehend the depth and breadth of its history…  Best wishes, Mike William Chapman, my 4th great Grandad’s charges, at age 23 read at the Old Bailey; sentenced to 7 years of transportation to Sydney.
    • The whole process and the progress are closely observed, it's hand-driven and very controlled. I can't see the "danger", unless you are watching the TV while doing it. As you could have read, and in this quote "wheel" is the balance-wheel.
