Watch of Today
mk3
Wearing my 'new' Movado today. This arrived from the 'bay with a movement that was superglued together, but the dial's in great condition. The only useful bit of the movement was the setting lever spring, and the only thing missing from the donor movement was the setting lever spring. I love when that happens.
Happy Christmas, all.
post-148-0-82141900-1451214489_thumb.jpe
  • Like 6
here's what i have been wearing today. a hand winder, 1964 seiko sportsman. it doesn't get much wrist time. but it did today. i took it off long enough to regulate it and snap a picture. one of the reasons i bought this one is because it's a 36mm. making it the perfect size.
that mark on the dial face is on the crystal.
Wearing a chronograph I picked up on the 'bay. It wasn't running and had a knackered dial, but there was a 30mm dial on eBay that was cheaper than sending the existing dial to Messrs Bill for restoration (which I might still do), so I used that.
It has a lovely Landeron 47 movement (1937) which I enjoyed servicing. Runs sweetly. All it needs now is chrome replating...or not!
Thought I'd revive this thread as I enjoyed it and it seems to have gone quiet.
Today's offering is a 21 jewel hours and minutes only Accurist dress watch from (guessing) mid 1960's ish.
Housing a very pretty manual winding Peseux 320 which is a great time keeper, the only issue with it is the tiny crown makes it a pig to wind.
I'm very fond of this watch for its simplicity but it doesn't get a lot of wrist time due to the lack of water proofing. I'm in the office today though so that's ok.
hi everyone,
todd here.
although i have an extensive collection, many more valuable than this one, this is my favorite everyday watch to wear.
a bulova computron drivers watch from 1976.
absolutely mint, with no bad segments, and a great story behind it.
I spoke too soon, in post yesterday, looks clean inside except for non-Seiko gasket, case is dirty, aftermarket brace, should clean up nice, she's a running!
Thanks Ramrod, PM me for details, I would like it to be close to original, I do have small wrist!
post-1800-0-83657200-1456486675_thumb.jp
    • https://watchguy.co.uk/cgi-bin/files?showfile=Venus/Venus 178.pdf&filename=Venus 178.pdf&dir=Technical Manuals&action=documents   The hour recorder is driven by the barrel and it will only stop if it is held by the hour recorder stop lever 8690. So I would check if this lever (powered by the spring 8691) is really holding the hour recorder in the "chrono off status". I haven't worked on a Venus 178 so far, but on an Omega 861 I chose 9501 grease for the friction spring as it's moving very slow at quite high tension.
    • All I do is use a fine marker (sharpie) to put the service date on the back cover, this way it can be removed with some IPA and does no permanent damage to the watch. I'm in two minds about the whole service marking thing, sometimes it's good/bad to see the markings on the watch case back as you know it's been worked on and vice versa. However, if I took my car in for a service and the mechanic scratched some code into the housing of my engine I wouldn't be too impressed. Hence, I think my sharpie solution is a reasonable compromise.
