Watch of Today
mk3
6 hours ago, stroppy said:
So many jewels!  Does the jewel count make this watch exceptionally accurate, robust and immune to temperature changes?
One would think so but unfortunately not. (for the most part, some can be functional) During the 60's, watch companies were adding more jewels to their watches to "one up" each other in order to gain sales.  This Benrus has 39, 17 in the Movement and 22 in the reverser wheels. (11 in each)  There has been lots of discussion in the past on other forums about the extra jewels being functional. In this watch, I have to say no after looking at it but I could be completely wrong.  @Mark, what's your opinion on this?  How in the world should I attempt the service? ;)
I also have a Waltham 100 in my collection, which is the coolest yet biggest joke around in terms of functionality....it contains 83 useless, highly decorative yet REALLY COOL jewels underneath the edge of the weight.  These watches represent an interesting time in our history:D  I'll be wearing it Monday, will try to remember to snap a pic of both the watch and movement.
Edited by jeffc83
typo
But to average Joe in the jewellers of the time when he whipped the back of and said look at all those jewels its the best thing since sliced bread the person buying would have been amazed. And in answer to your question about alarm movements  noirrac1j I've worked in both the Lucerne was a nice simple pin lever movement the sekonda was a Russian movement which Stefan (svorkoetter) did a fanrastic walkthrough on i only wish hed done it earlier I would have known what to expect and his is much nicer one cosmetically than mine .
18 hours ago, Cad101 said:
It's a loud buzzing noise but it takes you by surprise I have a Lucerne alarm with a little bell inside that's quite loud when it goes off still trying to find a second hand for this one tho.20160514_203510.jpg
I think this old Sindaco-made watch (being sold for parts on Ebay) may have the second hand you are looking for:
http://www.ebay.com/itm/Vintage-AlanJack-Watch-1-Jewels-Stopometer-Swiss-/351723081948?hash=item51e45450dc:g:gdgAAOSwKfVXJ6Pr
Hey Cad101 what's the caliber on that alarm? I might have a sweep second hand for that alarm...maybe gold or possible stainless.
JC
1 hour ago, stroppy said:
Another pin lever, I bet! :)
No, it's a jeweled lever! You might be able to just see the pallet jewel in the pic.
 I went through a whole alarm phase where that's all I worked on. This one a 17 jewel Ronda 1243-21. There are other Ronda movements that are one jewel--those are the pin levers.
JC
2 minutes ago, ftwizard said:
Today is Accurist day. A rather nice number, picked up for around a Tenner. Just polished the crystal and it looks great.
Just a couple of cracks in the glass, but I'm OK with that.
ice
That's very nice with Roman numerals at 12 and 6 only...clean and classic looking. British make?
JC
This was a mod I did a few years ago.  Seiko 6309 7040. Check out the second hand you aviators.  It was one of those bits and pieces,  junkyard builds.  I actually wear it a lot as its a bit of a favorite, fits good and is very comfortable to wear.  I just serviced it recently and it's running very nicely.  Not bad for a watch that serials from 1980.
I just finished this today,  7S26 0020.  It's been sitting in my parts bin for a couple of years after I picked it up in a second hand shop.  A fairly extensive service (oddly I found a scored end stone!)  and a bit of a face-lift and this old Pepsi is looking and running  real nice.
1 hour ago, tomprobkins said:
This is one I am really proud of. It was a gift / trade. A 1940 Omega with a center sweep second hand train added on to a 15 jewel movement. Simply beautiful.
So clean and uncluttered..the beauty of form following function...and its Omega!
JC
7 minutes ago, tomprobkins said:
This one feels bigger than it is. It is only 30.5 mm, but it feels like about 34mm on the wrist.
That is just my size too;)  For some reason, some DO look bigger than they are on the wrist, especially from this era!  Again, beautiful piece!!!  I collect these so it's right up my alley:D
Edited by jeffc83
    • Lots of rust on that hairspring Nev, would you even try to clean it up ?
    • How do you find the working distance from microscope lens to movement? Is it comfortable enough to get tools in?
    • Once you have the collet closer bits off, and the pulley off, there are two nuts on the spindle. These must be removed. There is a large nut in the back of the headstock with two holes, remove this with an appropriate wrench. The front large nut comes off too. The spindle now comes out- but wait- there's more! There is a spacer between the outer races of the bearings; the spindle will almost certainly come out "assembled" with both bearings and this spacer (it can actually come out front or back-ways with the large nuts off the headstock). You have to manage to press out the spindle from the rear bearing, get the spacer off, then remove the front bearing, now you can get to the key.   Imagining you get it all apart without causing any damage to the bearings, now the fun part starts. You must apply preload to the bearings, and this is a very tricky endeavor. Basically once you have the bearings back on, and are in the casting, you snug up the rear nut (one of the two) on the spindle, checking the play of the spindle with at least a 0.002mm reading indicator, until there is zero axial play, then just a little more, then snug up the second nut to lock things in place. Of course snugging up the second nut influences the preload, so you can go back and forth a few times to get it right. Too much preload and bearing life diminishes, too little, and you get poor performance, poor surface finishes, ball skidding, etc.   When I replaced the bearings in one of mine many years ago, I was surprised to find that the bearings were regular deep-groove bearings, but of a higher precision class than normal. I replaced with dimensionally identical angular contact bearings, class P4. In trying to set the preload, I just about lost my mind, so called Barden (the high precision arm of FAG bearing makers, and who made my new ones) and a nice engineer told me that the folks at Leinen were either crazy, or really good- he also said it's 100% A-OK to set up deep groove bearings with preload like this, but best is angular contact. In this bearing setup, the standard way to do it is to have a spacer between the outer races, and another between the inner races. Leinen has the former but not the latter, haha. His advice was to make an inner spacer. The trick is it has to be the exact same length as the outer spacer, within like a micron.  Then you just tighten everything up and the preload is set, because the bearings (the new ones) are ground in a way that they have proper preload in that situation. Easy. Sort of- if you have the means to make the other spacer!   Just to note- Schaublin does the preloading as Leinen did on these on their lathes using angular contact bearings. There is a procedure in the manual, where you tighten the nut until axial play is zero, then a certain number of degrees more. This works on their setup as the nut itself locks without a second nut, and they spent the time to figure it all out in a repeatable way.   I say all this not to scare you off from dismantling your headstock, just to give a heads-up what you're up against to get it back to where it was before.
    • Do, write a nice letter to Santa. I do all disassembly and assembly under the microscope. I consider it a necessity.
    • Yes Breguet overcoil, and A is OK, the damage is from B to the end. It should look lile this. The studd is fixed by the screw head into  the cut.
